My neighbor, a “hack mechanic/jimmy rigger”, said not to use magnetic spark plug sockets because….
Discussion in '1st Gen Tundras (2000-2006)' started by StrawberryBlowpopPrincess, Apr 8, 2025.
  1. Apr 8, 2025 at 1:54 PM
    StrawberryBlowpopPrincess [OP] New Member
    2002 sequoia RWD
    my neighbor who is a master of misinformation, (same guy from my other thread who told me to forget about changing my O2 because at worst, I’m only losing one MPG per day of driving that the cost doesn’t justify buying them)…. And oh, You should hear some of the “advice” hes given me in the past. Like spraying down a squeaky belt with WD40. Or jumping on the lug nut wrench to tighten down my lug nuts to make sure they are “good and tight, don’t want the wheel falling off” (correct spec is 83ft lb, and he weighs at least double that)… oh I have many many more stories
    Anyways, I usually never listen to advice once I figured out just how much of a hack he his, as a self proclaimed “shade tree mechanic” but…
    He was telling me today to never use magnetic spark plug sockets because it can throw off the balance of the metal inside of the spark plug. And although usually I don’t listen to him, I do know that taking a magnet to metal can and will change the metal to being magnetized/Demagnetized. he said that I wasted my money on that socket and it’s just another way for big corporations to get inside my pocketbook at the cost of doing things the wrong way.
    I thought I would come here and ask the real professionals on whether or not I’m making a mistake on using a magnetic spark plug socket.
  2. Apr 8, 2025 at 2:01 PM
    Your neighbor is a clown.
  3. Apr 8, 2025 at 2:06 PM
    I wasn't aware that you could magnetize an aluminum can ...........
  4. Apr 8, 2025 at 2:08 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Probably the same "mechanic" from the other thread that concluded a leaky tire was the cause for an electrical draw :D
    WILLINH, Weagle, bulldog93 and 3 others like this.
  5. Apr 8, 2025 at 2:08 PM
    centex
    centex New Member
    I’ve heard a lot in my days but that takes the cake.
    WILLINH and Weagle like this.
  6. Apr 8, 2025 at 2:09 PM
    centex
    centex New Member
    Oh where is that thread. I need some toilet reading material.
  7. Apr 8, 2025 at 2:12 PM
    snivilous
    SW UT
  8. Apr 8, 2025 at 2:15 PM
    2002 sequoia RWD
    Oh if you think that’s bad you should just hear what all this guy has said in the past. And he’s a nice guy, I hate it for him, but being nice doesn’t mean your not an idiot
    Nicklovin, Weagle, bulldog93 and 2 others like this.
  9. Apr 8, 2025 at 2:23 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    You're being very kind.
  10. Apr 8, 2025 at 2:24 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    I personally have never heard of or have seen a magnetic spark plug socket. Every one that I have encountered in my life of 40+ years of wrenching on cars and changing countless spark plugs, has a rubber insert that gently hugs the porcelain portion of the plug.
    BroHon, WILLINH, Weagle and 4 others like this.
  11. Apr 8, 2025 at 2:25 PM
    BlackNBlu
    Rich
    MN
    I've seen/had both. Prefer the rubber insert.
  12. Apr 8, 2025 at 2:28 PM
    2002 sequoia RWD
    Well they definitely (?just started?) make them. I own one and am excited to use it…
    also, to use or not to use dielectric grease on the spark plug/boot? Half the videos i watch use it, the other half don’t. What should I do? (Im still a beginner, but all the Toyota videos never use the dielectric grease, but then I watched Chris fix change spark plugs and he used it and I usually trust what he says… maybe Toyotas are different in this case???)
  13. Apr 8, 2025 at 2:33 PM
    ATBAV8
    Tempe, AZ
    Again, 40+ years and never. If your boots are in good shape, it's a non-issue.
    Weagle and bulldog93 like this.
  14. Apr 8, 2025 at 2:43 PM
    centex
    centex New Member
  15. Apr 8, 2025 at 2:45 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    Little grease won’t hurt, same with a tiny bit of antiseeze on the upper thread part. Now if too much of either is used problems can happen.
    BlackNBlu and Black Wolf like this.
  16. Apr 8, 2025 at 2:47 PM
    He must own a Renault. They "supposedly" had a warning about not using a magnetic spark plug removal tool on some of their engines but I haven't seen an official posting. More hearsay than anything.
  17. Apr 8, 2025 at 2:50 PM
    centex
    centex New Member
    20+ years and I’ve never used it and no issues. I’m also the guy that puts a little anti-seize on spark plugs and has never had an issue.
    BlackNBlu and rouxster70 like this.
  18. Apr 8, 2025 at 3:02 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Some people are just eat up with stupid.
  19. Apr 8, 2025 at 3:03 PM
    Can't fix stupid.
  20. Apr 8, 2025 at 3:05 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    You should jot all these pearls of wisdom down somewhere.
  21. Apr 8, 2025 at 3:13 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Same guy votes for president, right?
    WILLINH likes this.
  22. Apr 8, 2025 at 3:20 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Grain of salt for Rigger.
    Nothing wrong with magnetic spark plug sockey nor with the too many ole timey spark plug sockets I have with rubber insert. Magnetic works better for me with my 04 now a days….different strokes 4 different folks
  23. Apr 8, 2025 at 3:25 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    can we just merge all of OPs threads into one big pile of :poking: ???
    G_unit3000, ATBAV8 and Bprose like this.
  24. Apr 8, 2025 at 3:46 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I think he was referring to German torque values on your lug nuts. “ gut en tite”.
    WILLINH and whodatschrome like this.
  25. Apr 8, 2025 at 3:49 PM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    April Fool's was last Tuesday, not today.
  26. Apr 8, 2025 at 3:50 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Not even with duct tape (but it does help muffle the sound)
  27. Apr 8, 2025 at 3:59 PM
    Red Green.."Duct Tape Forever" is Oscar category....
  28. Apr 8, 2025 at 5:16 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    My 2 cents. I use a standard spark plug socket to remove the spark plugs. You know with the rubber.
    Then I pull out the rubber plug and use a piece of rubber hose that fits on top of the spark plug then thread it by hand to start the plug then with the rubber plug off I tighten up the plug.
    BlackNBlu likes this.
  29. Apr 8, 2025 at 8:13 PM
    2002 sequoia RWD
    my new thread is a completely different topic. Creating a new thread for a new topic creates a better flow for conversation and helps keep good information organized and complied for the next person who is doing research. Someone might have the same question I just asked, but if the information was in my other thread, they might end up either having a hard time finding the specific info, or just skip the thread altogether under the guise that the thread title has nothing to do with said question.
    why are you upset with people creating new threads? If you don’t enjoy the conversation you don’t have to click on it.
    not only that, but the search function on this site is terrible, and doesn’t exactly list the best information at the top, rather it just lists the most recent based on the key words they typed in the search bar.
    I genuinely don’t think you understand what the point of a forum is. If no one was aloud to ask questions that have been discussed in the past, there would eventually come a day this website would die off with no new threads ever being created, because “we’ve already discussed this just search for it”
    I love this place and enjoy my new friends, I’ll always make new threads when I have a new question because I enjoy the fresh conversation with fresh opinions and takes.
    red61cj5 likes this.
  30. Apr 8, 2025 at 8:16 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Magnetism will not occur if you get a really Good Witch Doctor to cast a spell first - then all will be Good.
    Tundra2n3 and atc250r like this.
