Low Boost under acceleration
Discussion in '3rd Gen Tundras (2022+)' started by DCTundraBT, Mar 22, 2025.
  1. Mar 22, 2025 at 10:31 PM
    DCTundraBT
    DCTundraBT [OP] New Member
    Carl
    Hendersonville, NC (WNC)
    24 Brown Town Tundra
    Guys, I noticed today when towing my camper that from a stop, under full throttle I am only getting 10ish psi of boost in 1st gear, as soon as it shifts to 2nd I am getting 18psi. Is this normal? It never did this until today.
    Will the tundra pull boost based on fuel? Or crappy fuel?
  2. Mar 23, 2025 at 10:58 AM
    Tiger85
    Tiger85 New Member
    2025 Mag Gray Platinum i-Force MAX
    Can't say I've tried to go full throttle while towing. I've got the hybrid and under regular acceleration while towing the hybrid assists and the boost maybe goes to around 10.
  3. Mar 23, 2025 at 11:01 AM
    Breathing Borla
    AZ
    geez, this things rips while towing, why the WOT?
    are you in tow or tow + depending on your trailer weight?
  4. Mar 23, 2025 at 6:53 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    That can be torque management in those lower gears by the ECM.
    My Superduty diesel did that as well to protect the drivetrain under the high torque in low gears. It could still spin the wheels taking off while towing though.
    Blufin, ColoradoTJ, BlackNBlu and 2 others like this.
  5. Apr 7, 2025 at 12:38 PM
    DCTundraBT
    Carl
    Hey TW - I am looking into changing the plugs on my truck (33,xxx Miles) , This is what happening - not building boost - only 7-10 PSI in 1st gear and 15-20 in 2nd. Idle seems unstable too. What are your thoughts. Acceleration video link below.
    Here is a link to the video - https://photos.app.goo.gl/tzHMCXvbfhVBGduQ9
  6. Apr 7, 2025 at 1:19 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds like torque limits, truck doesn't want to give full power since 1st gear ratio would be too low and could break things. Nothing wrong with it, consider it a feature.
    ColoradoTJ likes this.
  7. Apr 7, 2025 at 1:43 PM
    DCTundraBT
    Carl
    I could understand that if its been like that since day 1. But this just started happening with 31,500 miles on it. I have been towing 4K LBS pretty consistently with it too. Idle has been inconsistent too. running 91 OCT it will build a little more boost PSI also.
  8. Apr 8, 2025 at 1:39 PM
    GeoNeo
    GeoNeo New Member
    Geo
    2022 Tundra
    I am not sure on the Tundra as mine doesn't have the boost gauge but it is NOT uncommon for manufacturers to limit boost in 1st and 2nd gear. Keeps you from breaking things and tries to give usable power without loosing traction. You were getting 18 pounds in every gear before this? * Scratch That i just saw you said you were*
  9. Apr 8, 2025 at 1:48 PM
    DCTundraBT
    Carl
    I was getting 18ish PSI of boost. It used to break the tires loose. My fuel economy has dropped also by 30% now and I am noticing the engine coolant level is below the low mark. Engine oil looks fine, not milky.
  10. Apr 8, 2025 at 1:49 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    I can't imagine full boost in first gear while towing NOT obliterating the tire(s). It has to be limited.
    But it does sound like something has changed.
    Simple things first:
    Looked at your air filters lately?
  11. Apr 8, 2025 at 1:50 PM
    DCTundraBT
    Carl
    I replaced them within the last 2 weeks too. It would roast tires before all this, and traction control would kick in under full throttle from a dead stop. It's gutless pulling the 4k lbs camper we have now too
  12. Apr 8, 2025 at 2:39 PM
    Breathing Borla
    AZ
    just speculating but maybe a plug fouled
    Im trying to think do I get full boost in 1st gear, I mean its so fast to shift, Im not sure
    try tow haul +, there is no torque management and see how she rips
  13. Apr 8, 2025 at 3:04 PM
    GeoNeo
    GeoNeo New Member
    Geo
    2022 Tundra
    I have worked on a LOT of Turbo vehicles and i cannot think of any that give FULL BOOST in the first two gears on an automatic vehicle.
    The fuel economy and the rough idle make me think this is a ignition system issue. Check the coil pack connections to the plugs. But no misfire codes is strange if its that bad
  14. Apr 8, 2025 at 3:59 PM
    DCTundraBT
    Carl
    I changed the plugs last night thinking the same thing and noticed the coolant was way below the low mark ( I look Everytime I change the oil). All the plugs like similar to the one below. After changing the plugs it still doesn't run any better.
