Dimming rearview mirror
Discussion in '2nd Gen Tundras (2007-2013)' started by Connavar, Mar 30, 2025.
  1. Mar 30, 2025 at 8:28 PM
    Connavar
    Connavar [OP] New Member
    2008 SR5 double cab
    I have a 2008 SR5 Dc, Play current manual rear view mirror glasses starting to crumble away and I was looking to replace it with the auto dimming one. Does anyone know if the 08 double cab SR5 came pre-wired above the upper console for the auto dimming mirror?
  2. Mar 30, 2025 at 9:10 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    If you do, it should look like this.
    I would find it and verify how many pins the connector has before buying one.
    Either remove the overhead console or feel up behind the headliner.
    It would need these wires for your dimming.
    The white wire would also power the garage door opener if applicable.
    Unfortunately, that mirror OEM is almost $1K.:eek2:
    Hopefully you can find a cheaper used or aftermarket part.
    87810-0C050 - 2006-2009 Toyota - Mirror Inside | Sparks Parts
    There are several on eBay, just make sure your connectors match.
    Some of them have 12 and 14 pin connectors.
    Good luck..
    Thumper_6119 likes this.
  3. Mar 30, 2025 at 9:52 PM
    FFR1910
    FFR1910 New Member
    My 2009 did, I added the oem from
    eBay with the garage door buttons. One of the best mods I have done. Bill
    1lowlife likes this.
  4. Apr 8, 2025 at 6:23 PM
    Connavar
    2008 SR5 double cab
    Turns out the wiring was in the center roof console and I was able to get an OEM mirror from a junkyard here for $70. Everything plugged right up and started working thank you both for all your help and information.
  5. Apr 8, 2025 at 6:32 PM
    FFR1910
    FFR1910 New Member
    Perfect, glad it worked out for you. Bill
  6. Apr 8, 2025 at 7:28 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    That is awesome..
    Glad you figured it out..
    I would miss my dimming feature and I use the garage door opener every day.
