Bushwacker OEM smooth style flares
Discussion in '2.5 Gen Tundras (2014-2021)' started by Javelin, Mar 27, 2019.
  1. Feb 14, 2022 at 10:08 AM
    #61
    Tundra805
    Tundra805 Quality. Durability. Reliability.
    Tennessee
    2020 CrewMax SR5 TRD 4x4 5.7 Cement
    Hey y'all, got my OE style Bushwacker fender flares installed over the weekend. Great quality. Very satisfied with the fitment. 100% perfect? No. I did have to bust out the Dremel it a couple spots. I added 1" clear 3M paint protection under each one after hearing how important it is from another member here. The raw finish is good, not super texturey and not glossy either.
    Tips:
    Follow the directions. They aren't the most thorough but still very helpful.
    Install on a hot day, the flares are easier to work with when warm, a heat gun is your friend.
    Be prepared to Dremel / file / shave a little here and there in tight spots.
    After removing a few screws, loosely mount a flare with one or two screws and use some tape to outline where paint protection film should go (see pic).
    The rubber seal trim is tricky, be patient, make sure the flare edge sits IN the rubber seal. I had only a few inches left over.
    The curve around the gas door is the trickiest spot. Make sure you really bend/arch the seal into place or it ends up not laying flat against the body.
    Fender flares protect my fenders from gravel damage – my mud flaps protect your windshield from gravel damage.
    :oldglory:
  2. Feb 16, 2022 at 4:28 PM
    #62
    CanTundra
    CanTundra New Member
    2021 Tundra TRD Off Road
    nice . how much higher did you go with the clear tape ? 1/8"?
    I have to still work on mine. I am going to test fit, them paint then re install. I hope it goes smooth
  3. Feb 16, 2022 at 8:11 PM
    #63
    VadersTundy
    VadersTundy New Member
    2019 black sr5 crewmax
  4. Feb 19, 2022 at 4:50 PM
    #64
    CanTundra
    Did you have to trim mud flaps openings?
    Nice tundra btw looks cool
    Tundra805 likes this.
  5. Feb 20, 2022 at 10:20 AM
    #65
    VadersTundy
    thanks! Nope no trimming necessary
  6. Aug 19, 2023 at 6:20 PM
    #66
    bengston11
    bengston11 New Member
    2020 Crewcab Sport 4x4
    Stock, for now.
    What size lift/ tire area you running? 295-70? It looks perfect with those flares! I have FNBFD in my garage but I'm back and forth on tire size since i want to run a modest fender flare as well. Im looking to you for inspiration haha
  7. Aug 19, 2023 at 7:21 PM
    #67
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    I have not had the tundra for a while now. But I am still running
    Bushwacker OE
    ZappBrannigan likes this.
  8. Aug 22, 2023 at 6:16 PM
    #68
    intr3nsic
    intr3nsic New Member
    This truck is beautiful. Can you link me to the part number for the flares?
  9. Mar 31, 2025 at 8:09 AM
    #69
    textundra12
    textundra12 New Member
    How did you get your FNW center caps to fit flush?
  10. Apr 3, 2025 at 7:39 PM
    #70
    textundra12
    What did the color match painting cost you
  11. Apr 4, 2025 at 12:27 PM
    #71
    Echo5Golf
    Echo5Golf New Member
    Phil
    Tundra Hunter
    This truck..! In 1792 is my dream ride! Wow…
  12. Apr 4, 2025 at 1:08 PM
    #72
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    That is a nice looking truck!!! AND its the right color