    About the coolant, I started/ran the truck today for about 1 min and it had a lot of pressure in the coolant container. I am thinking we got a failed head gasket
  15. Apr 10, 2025 at 8:52 AM
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    OK, oil isn't milky. Notice white smoke from the exhaust? The coolant has to be going somewhere.
  16. Apr 15, 2025 at 6:02 AM
    DCTundraBT
    Carl
    Can someone send me a WOT video from 0-45/60 please. I want to see the turbo boost in 1st gear. I know it's quick and could break the tires loose, but I need this information. I am being told my truck is operating like normal. I need some help guys
  17. Apr 15, 2025 at 8:22 AM
    Noobo Baggins
    Glenn
    My 2025 doesn't show much boost at all. Barely registers anything on the gauge. Wish there were a way to wake up the turbos somehow. Gotta think someone somewhere has a hack for that ... but then again, this motor hasn't really proven itself worthy of performance tweeks.
  18. Apr 15, 2025 at 8:27 AM
    Raven67
    Kentucky
    I guarantee you won't see full boost in 1st gear. It's called torque management. Computer is in charge.
    Boost will raise as you get to higher gears.
    Redward 25 likes this.
  19. Apr 15, 2025 at 8:39 AM
    Redward 25
    Redward 25 New Member
    2025 SS red Tundra SR
    none....yet!
    I highly doubt it's a head gasket. There are two coolant tanks, one for turbo/intercooler and one for engine. It's possible that a turbo has a leaking seal or a cracked housing that is causing coolant loss, and loss of boost. But as other posters have said, computer controls boost and limits it. I would think it would throw codes if something were that amiss.
  20. Apr 15, 2025 at 8:41 AM
    Redward 25
    none....yet!
    Or the low coolant in intercooler side is raising inlet temps and computer is limiting boost to prevent or is detecting detonation.
  21. Apr 15, 2025 at 8:42 AM
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    ^This. The computer wont let you have full power at low gear low speed. In the new Ford superduty with 6.7HO, it wont let you b/c otherwise youd be smoking tires all the way to 60mph.
    Raven67[QUOTED] likes this.
  22. Apr 15, 2025 at 2:05 PM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    Before someone posts the video, see if this one helps.
    Tundrastruck91 likes this.
  23. Jun 9, 2025 at 11:41 AM
    GeoNeo
    GeoNeo New Member
    Geo
    2022 Tundra
    Any resolution on this?
  24. Jun 10, 2025 at 6:36 AM
    DCTundraBT
    Carl
    Nope, No resolution. The dealership deep dove the issue, and found history of the transmission requesting the engine to reduce power because one sensor in the trans was showing hot/overheated fluid. The date that is occurred I was not towing or hauling anything. I am being told this was normal from Toyota/Dealership.
    When I connect my 4K camper, you have to WOT it to actually get moving, its becoming worse to drive. When you are trying to pull out into any HWY traffic with any load its only building 8 PSI of boost when it used to build 18PSI and it used to roast the tires if you WOTed it, and now it takes for ever to get out of 1st gear. Also, 1st, 2nd and 3rd most of the time seem like a CVT transmission. I am waiting for it to get worse so the dealership will actually do something about it. I have the Platinum 7yr 125K warranty (Thank you - Jerry Johnson)
  25. Jun 10, 2025 at 7:10 AM
    Raven67
    Kentucky
    Think you need a different dealer. You most definitely have a problem.
    Breathing Borla likes this.
  26. Jun 10, 2025 at 7:31 AM
    DCTundraBT
    Carl
    Raven, I am agree, we are in process of moving, and I will be taking it to a different dealer once we are settled. I will keep this post updated.
    The truck has been in the shop 3 times for the transmission. 1st time in was at APRXX 1 K miles and it felt like 2nd gear slip - was told it was driving like normal. 2nd time in was at 34K and low boost started (engine pulling power from dead stop = low boost) - Dealership cleared all driving data ( reset all learned behavior ) and the issue was still there. 3rd time in at 35K and found the trans temp high and engine power being pulled (engine pulling power from dead stop = low boost) - Was told this was normal ( What a joke) and its getting worse. hopefully on the 4th time in (Different dealer) they will do something.
  27. Jun 10, 2025 at 7:40 AM
    EmergencyMaximum
    Maybe the truck is eating bearings and can't make enough power to request higher boost due to friction? I doubt computer would pick up worn bearings; probably just thinks you are too heavy all the time?
    Edit: Or maybe...[conspiracy theory] there *is* a bearings health sensor and computer is limiting boost to save the engine past warranty so it doesn't grenade itself too soon?
