    1 vote(s)
    3.4%
  2. Yes - roll/swipe on
    26 vote(s)
    89.7%
  3. Yes - areosol
    2 vote(s)
    6.9%
  1. Apr 10, 2025 at 6:30 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Very cool. TIL.
    "The janitors of nature."
  2. Apr 10, 2025 at 6:30 AM
    Ah. If it’s a loaner truck then fuck it
  3. Apr 10, 2025 at 6:30 AM
    Florida AF
    Logan
    North Florida
    whoa.... I take it they dont usually do loaners and you had something to do?
  4. Apr 10, 2025 at 6:49 AM
    Florida AF
    Logan
    North Florida
    It is annoying when work gets in the way of play time... today looks like it may be an interesting one
  5. Apr 10, 2025 at 7:05 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I might have the opposite situation today. Weather's nice and I haven't had a cigar with my dad in a couple of weeks. Might be a good day to sneak out at lunch and play hookie.
  6. Apr 10, 2025 at 7:17 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    That’s my favorite $4 HF flashlight
  7. Apr 10, 2025 at 7:20 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Looks like a 2x4 to me.
    T-Rex266, Blue Thunder and AZBaldy like this.
  8. Apr 10, 2025 at 7:35 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Looks like a very poor design and waste of space.
  9. Apr 10, 2025 at 7:45 AM
    Leo's first
    Groton ma
    Probably but I wedged a dime in there and had to use my Leatherman to get it back
    :confused:
    Exactly this!
    I’m calling it “the roach holder “ :rasta:
  10. Apr 10, 2025 at 7:58 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  11. Apr 10, 2025 at 8:03 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Me sitting here trying to remember all the posts I made in the last 24 hours...:confused::oops:
  12. Apr 10, 2025 at 8:03 AM
    Florida AF
    Logan
    North Florida
    I am so glad we didnt bet, because I would have lost money.
  13. Apr 10, 2025 at 8:25 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I wrongly assumed you were in a tundra. The coin holder in the tundra is located where the 4x4 knob would be...
  14. Apr 10, 2025 at 8:31 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Coin holder... :notsure:
    AZBaldy, OldGuy03, T-Rex266 and 2 others like this.
  15. Apr 10, 2025 at 8:32 AM
    Tripleconpanna
    Damn it... :frusty:
    Should've scrolled one post down before clicking reply :anonymous:
  16. Apr 10, 2025 at 8:33 AM
    Florida AF
    Logan
    North Florida
    ha! thank you for making me not feel crazy
  17. Apr 10, 2025 at 8:33 AM
    Tripleconpanna
    I read that as fleshlight the first go around :bananadead:
  18. Apr 10, 2025 at 8:36 AM
    Leo's first
    Groton ma
    :anonymous:
  19. Apr 10, 2025 at 8:44 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Of course you did.
  20. Apr 10, 2025 at 9:12 AM
    Azblue
    The Dirty T ( ^_^)_且
    If only there was a way to add multiple quotes to a reply as you read through a bunch of posts. :monocle:
  21. Apr 10, 2025 at 9:24 AM
    Florida AF
    Logan
    North Florida
    I will have to see if this is something the mod's could add... this seems like it would be useful for so many members here...
  22. Apr 10, 2025 at 9:35 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I did the same. And then went through my posts to actually verify.
  23. Apr 10, 2025 at 9:39 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    All right folks the dumb guy needs some help here. I need to replace the bearing hub assemblies on my trailer. I figured this would be real easy to just pull my old hub then look at the bearings inside to verify the correct part number. But apparently my bearings are either not stamped or that bearing number has been worn off. I know I have a 2200 pound torsion axle on the trailer, and it's a 5 x 4 1/2" bolt pattern that I'm looking for. I've also measured the axle diameter and taken this information to the Google machine, but still can't verify I'm buying the correct part. I guess my other solution would be to just repack these hubs with new bearings instead of buying the whole new assembly, but I still have no idea if I'm buying the correct bearing . Any and all help would be appreciated.
    Blue Thunder, AZBaldy and T-Rex266 like this.
  24. Apr 10, 2025 at 9:39 AM
    Florida AF
    Logan
    North Florida
    in unrelated news... Square dot com for business is fn annoying so far....
  25. Apr 10, 2025 at 9:41 AM
    Florida AF
    Logan
    North Florida
    oof... and I assume hitting up the sales sheet/manufacturer is not an option?
    thank you for reminding me I need to contact both vendors for those details before I NEED to do so.
  26. Apr 10, 2025 at 9:48 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Looked at spec sheet from my trailer and also called the manufacturer. Got the message that because those parts are always in flux there is no way to verify the part. Most confusing part of this whole debacle is, that my hub assemblies are not like most. It is not held on with a castle nut and a cotter pin, but by a different means that I've never even seen. It's kinda like a weird little clip ring that holds the nut in place on top of the washer which holds the bearings in. It is an ez lube axel. Only have a photo of the axel itself right now. Can take pics of the hub later tonight when I'm back at home.
  27. Apr 10, 2025 at 9:51 AM
    Florida AF
    Logan
    North Florida
    Sounds almost like a snap ring, which I hate... but regardless, I will be watching to learn since I do not have a clue!
  28. Apr 10, 2025 at 9:53 AM
    Azblue
    No idea, but I get all my trailer stuff like bearings and brakes from these guys. Maybe give them a call.
    https://www.southwestwheel.com/?srsltid=AfmBOorkRPg7AvhtPEuevTtTr-pVqoZ6_HlH6vI7zKbU3A-NuNmjSEti
  29. Apr 10, 2025 at 10:04 AM
    Tripleconpanna
    :D
    :militarypress:
    :nuclear:
  30. Apr 10, 2025 at 10:06 AM
    Tripleconpanna
    If only there was a way to create diversity amongst our Staff Members by hiring some 'challenged' personnel... :monocle:
    Oh wait....
    :nuclear:
