Official Banks Power 3rd Gen Tundra Discussion
Discussion in '3rd Gen Tundras (2022+)' started by ToyFan, Sep 20, 2023.
  1. Mar 29, 2025 at 5:18 PM
    #241
    vtown76
    vtown76 New Member
    Will it show the actual gear you are in or just “D”?
  2. Mar 29, 2025 at 5:25 PM
    #242
    TacCoyote
    TacCoyote New Member
    2024 Tundra Hybrid TRD Limited CrewMax 6.5'
    Just the D.
  3. Mar 29, 2025 at 5:28 PM
    #243
    vtown76
    vtown76 New Member
    Well that’s pretty useless.
    Blufin and lapoolboy like this.
  4. Mar 29, 2025 at 6:50 PM
    #244
    TacCoyote
    @ToyFan any update to getting the gear number instead of just “D”?
    lapoolboy likes this.
  5. Mar 31, 2025 at 3:26 PM
    #245
    ToyFan
    ToyFan [OP] New Member
    Jay
    2018 Tundra
    Black Rhino Wheels
    Jay from Banks here!
    I'm excited to announce that our next wireless iDash Pro firmware update will contain the following PIDs for 2014-2021 Tundras.
    • Current Gear (In addition to PNDR, it will display 1,2,3,4,5,6. I believe iDash Pro will be one of the very few instruments to display actual gear.
    • Torque Converter Status
    • Transmission Fluid Temp
    • Engine Oil Temp
    Target date for the firmware release is the week of April 14.
    @TacCoyote
    Abell207, dadtrucklife and TacCoyote like this.
  6. Mar 31, 2025 at 3:32 PM
    #246
    TacCoyote
    What about third gen Tundras? 2022+?
    ScottieBones likes this.
  7. Mar 31, 2025 at 3:49 PM
    #247
    lapoolboy
    lapoolboy New Member
    Yes, that's great and all but this is the 3rd gen forum
  8. Mar 31, 2025 at 4:00 PM
    #248
    TacCoyote
    No need to be rude.
  9. Mar 31, 2025 at 4:01 PM
    #249
    lapoolboy
    If that's rude, then you need to toughen up.
    Woocawachie and Blufin like this.
  10. Mar 31, 2025 at 4:08 PM
    #250
    lapoolboy
    @ToyFan
    The fitment here still looks less-than-perfect. This is a recent install @TacCoyote did and so I assume the pod is new stock? If so, should be v2, correct?
    @TacCoyote, did you purchase directly from Banks?
  11. Apr 6, 2025 at 6:56 PM
    #251
    tom_w2287
    tom_w2287 New Member
    Tom
    2024 Tundra SR5
    Weatherguard toolbox, Ranchhand grille guard
    Any update to the monster exhaust and ram-air intakes?
  12. Apr 7, 2025 at 8:06 AM
    #252
    ToyFan
    Jay
    2018 Tundra
    Black Rhino Wheels
    Monster-Exhaust is indeed in development. Unfortunately, I don't have an update on the Ram-Air intake.
  13. Apr 7, 2025 at 8:08 AM
    #253
    ToyFan
    Jay
    2018 Tundra
    Black Rhino Wheels
    I will as our Firmware team if actual gear is currently displayed in '22+ Tundras. If it isn't, I'll ensure that it's added in an upcoming firmware update. Stand by...
  14. Apr 7, 2025 at 8:33 AM
    #254
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Is this an update for existing iDash models or a new release?
  15. Apr 7, 2025 at 8:59 AM
    #255
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
  16. Apr 7, 2025 at 9:20 AM
    #256
    ToyFan
    Jay
    2018 Tundra
    Black Rhino Wheels
    The firmware update will be for the iDash Pro, which was released last month. If you're interested in upgrading, please see this link.
  17. Apr 7, 2025 at 9:22 AM
    #257
    ToyFan
    Jay
    2018 Tundra
    Black Rhino Wheels
    Selected Gear (1,2,3,4,5,6) on 2014-2021 will be included in the iDash Pro firmware release this month. This firmware will come wirelessly. Once you connect the Banks mobile app to the iDash, it will prompt you to update.
  18. Apr 7, 2025 at 9:22 AM
    #258
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Thanks, submitted...
