Welcome to Tundras.com!
Quick Links:Hellwig 991 helper spring makes clunking noise
2002 Dies after it warms up. Compression codes on one side only (driver's).
Cheap Fix for a Plastic Gas Tank Vent Pipe with a Few Small Holes???
1st gen worse MPG. What could be the Problem?
05 Limited slip differential fluid change
Stupid interior trim question (door handle trim replacement)
Need some help on a value of a 2003
Discussion in '1st Gen Tundras (2000-2006)' started by OkieMike911!, Apr 7, 2025.
