Let's see 1st gen with Toyota Rims
Discussion in '1st Gen Tundras (2000-2006)' started by Lupe, Feb 19, 2019.
  1. Nov 1, 2024 at 2:57 PM
    #1051
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Yeah these look phenomenal
    G_unit3000 likes this.
  2. Nov 1, 2024 at 3:11 PM
    #1052
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    These look like 2nd Gen Rock warriors? Maybe a look alike? Adapters? Or 2nd Gen hubs? Did Toyota ever make 6 lug rock warriors? Aside from the Tacoma/FJ wheels @rrod just posted
  3. Nov 14, 2024 at 4:58 PM
    #1053
    daveeasa
    OK, now that I have my studded tires on T4R wheels, I need a set of lug nuts. Anyone know the best option? Overpay for OEM?
    I run the faux beadlocks with my summer tires. I might be able to just re-use those? But it might be nice to have non-locking lug nuts on the snows since they are studded so I'm more likely to swap 'em out on an as-needed basis?
  4. Nov 18, 2024 at 12:11 PM
    #1054
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Look on craigslist and marketplace for people selling OEM wheels, 9 times outta 10 they got a box of stock lug nuts they will sell for $20
    I have 2 or 3 sets of OEM lug nuts that i never paid for. Normally people will give them to you to get them out of their way.
    Tlar25 likes this.
  5. Nov 18, 2024 at 12:26 PM
    #1055
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Hmm, these do look good and it gives me an idea.
  6. Nov 18, 2024 at 12:44 PM
    #1056
    What lug nut you need depends on the seat inside the hole. Will the lug nut rest agaist a flat surface, or is it a conical seat?
    If conical, that's the type of nut you need. If flat, you need lugs with flats. Granted, with steelies you need a slightly different, but that's clearly an alloy wheel.
  7. Nov 18, 2024 at 4:25 PM
    #1057
    daveeasa
    I actually have a set of 22mm acorns from when I ran snows on steelies back in the day. I still have a steelie spare on the '05, so I keep the acorns around for that guy. I know the OEM ones work fine in a pinch but kinda like having the right nuts, nomesame?
    I think I want new OEM but looks like $100+ for 24 of those, hmm.
    i have enough spares to get them mounted up but just wanted a nice new set. The blacks are the nicest of my spares but I think they will clash.
  8. Nov 18, 2024 at 4:26 PM
    #1058
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    FYI:
    Conical aftermarket for us, or if using different mfg wheels.
    Mag is OEM.
    Ball seat is Honda OEM.
  9. Nov 18, 2024 at 4:37 PM
    #1059
    daveeasa
    I'm no expert but I do own 7 sets of Toyota wheels (owned 8 till a little while ago) and they are all mag nuts. Which is standard FGT/Tacoma lugs till the 14MM stuff in recent times, yeah?
    Just kinda want a nice new set of OEM quality silvers I think, gotta decide if I'm gonna drop real money or just go aftermarket?
  10. Nov 18, 2024 at 4:39 PM
    #1060
    You need the middle one in @assassin10000’s pic. Mag seat.
  11. Nov 18, 2024 at 4:42 PM
    #1061
    daveeasa
    I know this, I am not as dumb as I look :)
    The q's are part numbers / where to buy (dealer?) / oem vs aftermarket and I have both so I know OEM comes in both short and long.
    Seems like everyone DGAF's on these?
  12. Nov 18, 2024 at 4:45 PM
    #1062
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I'd probably just get dorman replacements. 712306
    daveeasa[QUOTED] likes this.
  13. Dec 8, 2024 at 8:19 AM
    #1063
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
  14. Dec 8, 2024 at 1:21 PM
    #1064
    daveeasa
    I ended up finding some OEM takeoffs on eBay. I think 10 for $30 or so? I guess some dealerships like to take the OEM wheels off and throw on aftermarket ones to charge more?
