CrewMax + 6.5' Bed Off Road?
Discussion in '3rd Gen Tundras (2022+)' started by Ry'sTundra, Apr 9, 2025.
  1. Apr 9, 2025 at 11:45 PM
    Ry'sTundra
    Ry'sTundra [OP] New Member
    2009 SR5, 2017 SR5 (Sold)
    Question for you Crew Max + 6.5' bed owners... how does it perform off road? It's about time to replace my 2009 Double Cab and the new DC back seat is too small. But the CM with a 6.5' bed has me worried about off road maneuverability and ground clearance. I'm not looking to make it a rock crawler, but I like to get into some out of the way camping and hunting spots. Also looking to rig it with a Four Wheel Camper or similar, so the extra foot of bed length would be a plus.
    Would love to hear from anyone that has put together a similar build.
    Thanks!
  2. Apr 9, 2025 at 11:56 PM
    aktundra34
    aktundra34 New Member
    I have a crewmax with a 6.5 bed and find that it does just fine off-road in Alaska. If you can afford to get one with the pvm camera setup, it is so much easier to maneuver on tight trails. If ground clearance becomes an issue for you (it has not for me) you could always lift it. The one thing that is a major tradeoff is poor maneuvering in small parking lots - I typically just park further away.
    Blufin, wing-2 and troutback like this.
  3. Apr 10, 2025 at 12:02 AM
    Ry'sTundra
    Thanks! And yes, I plan on getting the off road package with PVM, and add at least 33" tires to start, maybe a lift later.
  4. Apr 10, 2025 at 6:54 AM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    I have crew Max off road package 6.5 bed. ~2.5 in lift on front and ~1 in lift on rear. 37x12.5 tires. Mild off roading and it does great. Desert running, snow, mud, rocky trails (nothing extreme). 3 years and almost 100k miles on my truck
  5. Apr 10, 2025 at 7:00 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    OEM tires are 32.5"...that 1/4" of height difference with 33" will be huuuuugge
    Hbjeff likes this.
  6. Apr 10, 2025 at 12:00 PM
    TheDo114
    TheDo114 New Member
    2022 Black Tundra SR5 TRD Offroad
    Lol, the OEM tire are closer to a 32 in real life than 32.5. If you get an aftermarket 33 you'll get a inch more. I know it's not a lot, but an inch is an inch ;)
    size matters :anonymous:
  7. Apr 10, 2025 at 9:21 PM
    Dirtsurfer83
    Dirtsurfer83 New Member
    Olalla, WA
    '23 Tundra TRD
    Dobinsons IMS 2/1 Method 703 Toyo RT Trail 35x12.50r17
    My truck has about the same turning radius as our full size dump truck. I’ve become a master at 3 point turns in parking lots and in the woods, lol. Long wheelbase and sits pretty low even with small lift. Rocky terrain and I’d invest in gas tank skids, etc
  8. Apr 10, 2025 at 10:33 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    The women always love that extra inch!
  9. Apr 11, 2025 at 11:37 AM
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    I came from a 2008 double cab and have the crew max 6.5’ bed. However I don’t off road my trucks aside from gravel roads.
    It is a very long truck, but to me has a good turning radius for how long it is. I also end up parking far away and back in most of the time. I think it would be fine with mild/moderate off roading. I wouldn’t get a shorter one just for slightly better turning off road. The crew max 6.5’ is such an awesome combo.
    TheDo114 and 22whatwedo like this.
  10. Apr 11, 2025 at 3:47 PM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    I have this exact config waiting for me to pick up next week: 25" TRD OR Limited 6.5 in Lunar Rock. I need to tow with it so I will deal with the extra length when off road.
    TheDo114 likes this.
  11. Apr 11, 2025 at 4:00 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Even if you get an inch larger tire, it’ll only add 1/2” of clearance. Won’t even make a difference. Just hold off on swapping tires til you’re set on your lift and can get atleast 35’s or 37’s. That’s a really long wheelbase to be off-roading.
  12. Apr 12, 2025 at 6:43 AM
    TheWoods
    TheWoods New Member
    2010 Tundra TRD 5.7
    Yes parking is a problem being a foot longer in length. Using the sensors.
  13. Apr 12, 2025 at 12:49 PM
    TheDo114
    TheDo114 New Member
    35 and 37 look nice, but they are a real killer in fuel economy and ride comfort.
    I just measured and my stock tire measure 32.1 and my new ones are 33.5. 35’s are usually between 34.5 and 34.8 so that would only net me another half an inch of extra ground clearance and kill any fuel economy I have. Now going to 37’s would make a drastic difference, but I better hold a funeral for fuel milleage, handling, breaking distance, etc.
    I’m not rock crawling or going in extremely steep holes. Slightly bigger, more aggressive tires and better skidplates are enough for what I do. I mostly deal with mud, gravel, sand, water and small rocks, with the occasional bigger boulder climb but they are big enough that I do not have to worry about break over angle.
    I can’t go anywhere yet since everything is still snowed in, but I should be able to get to the deer camp by the end of the month and the moose camp by the end of May and see how it goes.
  14. Apr 12, 2025 at 1:54 PM
    dagooaz
    dagooaz New Member
    Dave
    I have 35s with a 3” Westcott lift upfront and the TRD Bilsteins from the TRD lift. I have 1” lift Dobinsons springs in the rear with TRD Bilsteins. Sucking the gas mileage down? A bit, I lost about 3 MPG. Ride and handling? Ride same as stock on my hybrid. I also went down to 18” wheels from the stock 20” Handling is much improved. As far as braking, didn’t have an issue towing an 8k lb trailer.
    TheDo114[QUOTED] likes this.
  15. Apr 12, 2025 at 2:15 PM
    bailey bulldog
    bailey bulldog New Member
    What tires do you have?
  16. Apr 12, 2025 at 2:26 PM
    dagooaz
    dagooaz New Member
    Dave
    Falken Wildpeak AT4W. Love em.
  17. Apr 12, 2025 at 4:35 PM
    TheDo114
    TheDo114 New Member
    Don’t get me wrong, your truck will be better off-road with the lift and bigger tires and will look amazing. Lifted Tundras with bigger tires are so nice.
    But you’re still using 15% more gas, have a longer braking distance, not to say that it’s unusable, but longer nonetheless and poorer ride and handling than a stock truck for day to day.
    Is the compromise worth it or not, and to me, 15% more fuel represents around 2000$ a year so it’s a pretty big difference.
  18. Apr 12, 2025 at 4:58 PM
    kjinxx2
    kjinxx2 New Member
    Wow I thought I drive a lot... $13k a year in gasoline is insane
  19. Apr 12, 2025 at 5:11 PM
    dagooaz
    dagooaz New Member
    Dave
    Like I mentioned in my post, my ride is the same as stock with the setup I have and it handles much better through turns. Yes, I knew I’d take a hit on mileage. But there’s a price to looking good.
    joonbug likes this.
  20. Apr 12, 2025 at 5:17 PM
    koditten
    Kirk
    Midland of the Mitten
    Wow! the things you can learn? I didnt know you could get a CM with a 6.5' box? I'm jelly.
  21. Apr 12, 2025 at 5:42 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Well OP asked about offroading. Not fuel economy.
    TheDo114[QUOTED] and Blufin like this.
  22. Apr 13, 2025 at 3:02 AM
    TheDo114
    TheDo114 New Member
    Good old Canadian prices for gas
