  1. Apr 5, 2025 at 5:25 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    23Tundy, Jbehredt, Velocity72 and 9 others like this.
  2. Apr 5, 2025 at 5:54 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I like those kind of things. Have one myself. In fact I need to check it's charge.
    Rabidllamas likes this.
  3. Apr 5, 2025 at 5:57 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    That's not an OEM one, right? If not which is it?
    Corndog123 likes this.
  4. Apr 5, 2025 at 5:58 AM
    Corndog123
    Sam
    Tennessee
    Mine is the TRD.
    Xcumminsguy likes this.
  5. Apr 5, 2025 at 7:57 AM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Will this fit if I have a lift? Coachbuilder +3 and a 1” block. Thanks
  6. Apr 5, 2025 at 8:46 AM
    1794TX
    Steven
    N.TX
    '20 1794
    You'll need new links. I'm sure there are others out there, but as an example:
    BDS Suspension ⚡
    BR73 likes this.
  7. Apr 5, 2025 at 9:20 AM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    Realized there's these storage spots on the underside of console lid, found a good use for the tissue holder
  8. Apr 5, 2025 at 9:23 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    That's what I use that for too :thumbsup:
  9. Apr 5, 2025 at 9:27 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Roof is actually what pushes a deadening project firmly into wild.
    woods and bulldog93 like this.
  10. Apr 5, 2025 at 9:56 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I noticed a huge difference after I did the roof. Mostly in road/wind noise. Still gotta do the floor one day.
  11. Apr 5, 2025 at 11:27 AM
    SAGE63
    San Diego County
    I put my winch remote in there
  12. Apr 5, 2025 at 1:34 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Playing around with some of the pid’s and getting some gauges set up, mainly so I can monitor my transmission temps while towing and changing fluid. Crazy how many things you can see live on data with this thing.
  13. Apr 5, 2025 at 1:49 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I hope all the work will be worth it in the end for me. It is quite a task. I think i need more dynaliners. Already used 1 roll (12sqft) for the roof. 1 more for the back wall. Ordered 5. I dont think it’ll be enough for floor AND doors. Was reading that the doors need 20sqft. So that’s gonna be 2 rolls. One for the front doors and one for the rear doors.
  14. Apr 5, 2025 at 1:58 PM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    atc250r[QUOTED], HulkSmurf14 and BR73 like this.
  15. Apr 5, 2025 at 1:59 PM
    BlueRibbon4x4
    Geno
    Maybe one more roll to take care of the floor in two rolls. Just a guess though. I did mine in pieces, and noticed a difference each time. Just the rear wall, then the doors, then the roof. The roof being the most noticeable. If you’re doing it all at once, you’ll definitely be happier with the results.
  16. Apr 5, 2025 at 2:05 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    atc250r and TheMuffinMan[QUOTED] like this.
  17. Apr 5, 2025 at 2:22 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    I put tissue in there. Weird huh?
    Florida AF, 23Tundy, Jbehredt and 4 others like this.
  18. Apr 5, 2025 at 3:45 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    One more door down, one left to go. I'm a touch OCD so it took me a little over 2.5 hours to do both inner door skin and outer.
  19. Apr 5, 2025 at 3:53 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Is that an OEM speaker?
    Tripleconpanna likes this.
  20. Apr 5, 2025 at 3:54 PM
    BrandonL812
    Brandon
    Sure look like it. He better. Swap them out while he’s there now. Save some time.
  21. Apr 5, 2025 at 3:55 PM
    BrandonL812
    Brandon
    Complete coverage. I like it. Doors will be my last.
  22. Apr 5, 2025 at 5:12 PM
    jmdaniel
    Leander, TX
    Swapping speakers takes no time at all.
  23. Apr 5, 2025 at 5:13 PM
    BrandonL812
    Brandon
    Yup. But since he got the panel off already. This is the time yo do it. Cuz later he would need to pop the panel and get back in.
  24. Apr 5, 2025 at 5:15 PM
    BrandonL812
    Brandon
    Back wall is finished. Just need to peel and stick.
    Florida AF, woods, bulldog93 and 2 others like this.
  25. Apr 5, 2025 at 5:45 PM
    justcuz
    justcuz 2.5 Gen Member
    finished the wax application with my DA buffer/polisher. IMG_0272.jpg
  26. Apr 5, 2025 at 6:46 PM
    00h2itr
    00h2itr New Member
    Carolina's
    Yes, JBL system in a '21 Limited.
  27. Apr 5, 2025 at 6:48 PM
    00h2itr
    00h2itr New Member
    Carolina's
    Very noticeable difference if you tap the door with and without deadening. Glad I did the inner as well as outer.
  28. Apr 5, 2025 at 6:58 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    Get a rice of black heat shrink from HD and put it in the shifter good idea
  29. Apr 5, 2025 at 8:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Making my way to Vegas. Stopped in Reno to chat with a buddy and brainstorm the next phase
  30. Apr 5, 2025 at 11:09 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    IRS / 4-link time?
