2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Oct 18, 2017 at 4:58 PM
    #91
    bluecrush
    bluecrush New Member
    What LEDs did you put in there? I was considering the 2018 fogs also...but if your LEDs are cheaper, may do that.
  2. Oct 19, 2017 at 7:06 PM
    #92
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Does the other harness made my thomas dim the led drl?
  3. Oct 19, 2017 at 7:12 PM
    #93
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Those harnesses does not have a PNP DRL harness. You would have to wire them up to the stock DRL relay in order for them to dim. Stock Platinum/1794 harnesses have the dim feature, just not SR5/Limited/Pro since they do not come with LED DRL's from factory.
  4. Oct 19, 2017 at 7:16 PM
    #94
    eledobleu
    Orlando, FL
    Toyota does not have the feature where the DRL's turn off when blinkers are engaged. The DRL's do not dim to allow turn signals to perform better at night, they only dim because DRL's are not needed at night while headlights are on. When the headlights are on, the main LED headlights are so much more brighter than the DRL's that they drown out the DRL's. Having the DRL's on all the time wont effect or interfere with DOT standards of stock turn signals or headlights.
  5. Oct 19, 2017 at 7:20 PM
    #95
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    @eledobleu can make them dim pnp but it’s gonna be more than 200 since more parts are needed.
  6. Oct 19, 2017 at 11:08 PM
    #96
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    I didn’t say Toyota had “DRL off with turn on”. The headlights don’t drown out the DRL’s when on Hi/bright. If you have the headlights ON with the DRL’s ON bright(day or night)the turn signal beam drowns. The “effective luminous intensity” of the turn signal is lowered. It’s all in the design of the headlight. Where each thing is located, how far apart and so on. This is why the DRL’s go on LOW with the headlights on. The turn signals MUST meet minimum requirements for visibility.
    BlueBottle and iHacker like this.
  7. Oct 20, 2017 at 8:11 AM
    #97
    eledobleu
    Orlando, FL
    Yes the price would be more so around $350 as a Relay is needed to be added and more wiring. If those of you that feel you need the Dim function for non Platinum tundras please let me know
    I stand corrected, nice post! I have OEM platinum retrofit with Panamera DRL Shrouds for the past 2 years (non platinum Tundra). My LED's do not dim when headlights are on "bright all the time". Never had any problems or issues. Yes the headlights do drown out the DRL's. When im driving behind a vehicle, only thing people see are my headlights. You must understand that we drive a full size truck with the majority of people running lift kits. Even without a lift kit our trucks headlights blinds all cars and most SUV's directly in front of us as we sit higher off the ground. Anyone within that distance of 10ft in front of us will not see our parking lights or DRL's as the headlights will be shining onto their vehicles.
    iHacker likes this.
  8. Oct 20, 2017 at 8:20 AM
    #98
    eledobleu
    Orlando, FL
    ***UPDATE***
    ALL PARTS ARE IN AND HARNESSES ARE BEING MADE FOR EVERYONE. ORDERS ARE NOW BEING ACCEPTED. PAYMENT INSTRUCTIONS WILL BE SENT TO ALL EMAILS ON THE LIST. WAIT TIMES WILL VARY BASED ON YOUR POSITION ON THE LIST. HARNESSES ARE MADE PER ORDER/PAYMENT SO PLEASE FOLLOW THE INSTRUCTIONS AND MAKE SURE YOU INCLUDE ALL DETAILS OF YOUR ORDER.
    KEEP IN MIND IT TAKES TIME TO MAKE THESE HARNESSES. IF YOU PLACE AN ORDER TODAY AND DO NOT RECEIVE YOUR HARNESS, HAVE PATIENCE PLEASE!
    X09, ncmtnman and Tundracollector like this.
  9. Oct 20, 2017 at 8:59 AM
    #99
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    Yea regardless what we think looks good or not. The DOT standards are there for reasons we like or don’t like. Lol just like you said our trucks are lifted to certain heights and even that has a bumper height requirements lol but screw it it looks good,right? Lol so many rules and regulations. Most of the things we do to our cars or trucks are for off road purposes anyways.
    Regardless, good job on producing these harnesses. :thumbsup: Now our trucks look good as far as the headlights go.
    eledobleu[QUOTED][OP] likes this.
  10. Oct 20, 2017 at 9:24 AM
    #100
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    I’m not taking sides but @eledobleu did the harness this way because the majority of the people out there wanted a PLUG n PLAY harness “the easy route” without doing the dirty work themselves and making them 100% OEM function. So the only option was to keep the drl hi’s on all the time in a PNP harness and most people don’t know better and it kept the cost down. Cause in reality he’s not making much off these harnesses once parts ordered/built/shipped
    Mw4904, ncmtnman, st33l and 1 other person like this.
