Rear Brake Adjustment FSM doesn't make sense
Discussion in '1st Gen Tundras (2000-2006)' started by Dblock500, Mar 26, 2025.
  1. Apr 4, 2025 at 8:01 AM
    Dblock500
    Dblock500 [OP] New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    I saw that, and haha yeah I'm probably going to start including that when I start my routine as well. Greasing the driveshaft has helped but actually getting tires that are the same size as the rear (some reason the PO put different sizes on the front) has made my ride silky smooth. I plan on doing a rear diff fluid change today or tomorrow.
    The Black Mamba likes this.
  2. Apr 4, 2025 at 8:04 AM
    Dblock500
    DMV
    Too low = as in too many clicks? Mine is within the recommended range 5-9 (or whatever it is) for now
  3. Apr 4, 2025 at 8:55 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Yes.
  4. Apr 4, 2025 at 9:11 AM
    14crwmaxltd
    14crwmaxltd New Member
    T.
    2014 crewmax 4x4 Limited
    Leer cap
    After 45 years of screwing around with cars, I can tell you that there is nothing better than a mayonase jar, tube, and brake bleeder fitting for solving bleeding problems.
    That tube, suspended vertically above either the wheel cyl, or caliper, will allow you gauge the air content, and prevent backflow of air into the bleeder when doing a flush, or bleeding procedure.
