Tire Size Running Into Issues
Discussion in 'Wheels & Tires' started by MikroT, Apr 5, 2025.
  1. Apr 5, 2025 at 7:33 PM
    MikroT
    MikroT [OP] New Member
    Dom
    2024 Tundra Hybrid
    Planning to get a spare set of tires soon, so I'm wondering what tire size diameter owners have reported that they will start running into issues?
    ...edited, to include that I will probably be putting these on 17" wheels.
    Current plans:
    • Maintain stock height - no TRD height or anything. Just limited trim height
    • Thinking 17" wheels, ~ 0mm offset, 4.5-5" backspacing, and around 8.5 inches in width.
    • Wrapped in something like 285-290/70-80/R17s.
  2. Apr 6, 2025 at 5:32 AM
    Observer
    Observer New Member
    I suspect your question will get bumped to the wheels and tire thread https://www.tundras.com/threads/gen-3-2022-wheels-and-tires-photo-thread.101215/ but from what I have seen 34" tire will fit without rub on stock suspension at full turn. Keep in mind also the width. Seen a few post that state 275/65/r20 will fit on stock if that's the rim your running. Best thing is to just go into the wheels and tire thread. Pay mind while looking to see if they have added a lift or not.
    Blufin, BlackNBlu and Raven67 like this.
  3. Apr 6, 2025 at 8:12 AM
    MikroT
    Dom
    2024 Tundra Hybrid
    Thanks for referring me to that thread!
  4. Apr 6, 2025 at 8:25 AM
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    lot's of variables - and your year/ model and spec will allow others to share more.... stock wheels ? Stock height etc... plans for use- mall cruiser or hard core etc..
    Observer likes this.
  5. Apr 6, 2025 at 10:02 AM
    Crowmag
    Crowmag New Member
    2025 Limited TRD OR W/TRD 3" Lift
    True there's a ton of variables. Wheel type/offset, aggressiveness of tires even if they are the "same size". I just put on 275/65R20 Falken Wildpeak AT4W's on OEM wheels and they fit very well. Oddly on a full right hand turn with some speed, these tires ever so slightly rub the drivers side sway bar. For me on stock OEM wheels, 34" tires are they way to go. Unless you have offset wheels, 35" and larger tires will most likely rub and require trimming, especially on OEM wheels.
    Post #9366
    https://www.tundras.com/threads/what-have-you-done-to-your-3rd-gen-tundra-today.104778/page-313
    Saltyhero13 likes this.
  6. Apr 6, 2025 at 3:24 PM
    MikroT
    Dom
    2024 Tundra Hybrid
    @Crowmag Honestly, I was thinking something something close to stock, or just slightly over the stock diameter (32.5") - for added purposes of comfort, and some off road trekking.
    As it stands, I've decided on the following to keep it safe on fitment and options: 17" wheels, ~ 0mm offset, 4.5-5" backspacing, and around 8.5 inches in width.
    Now for the tires, I could just wrap the wheels in something close to stock size, but I was wondering what the limits were on 3rd gen tundras; by the looks of it it seems like it is the sway bar... guess I'll just have to find out myself. :militarypress:
    @SnowToy stock height for now...
  7. Apr 6, 2025 at 4:16 PM
    Crowmag
    Crowmag New Member
    Maybe Toyo Open County AT3? A little heavier than stock and I've heard they are decently quiet. LT255/80R17
    https://www.toyotires.com/product/o...XItxaxpXiXicVHLslQyNi_WB7SmC_1-RoC0voQAvD_BwE
