Transmission cooler install help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundrav82019, Apr 5, 2025.
  1. Apr 5, 2025 at 11:32 AM
    Tundrav82019
    Tundrav82019 [OP] I have all the duckies
    Leo
    2019 Tundra Limited TRD Off Road
    Hello all!
    I bought the Genuine Cooler Transmission cooler, Setrab.
    I need help or resources to help install, someone to help me or a shop y’all recommend. I live in Oregon City, Oregon.
    I don’t really have any supplies to install or tools for that matter. If any one knows anyone to help me or a shop, I would very much appreciate it!
    Thank you in advance!
    Norfolk757 likes this.
  2. Apr 5, 2025 at 11:46 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
  3. Apr 5, 2025 at 12:27 PM
    Tundrav82019
    Leo
    Do you have one installed?
  4. Apr 5, 2025 at 12:29 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Yes, also have factory cooler. Used to tow in AZ summers.
    Tundrav82019[OP] likes this.
  5. Apr 5, 2025 at 12:52 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    When I lived out there my coworkers had good experiences with Mule Expedition Outfitters in Tualatin and Iron Rigs in Beaverton. I don’t know if they do engine/transmission work, you’d have to ask.
  6. Apr 5, 2025 at 1:13 PM
    Tundrav82019
    Leo
    After install how much did it lower your temps?
  7. Apr 5, 2025 at 1:15 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    No idea, no trans temp gauge.
  8. Apr 5, 2025 at 1:27 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    You could rent space here. https://gearheadgarage.us/
    In fact, when I lived in Beaverton I used this garage to self install my transmission cooler. Fishing the hard lines is much easier with the truck on a lift.
    Lucid Tundra and Tbrandt like this.
  9. Apr 5, 2025 at 5:12 PM
    Tundrav82019
    Leo
    Great idea!
  10. Apr 5, 2025 at 6:41 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Are you confident in your abilities? It’s not to bad to do but when you said you don’t have any hand tools it makes think it might be challenging for you. The most challenging part is setting the transmission fluid level after your install which takes a method of reading the pan temperature.
    Also why do you think you need one? It’s really only necessary it you tow heavy alot.
  11. Apr 5, 2025 at 6:51 PM
    Tundrav82019
    Leo
    I plan to tow a 7 k trailer often and I live in an area with lots of hills. I have a trans fluid reader and getting pan temps of 215 and 245 at the TC. That’s without towing too. I worry I’ll reach really high temps this summer and damage the transmission otherwise I guess was my thought.
    Tripleconpanna likes this.
  12. Apr 5, 2025 at 7:03 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes if you’re towing heavy consider the trans cooler. It’s unlikely you will damage the transmission without the cooler. The advantage is that you won’t have to change your transmission fluid as often. Heat degrades transmission fluid quickly. To read the trans temps properly use OBD Fusion app or the Torque app to read the pan temps. Don’t be overly concerned about the TC temps.
    So the question is, are you confident in your abilities to do the work yourself? There are some good threads on the install.
  13. Apr 5, 2025 at 7:55 PM
    Tundrav82019
    Leo
    So the pan temps matter more then?
    I definitely have the confidence to do it, just will need to dedicate a day to it and need a level area. Might borrow a friends garage and have a buddy help me.
  14. Apr 5, 2025 at 8:45 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes the pan temps is the one to watch. The TC temps fluctuate quite a bit depending if the TC is locked or not. The pan temps gives the overall temp of transmission.
  15. Apr 6, 2025 at 4:08 AM
    Jmunk
    Jmunk New Member
    2020 Tundra SR5 Crewmax
    I found installing a transmission cooler kit to be very straight forward and easy. In an effort to save a few dollars I pieced together the OEM parts needed from a dealer online and plasma cut a mounting bracket for the cooler and getting it powder coated. Lots of ways to tackle this and most all aren’t that hard. I think the biggest thing to extending the life of the transmission is to put a cooler of some kind on it.
    Turned out alot of people wanted to save money and go the DIY route so I have started selling small kits of the brackets.
