Winch bumper lights Gen 3 using factory wiring
Discussion in 'Lighting' started by Over the LINE, Apr 6, 2025.
  1. Apr 6, 2025 at 8:14 AM
    Over the LINE
    Over the LINE [OP] New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I am planning my winch bumper install. I assume I can cut and splice my new fog lights to use the factory switch on the turn signal used for the circled lights.
    For my light bar, is there a way to add the TRD light bar switch and use it like factory? What I mean is tied to the high beams? At least i think it is tied to the high beams based on my owners manual reading. My assumption is the switch wiring is in the dash and in the harmess to the grill connection. I also assume the grill harnesses are specific and therefore there is no wire in the grill for the light bar. Can anyone confirm my assumptions and point me to the correct harness plug and which pins to accomplish this? 20250402_091530.jpg
  2. Apr 6, 2025 at 12:16 PM
    Over the LINE
    New Orleans
    Wow was I wrong. I searched TRD grill and light bar swaps and found the info I was looking for. It's been 10 years since I built my Gen 2.5. This 2025 truck is turning out to be a lot harder to deal with.