  15. Dec 9, 2024 at 7:01 PM
    #1065
    bdbrown528
    bdbrown528 New Member
    2002 Tundra Sr5
    When my Tacoma got totaled I made sure to rescue my Trail Edition wheels. Finally got around to putting them on the Tundra.
    New Wildpeaks going on later this week
  16. Jan 9, 2025 at 4:57 AM
    #1066
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    17” trd gloss gunmetal with 275/70/17 Toyo open country AT3s
    abcinv, j_supra, PNW15 and 5 others like this.
  17. Jan 9, 2025 at 7:24 AM
    #1067
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    My 4runner had a sidewall puncture so it got a new set of tires. I swapped the TRD pro wheels from my Tundra at the same time. These are early 5th Gen 4runner trail edition wheels with 285/75r17 toyo r/t's
    abcinv, G_unit3000, Mustanley and 3 others like this.
  18. Jan 9, 2025 at 9:08 AM
    #1068
    Tlar25
    Tlar25 New Member
    2006 DC SR5 4x4
    Pictures I saw on Craigslist (?) of a 1st Gen on GX470 wheels
    StratusDuo and 455h0le_dachshund like this.
  19. Jan 9, 2025 at 10:47 AM
    #1069
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I think assdog is running those on his T3
  20. Jan 9, 2025 at 10:54 AM
    #1070
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  21. Jan 9, 2025 at 11:32 AM
    #1071
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Those RT’s were tempting, but I ended up going AT3. The RTs are the only sl/xl 275/70/17. But they’re pretty luggy for my use…
    Tlar25[QUOTED] likes this.
  22. Apr 4, 2025 at 3:33 PM
    #1072
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Going to look at and hopefully take home these wheels tomorrow. I'm not sure if these are from a taco or a 4 runner and I don't think the seller knows (they don't speak English either). They're selling for $200, in case they dont have the lug nuts, and if anyone can ID what these came off from looking, will my OEM acorn lug nuts on OEM patrick style wheels work?
    Also, anything else I should know or look for when going to check out in person based on whats observed in these pics?
    Tlar25, The Black Mamba and KNABORES like this.
  23. Apr 4, 2025 at 5:43 PM
    #1073
    Probably not acorns.
    You will know based on what you see on the wheels. If it is alloy and the inside edge is flat you need these, the lug nuts with the flat spinny washer part. Is that what the starfish use?
  24. Apr 4, 2025 at 9:59 PM
    #1074
    Lupe
    Lupe [OP] New Member
    Lupe
    2006 Tundra
    The tacomas and the FJ Cruiser had these wheels if I am correct.
    Tlar25 and Dblock500[QUOTED] like this.
  25. Apr 4, 2025 at 10:50 PM
    #1075
    Dblock500
    DMV
    Yessir, those look like what i currently have
  26. Apr 5, 2025 at 5:49 AM
    #1076
    The Black Mamba
    DFW
    Imma keep it stock
    Yes. The mating surface is flat, just as your Patrick lugs are flat. Here's a link to the black ones I'm running https://a.co/d/hjcJg80
    Dblock500[QUOTED] likes this.
  27. Apr 5, 2025 at 6:32 AM
    #1077
    Dblock500
    DMV
    Cool, thank you. On my way to check them out now
  28. Apr 5, 2025 at 6:52 AM
    #1078
    taranovich92
    taranovich92 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Yokohama Geolander AT 285/70/17, Apple CarPlay, CB radio, Firestik hood mount antenna, Randy Ellis Design front bar, Hella 500 rally lights, Hella horn, Mini LED projector headlights, Trailrunner Customs fogs.
  29. Apr 5, 2025 at 7:01 AM
    #1079
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Do these count as Toyota reeeims?
    Lupe[OP], Tlar25, G_unit3000 and 2 others like this.
  30. Apr 5, 2025 at 7:03 AM
    #1080
    The Black Mamba
    DFW
    Imma keep it stock
