Pano sunroof shade issue
Discussion in '3rd Gen Tundras (2022+)' started by prosledder, Oct 25, 2022.
  1. Oct 25, 2022 at 4:38 AM
    prosledder
    prosledder [OP] New Member
    2022 Tundra Platinum
    I went to close the sunroof shade on my platinum. Shade got about halfway closed then made a terrible noise. Sounded like gears were stripping or something. Now the shade is back to wherever it’s stored. The electric motor seems to work fine and I can see two tabs in the track going forward and backward when I press the button. Pretty strange. I’ve contacted my dealer to have it looked at. I guess add this to the list. Truck had a bad battery, passenger door speaker replaced and now this. Love the truck but damn…
    Rehret likes this.
  2. Sep 12, 2024 at 8:16 PM
    Rehret
    Rehret New Member
    Thanks for your posting. I am having the same issue now. Would you mind sharing what the problem was and how they fixed it? Thank you!
  3. Sep 12, 2024 at 8:30 PM
    Hella Krusty
    Hella Krusty New Member
    " Now the shade is back to wherever it’s stored." ....it in the roof right behind the pano!
  4. Sep 12, 2024 at 9:15 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
  5. Apr 7, 2025 at 10:02 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Literally just had this exact same thing happen tonight. Shade popped off the 2 “tabs”. Any idea how they fixed it?
  6. Apr 7, 2025 at 10:25 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Not sure if this helps you guys but when I had my headliner down (suede liner) the shade is spooled up right at the back of the glass and the mechanism is held on by 2 bolts. I didn’t take a pic but it takes 10 minutes to drop the headliner and I think you’d be able to get in there and reposition it quite easily. This is if you choose not to wait for the dealer or if they want to charge you.
    2020Platinum likes this.
  7. Apr 8, 2025 at 2:01 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    10 min to drop the headliner? Maybe if you're a pro. Took me about an hour to drop it and two hours to put it back on... And it's fragile and easy to damage
  8. Apr 8, 2025 at 6:17 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    It definitely can take longer, I just popped the top of all the pillars loose then pull the console and light out of the headliner and unplugged them. Then the headliner is held up by clips and Velcro so I pulled it off front to back and slid it through the rear glass opening. Regardless, the skill involved is minimal and it can easily be pulled and reinstalled by a single person.
  9. Apr 8, 2025 at 8:32 AM
    2020Platinum
    Patrick
    Northeast PA
    ok cool, I’m definitely comfortable dropping headliner if I need to, I’m considering painting it black anyway (along with the pillars). Was just hoping there was an easy way to re-attach it to those sliding “tabs”. Thanks for the info!
  10. Apr 8, 2025 at 8:35 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'd recommend getting a suede liner and some adhesive spray. It came out really nice and the material is easy to handle.
    2020Platinum[QUOTED] likes this.
  11. Apr 8, 2025 at 8:37 AM
    Henfield
    Henfield New Member
    Adding ceramic tint to the inside of the Pano made a huge difference to comfort. I hate being mircrowaved by the sun's UV rays. Next truck is no pano for me. .