    For the level area - you could always just use a jack and jackstands. It would help give you the extra room to slide around under it.
  16. Apr 6, 2025 at 5:34 AM
    yakeng
    yakeng 3URFE Apologist
    Wish a place existed near me like this.
    MadMaxCanon and Tripleconpanna like this.
  17. Apr 7, 2025 at 9:33 AM
    OhioCBtundra
    OhioCBtundra New Member
    Question for anyone that could help I installed the genuine cooling system TC a few months back and was going to add an inline magnetic filter. Which hose would I put it on (top or bottom)? Or does it matter. Pic below for reference
  18. Apr 7, 2025 at 9:54 AM
    Jmunk
    Jmunk New Member
    I have my setup so that the inlet is on the bottom fitting of the cooler. You can verify how yours is setup by feeling the hoses for the temperature difference. I really don’t think you need an inline filter but if you wanted one, I’d put it on the inlet hose of the cooler.
  19. Apr 7, 2025 at 10:32 AM
    OhioCBtundra
    Awesome big help. The inlet would be hot and outlet cold when touching I suspect. Seems the GCS is backwards on the top/bottom vs inlet/outlet orientation.
  20. Apr 7, 2025 at 11:30 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    If you have enough slack in the lines you could swap inlet & outlet, so inlet comes in on the bottom of the cooler. That way is preferred to avoid any possible air pockets getting trapped at the top of the cooler.
  21. Apr 7, 2025 at 11:41 AM
    Jmunk
    Jmunk New Member
    Yes, inlet is hot and cold is return. You want the inlet on the bottom so that as it fills up it purges air and no air is trapped in the system.
    If you have it reversed, probably not a huge issue and likely not worth rushing to swap the lines. If it’s been working fine for a while it might be fine forever.
    OhioCBtundra likes this.
  22. Apr 7, 2025 at 12:20 PM
    Gtboosted
    Gtboosted New Member
    Los Angeles
    2020 CSM Tundra 1794
    I recently installed my cooler. Got the bracket from Jmunk.
    I put a magnefine filter on the hose that feeds the cooler. I'm not really sure it's needed but it's cheap peace of mind since I swapped all atf fuid. I was worried I'd loosen up some debris with all new fluid.
  23. Apr 7, 2025 at 12:25 PM
    Gtboosted
    Los Angeles
    Op, the install is straight forward.
    Install the oem rubber hoses to the thermostat before you install it.
    The hardlines were difficult for me because the mounting tabs were not lining up to the mounting holes. I fiddled with them for 30 mins and couldn't put them on. Then I finally decided to look around and noticed the mounting bracket by the alternator is bolted in place. I backed off the bolt to give the bracket some play and was able to mount the hardlines. So if you get into the same obstacle where the holes don't line up. Move straight to backing the bolt for the bracket. I don't know why I didn't do that in the first place.
    bulldog93 likes this.
  24. Apr 7, 2025 at 1:50 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I too put a magnafine filter on the bottom hose.
    bulldog93 and OhioCBtundra like this.
  25. Apr 7, 2025 at 1:53 PM
    BrandonL812
    Brandon
  26. Apr 7, 2025 at 4:24 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I used these guys. $400. https://tualatintransmission.com/
  27. Apr 11, 2025 at 8:39 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    The line on the bottom.
    OhioCBtundra[QUOTED] likes this.
  28. Apr 11, 2025 at 11:19 PM
    Tundrav82019
    Leo
  29. Apr 12, 2025 at 3:33 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Do you have a point of contact or maybe the person's name you dealt with in case anyone from the area reaches out to these guys they'll be able to talk w/someone that's familiar w/what we're after??
    Also, at that price point, what if anything did they provide in terms of parts, fluids, etc... or was it all labor??
    Did you pre-mount the cooler or anything else prior to handing it to them??
  30. Apr 12, 2025 at 9:35 PM
    Pmac
    Pmac New Member
    The genuine one. He said it was a quality kit.
