Code P1128 - Paper Towel Destruction
Discussion in '1st Gen Tundras (2000-2006)' started by evanhmn, Apr 6, 2025.
  1. Apr 6, 2025 at 12:49 PM
    evanhmn
    evanhmn [OP] mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    Hi all,
    Made a big oopsie when wrenching on my truck this weekend. Had to replace the tensioner pulley assembly as the bolt head snapped off. Got it all put together and she ran good - I'll be doing a write up on this job actually. HOWEVER, it looks like when my old man and I were putting the air intake back on between the intake box and throttle body, we forgot to take out the paper towels that we stuck in the throttle body to prevent stuff from getting in.
    The truck turned on today, and died about a half a block from home. We pushed it back into my driveway. I had a feeling it was something in the intake because it was almost as if the truck wasn't getting air to go kaboom. I took the intake tube off, and our stuffed paper towels were still right where we put them in the throttle body. I played a fun game of doctor, and it looks like about a 1/3 of a paper towel is missing(just regular paper towel, not cloth) - presumably inside the engine. Just wondering if yall have any advice on this rookie move of ours. The truck is throwing a P1128 code, and it turns on, but then dies just about instantly. I'm guessing the paper towel is stuck somewhere. I ordered an endoscope, which will be here tomorrow, to see if I can peek inside.
    Heeeeelp meeee I can't believe we fudged up like this lol
  2. Apr 6, 2025 at 1:13 PM
    centex
    centex New Member
    Pop the throttle body off and make sure nothing is jammed in it. Then clear the code and see if it’ll start. An actual paper towel will be shredded and burned up rapidly in an engine and won’t cause any damage. The cloth ones will mess stuff up.
    evanhmn[OP] and joseph_womack like this.
  3. Apr 6, 2025 at 1:15 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    get an intake gasket and pull the intake, see if theres paper towel in the valves or blocking a valve; that code is for Bank 1 so check that side first
  4. Apr 6, 2025 at 1:17 PM
    joseph_womack
    Joe
    Louisiana
    yeah need a little clarification here @evanhmn yall put the paper towels in front of the closed throttle body? Meaning on the outside of it and not inside the intake? Or did you open the TB and stuff them under it?
    But regardless if you haven't already unbolted the TB, do that first and see if there is a piece behind it; if not its time to pull the intake
  5. Apr 6, 2025 at 1:17 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Check the throttle control motor. Some of the paper may have it jammed.
    joseph_womack likes this.
  6. Apr 6, 2025 at 5:07 PM
    evanhmn
    State of Taxes
    The paper towel was placed in front of the closed throttle body. We pulled the air intake hose to gain better access to the pulleys and just put the paper towels there to ensure nothing got in there while we were wrenching. I'd be real nuts for opening it and stuffing towels INSIDE it lol :D
  7. Apr 6, 2025 at 5:48 PM
    Why do you need a paper towel in front of a CLOSED throttle body?
  8. Apr 8, 2025 at 10:05 PM
    evanhmn
    State of Taxes
    Got myself a $20 endoscope on Amazon to check it all out - didn't see squat. And welp, she started up this morning, musta had a paper towel for breakfast, and kept on chugging along. Went easy on the gas and drove around town for a bit before returning twice just to do a smell test and look things over, all good. Drove about 25 miles with no issue. No light, no nothing. Perhaps I will feed the ol beast one paper towel a year to please her.
    Randy Morton and centex[QUOTED] like this.
  9. Apr 8, 2025 at 10:06 PM
    evanhmn
    State of Taxes
    Stupid, looking back on it. BUT, my old man sat a socket down in it and I just knew I needed to create a barrier. NEVER AGAIN AHHH
    KNABORES[QUOTED] likes this.
  10. Apr 9, 2025 at 4:26 AM
    centex
    centex New Member
    Not stupid. Good practice. I do the same thing.
