General Supercharger Thread
  1. Apr 8, 2025 at 6:24 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Just got it home. Ol girl pulled it like a champ up the mountain
  2. Apr 8, 2025 at 6:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's a boat...
  3. Apr 8, 2025 at 6:29 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's a good sale. But I'm saving for a trans rebuild and another engine...
    Saltyhero13 likes this.
  4. Apr 8, 2025 at 6:37 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    and it was already 24% off on their site... so 34% off total.
    dealers get 27% off so already better than that. hard to pass up when i need new brake anyway
    Mdl[QUOTED] likes this.
  5. Apr 8, 2025 at 7:24 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I wouldn't take one if it was free. Hard pass.
    NatesNightMare likes this.
  6. Apr 8, 2025 at 7:25 PM
    Saltyhero13
    What was your baseline stock run?
  7. Apr 8, 2025 at 7:30 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I didn't do a dyno before the SC install
    Saltyhero13[QUOTED] and Mdl like this.
  8. Apr 8, 2025 at 7:42 PM
    blenton
    blenton New Member
    Same. Not my jam. Not anymore. U less they made a full-size two door bronco. Then I might make a bad decision on purpose. But even that is a BIG maybe…
    Saltyhero13[QUOTED] likes this.
  9. Apr 9, 2025 at 12:17 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Well shit.
    This was just north of 900 mles on Kirkland 0-20 full syn after the install & drive to L.A. & back.
    New oil has no visible oddness, oil level is not higher than it should be, coolant is where it was when finished, has no oddness, no smell other than oil.
    Can this be from 6 months sitting in an open junk yard, no hood, radiator ripped off, fender ripped off, etc?
    HulkSmurf14 likes this.
  10. Apr 9, 2025 at 12:41 PM
    blenton
    blenton New Member
    Hmmm.. that is odd. Are you opposed to dumping that oil and simply changing the oil and filter? I’d honestly do that once, maybe twice, just to get rid of any possibility of residual contamination from the swap. Then drive it another 1000 miles and send in a sample. Oil is cheap compared to a motor, IMO.
  11. Apr 9, 2025 at 12:41 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Shit man, can't catch a break, can you? :(
    Tripleconpanna likes this.
  12. Apr 9, 2025 at 12:54 PM
    e30cabrio
    I have 20 quarts of Kirkland & about 10 filters, I'll be dumping the oil & filter in the morning, it's 98 right now.
    Nope, no break found unless you figure getting this report & draining the oil might be a break.
  13. Apr 9, 2025 at 1:01 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Can't know how screwed you are if you don't check :D
    I wouldn't sweat it or over think it until you have repeatable results. If the engine feels like it's running fine and fluids look fine, don't stress.
    Tripleconpanna, Wynnded, Mdl and 3 others like this.
  14. Apr 9, 2025 at 1:07 PM
    e30cabrio
    Sorry, it had its hood :D
  15. Apr 9, 2025 at 1:26 PM
    blenton
    blenton New Member
    Geez.. was it mauled by a disgruntled excavator??
    Wynnded, NatesNightMare and centex like this.
  16. Apr 9, 2025 at 2:01 PM
    centex
    centex New Member
    The metals are low. I’d flush it and run it.
  17. Apr 9, 2025 at 2:47 PM
    bflooks
    bflooks New Member
    Metrowest MA
    that? just a scratch. shit'll buff out.
  18. Apr 9, 2025 at 9:33 PM
    Saltyhero13
    Lightly used.
    Don’t lowball me.
    I know what I have!
    bflooks and blenton like this.
  19. Apr 10, 2025 at 6:11 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    I totally agree with you!
    Love the Old vehicles
  20. Apr 10, 2025 at 7:19 AM
    e30cabrio
    Oil & filter draining, it's taking a long time to stop streaming, oil looks & smells fine, feeling like I should get it tested too but I suppose waiting 1k & changing it again makes more sense, I'll be taking the BMW motor to Ca Saturday or next weekend so the 1k will be done pretty fast. (750 mile round trip).
    HulkSmurf14 and armyoffoo like this.
  21. Apr 10, 2025 at 9:06 AM
    e30cabrio
    I have 1.5 q left in 5 gallon jug #2 & the dipstick says I'm 1/2 low. (I put in 8 & it showed I had almost nothing on the dipstick so I added 1/2 a quart).
    That's never happened before.
  22. Apr 10, 2025 at 9:18 AM
    snivilous
    SW UT
    Sounds right to me, as I recall it usually takes just over 8 quarts. Either two gallon jugs isn't enough, or two 5qt jugs leaves an annoyingly small amount left.
    Wynnded, HulkSmurf14 and bflooks like this.
  23. Apr 10, 2025 at 9:19 AM
    centex
    centex New Member
    About 8.5qrs for my tundra depending how long it sits before I drain it.
  24. Apr 10, 2025 at 9:25 AM
    e30cabrio
    I let it drip over an hour until almost nothing was coming out, Does the Jowett add anything? I'm used to being just over on 8.5. I'm letting it sit a while & I'll check it & add the 1/2 if it's still showing 1/2 low.
  25. Apr 10, 2025 at 9:26 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Is that a 69?
  26. Apr 10, 2025 at 9:27 AM
    ssmokedz
    Shelton CT
    I didn't realize you are a fellow MDT! It makes me sad that most these guys know way more about Toyotas than I do LOL
  27. Apr 10, 2025 at 10:21 AM
    e30cabrio
    Hour later, still 1/2 low, added slightly over 1/2 as it's hard to judge on the 5 quart bottles.
    Hopefully the next sample is normal
  28. Apr 10, 2025 at 10:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You need to add a remote filter and engine oil cooler. That way it's an easy 10 quart fill...
    Wynnded, bflooks and HulkSmurf14 like this.
  29. Apr 10, 2025 at 10:29 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! My mom was married to a gasser spent all his time building and racing. She shakes her head everything I'm working on the truck.
  30. Apr 10, 2025 at 10:32 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Or a PML oil pan...
    Wynnded, Mdl and bflooks like this.
