2002 Sequoia battery drain
Discussion in 'Sequoia 1st Gen (2001-2007)' started by Lifer, Dec 28, 2023.
  1. Dec 28, 2023 at 6:46 AM
    Lifer
    Lifer [OP] New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    I do not have this truck at my location first off, it is down at my kids' house a couple hours away.
    First I heard of a problem I checked battery and it was 7 volts. It had just gotten cold and AAA battery was at 3 years so I put a new one in checked with my fluke that it was indeed charging and called it good.
    I should have test drove it because it did the same thing to my son again, actually died after losing power. When I got back down there the battery had recovered? I even charged the AAA battery and it is good.
    No codes at all and factory alarm but what I found happening is, the truck will begin discharging after it is warm? I have no idea if an alternator is capable of that?
    Ideas or experiences?
  2. Jan 2, 2024 at 6:55 AM
    Lifer
    Vince
    Nobody?:sadviolin:
  3. Jan 2, 2024 at 7:33 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    On my moms old sequoia while chasing a battery drain i found it by removing the radio fuse.
    Lifer[OP] likes this.
  4. Apr 6, 2025 at 9:29 AM
    Gobirds25
    Gobirds25 New Member
    Tom
    2001 Sequoia
    I have 2001 sequoia. Truck needs to be started every other day. Significant Battery draw, I used a 12v bulb in series with positive battery cable, which lights up to point where i can't hold it after a few minutes but not to the point where the bulb blows. Pulled all fuses in fuse boxes under hood. Only "fuse" which stopped current draw was the short fuse. Which took out radio, door locks and dome lights and chimes. Could not fine actual fuse to stop power draw? Does any on have electrical for 2001 sequoia?