  11. Oct 20, 2017 at 10:42 AM
    #101
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Tundracollector likes this.
  12. Oct 20, 2017 at 10:44 AM
    #102
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    iHacker[QUOTED] likes this.
  13. Oct 20, 2017 at 10:47 AM
    #103
    iHacker
    iHacker SW TRD PRO
    Mario
    As you mentioned this I figured this before too, but not so easy to make it on mass production for Leo or anyone doing harnesses :D
  14. Oct 20, 2017 at 11:23 AM
    #104
    lutznutz
    lutznutz New Member
    Plant City, FL
    2016 Tundra SR5
    Is it possible for that to be added to an existing harness? I kind of want to have them installed and see how they do before I decide I want the DRL dimming.
  15. Oct 20, 2017 at 11:37 AM
    #105
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Yes
  16. Oct 20, 2017 at 4:25 PM
    #106
    eledobleu
    Orlando, FL
    All emails have been sent! If you did not receive an email, please send me an email at eledobleuretrofits@gmail.com
    And please remember to have patience. These harnesses take time to make. They may take weeks to get down the list.
  17. Oct 20, 2017 at 6:39 PM
    #107
    jdm ctr '00
    los Angeles, CA
    2016 Tundra TRD PRO
    I’m in no way knocking anything he is doing. Just saying how and why Toyota has the lights working that way. I 100% understand why he makes the harness that way. It’s not easy to have them dim. People can do anything they want.:thumbsup:
  18. Oct 23, 2017 at 9:29 AM
    #108
    Bable985
    Bable985 New Member
    2014 silver sky limited trd
    ED4B7D48-1C2D-48DB-B098-8235A27CACF5.jpg I am mechanically incompetent but 4hrs later.... if I can anyone can.
  19. Oct 23, 2017 at 9:46 AM
    #109
    bluecrush
    I don't think I realized the amber blinkers stay on with the DRL LEDs also? I looked at some other pictures and they aren't on....
  20. Oct 23, 2017 at 9:50 AM
    #110
    iHacker
    iHacker SW TRD PRO
    Mario
    This is because @Bable985 left his parking lights connected in the turn signal when he repined the socket, if he want to get rid of the amber parking light he have to de-pin, cover and secure it with tape
  21. Oct 23, 2017 at 9:51 AM
    #111
    Bable985
    Bable985 New Member
    @bluecrush they don’t I had the parking lights on but I think I like this look
  22. Oct 23, 2017 at 9:52 AM
    #112
    inferno_pro_satx
    Roger
    2016 Tundra TRD Pro
    Absolutely 100% correct
  23. Oct 23, 2017 at 10:03 AM
    #113
    bluecrush
    Yeah me too! The only bummer is the dash/navi dims when you turn the parking lights on....so, in sunny Texas....I can't see my screen. Curious...do you guys have any ideas for brighter blinker bulb? Seems pretty dim and much smaller than the old front blinkers. Anyone tested any LEDs out yet?
  24. Oct 23, 2017 at 12:25 PM
    #114
    Silvertss
    Silvertss New Member
    So these will work if you don't have drls now right they will work with that harness
  25. Oct 23, 2017 at 12:34 PM
    #115
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
  26. Oct 23, 2017 at 7:19 PM
    #116
    KAM392
    KAM392 New Member
    2017 Silver Sky Metallic Platinum
    Where is the email list for the Harnessess
  27. Oct 23, 2017 at 8:12 PM
    #117
    boloson
    boloson New Member
    U have to email @eledobleu
  28. Oct 23, 2017 at 10:47 PM
    #118
    X09
    X09 New Member
    San luis obispo ca
    2017 Tundra Crewmax Limited
    What do i need for my 2017 Tundra Limited. What's his e-mail? Just received my 2018 headlights this morning. Hopefully i can get the harness next. Thanks
    Bob likes this.
  29. Oct 24, 2017 at 8:10 AM
    #119
    zwillz
    zwillz New Member
    2015 sr5 Crewmax
    Sry, I jus sawt your question... I had the 2018 fogs in my cart, but I decided to wait. Glad I did! They match pretty damn good. I got them on ebay for $40, and they are Bright!! Inbox me if you want the link. They are full PNP. Thx
    Link
    https://www.ebay.com/itm/LED-Kit-N1...ash=item2117f820c2:g:dTMAAOSwLF1X8Mpj&vxp=mtr
    victm4 and slide187 like this.
  30. Oct 24, 2017 at 8:12 AM
    #120
    zwillz
    zwillz New Member
    2015 sr5 Crewmax
    Sevi_86[QUOTED] and Bob like this.