  19. Apr 7, 2025 at 10:28 AM
    #259
    Lord Helmet
    Lord Helmet New Member
    So it begins.... the mods :rofl:
  20. Apr 7, 2025 at 8:49 PM
    #260
    Rogue556
    Rogue556 New Member
    Evan
    2023 Lexus GX460
    This isn't Tundra specific, but this is an option that I think would work in just about any vehicle that utilizes a dash mount and 1"/20mm ball mounts made by companies like 67 Designs, Ram, Bullet Point, Tackform, etc. It's a solid option for those who don't want to or can't mount their gauge to the A-pillar location.
    I started with a universal 52mm single gauge pod made by Glow Shift (Part #GS-U01B). It's under $20 on Amazon, and the metal construction allows you to bolt a ball mount directly to the back of the pod without issue. The lowest profile ball mount I could find was the 20mm Tackform TF-AR-33. It has a center hole for a 1/4 or 6mm socket head cap screw. The Tackform 20mm ball was $10 on Amazon. Other than that, I added a large fender washer on the inside of the pod and sandwiched a rubber washer of the same size in between the fender washer and pod to keep noise/vibration under control. (The pod also comes with a concave washer for the outside of the pod, as well as an L bracket. You don't need the L bracket but do need the provided concave washer). I added another large rubber washer between the provided concave washer and body of the pod on the outside as well and then added another two rubber washers between the 20mm Tackform ball and the concave washer.
    Other than that, the Banks idash Pro has an outside diameter that is just slightly too small to fit snuggly inside of the gauge pod, so I had to make up that extra space. I had an assortment of Ranger Band branded heavy duty rubber bands (UPC 616450871543) I purchased off of Amazon and used two of the 2" bands around the outside diameter of the idash gauge body. It now fits VERY snug in the gauge pod and isn't going anywhere.
    I searched everywhere to find a gauge pod that would mount to the common Ram style ball mounts that are everywhere these days and was surprised to not find a single option available anywhere, so was forced to make my own. If others like this setup, maybe @ToyFan can convince his guys over at Banks to make their own version?
  21. Apr 8, 2025 at 4:04 AM
    #261
    Daedalus
    Daedalus New Member
    My guy broke out the real camera for these shots...crispy!
    4mm likes this.
  22. Apr 9, 2025 at 7:15 PM
    #262
    sudobash
    sudobash New Member
    @ToyFan - ?
  23. Apr 9, 2025 at 7:17 PM
    #263
    lapoolboy
    Yes.... @ToyFan ???
    sudobash likes this.
  24. Apr 12, 2025 at 7:38 AM
    #264
    lapoolboy
  25. Apr 22, 2025 at 9:44 AM
    #265
    Daedalus
    Daedalus New Member
    @ToyFan
    There seems to be a lot of interest in Banks moving into the intake realm...I'd like to keep my OEM MAF placement and operation, and a lot of the others seem to move or stick it in a larger plenum....which according to Gale is a big no no.
  26. Apr 22, 2025 at 10:13 AM
    #266
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    It's too bad you don't have anything you can run off a head unit.
    matth66 likes this.
  27. Apr 22, 2025 at 6:21 PM
    #267
    saleen079
    saleen079 New Member
    22 Tundra Limited TRD
    Lots of DIY stuff
    It's been a while since I've been on the forum. Unfortunately, I traded my 22 Tundra in for the wife's new 4runner trd pro, but I took the Banks pedal Monster off before we took it in. If anyone is interested, I'll take $175 for it, and I'll take care of shipping. It made a world of difference with the throttle lag. I ran it for about 2000 miles before taking bit off. PM me if anyone has any questions.
  28. Apr 23, 2025 at 6:58 AM
    #268
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    This is what I’ve been saying. They have an app. It seems to be just one more step
  29. Jun 9, 2025 at 3:07 PM
    #269
    223Wylde
    223Wylde New Member
    Jeff
    Cottage Grove, MN
    2023 Tundra TRD Pro MGM
    Anyone here with a 3rd Gen Tundra upgrade to the iDash Pro? I'm just wondering if it now displays trans gear 1,2,3 etc, not just "D".
    Taikowaza and lapoolboy like this.
  30. Jun 9, 2025 at 3:16 PM
    #270
    TacCoyote
    I have and it still says just D but there is a new firmware update that I haven't done yet. Lemme go install it and I'll let you know.
    Taikowaza and 223Wylde[QUOTED] like this.
