No rear brakes after rebuild wth??
Discussion in '1st Gen Tundras (2000-2006)' started by Dracko, Apr 2, 2025.
  1. Apr 2, 2025 at 10:09 AM
    Dracko
    Dracko [OP] New Member
    2005 Tundra SR5
    I just replaced my wheel cylinders, rear brake shoes and had the drums turned. I also replaced the bell crank kits. We've bled the system. I adjusted the bellcranks so theres 1mm of play, adjusted the park brake cable to theres no slack. When the e brake cable is pushed down it clicks 8-10 times and the cable is really tight, e brake works.
    YET when i push the brake pedal i have no rear brakes at all. With the drums off, we push the brake pedal and the wheel cylinders don't even expand at all. Very perplexing because we bled the system and have clean brake fluid at the rear cylinders. Truck on jack stands rear wheels just keep spinning while i have the pedal to the floor. What the heck??
  2. Apr 2, 2025 at 10:25 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    First off, you should place something behind the brake pedal to protect the seals in the master cylinder if you are literally pushing the brake pedal to floor. A brick or small piece of wood should suffice.
    Sounds like there is air in the system. Did you bleed the LSPV (above rear axle) in addition to the drums?
    ATBAV8 likes this.
  3. Apr 2, 2025 at 10:26 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If you haven't already, I'd crawl underneath and take a look at your parking brake lever and see if theirs slop.
  4. Apr 2, 2025 at 10:29 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Two questions for ya, both have to do with the LSPV (Load Sensing Proportioning Valve):
    Did you bleed the LSPV when bleeding the brakes?
    Are the jack stands supporting the axle, or the frame?
    If you’re not familiar with the LSPV, it is the contraption mounted to the frame above the axle, it has a rod going between it and the axle. It’s job is to increase rear brake pressure when hauling or towing heavy loads.
    Bleeding it is an important step, as it is a high point in the system and will trap air bubbles. Also, if you have the truck supported by the frame, and the axle is at full droop, it might be cutting off fluid to the rear brakes.
  5. Apr 2, 2025 at 10:31 AM
    Dracko
    2005 Tundra SR5
    thanks, I did bleed the LSPV . Maybe we'll do some more rounds of bleeding. We aren't pushing it right to the floor when bleeding. But I had to to get the wheels to stop spinning so i could put it back in P. Hope I didnt damage anything.
    I did adjust the E brake cable adjuster underneath, there is no slack
    What is the 8mm bleeder behind the master cylinder?
  6. Apr 2, 2025 at 10:34 AM
    Dracko
    2005 Tundra SR5
    OK we'll bleed some more over here. Bleed the LSPV first this time.
    the truck stands are under the axle in the rear.
    crazy how theres no pressure going to the rear cylinders when the pedal is pushed.
  7. Apr 2, 2025 at 10:35 AM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    I pedal bled for 20 years, I then bought a motive power bleeder. Made my own adapters for Toyota and gm a bodies. Mostly I just use the air pressure without fluid in the unit, but it’s so easy to fill the jug with Blake fluid and flush the entire system. Best to ya
    tvpierce and Dracko[OP] like this.
  8. Apr 2, 2025 at 10:36 AM
    FiatRunner
    Jack
    Yeah, it is pretty crazy how little the rear brakes do with the truck fully unloaded. You can simulate load and increase the rear breaking power by adjusting the LSPV arm on the axle side. Moving it upwards towards the bed will increase pressure.
  9. Apr 2, 2025 at 10:59 AM
    Dracko
    2005 Tundra SR5
    we just bled it again. getting nothing but fluid out of all bleeders including LSPV. the rear cylinders just aren't getting enough pressure. Can't even stop the drums spinning while in Drive. Dads been a mechanic for a couple decades and is perplexed.
  10. Apr 2, 2025 at 11:08 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    We need pics, man. You'll need to remove the drums and get us pics to assist. Otherwise, we're all just going to guess and you'll be running around chasing your tail.
  11. Apr 2, 2025 at 11:24 AM
    rouxster70
    04ac2wdv65spd
    Are the star adjusters positioned correctly on the shoes? When the shoes are positioned correctly they rub the drums barely.
    Weagle likes this.
  12. Apr 2, 2025 at 12:45 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    What the hell kind of bleeding operation are you doing? I have never once, nor heard of, putting the vehicle in drive while the engine is running to bleed brakes in over 40 years of wrenching on all kinds of vehicles.
  13. Apr 2, 2025 at 12:47 PM
    ATBAV8
    Tempe, AZ
  14. Apr 2, 2025 at 12:54 PM
    rouxster70
    04ac2wdv65spd
    On vehicles with abs, I’ll often turn the key to acc and or start to bleed the the abs “block”.
    I only run vehicles on stands if looking for problems with drivetrain or bearings. SUPER CAREFUL!!!! Triple check your stands, pray hard, do good deeds for karma.
    noahrexion likes this.
  15. Apr 2, 2025 at 1:06 PM
    Dracko
    2005 Tundra SR5
    Yes theyre adjusted to just barely rubbing.
    haha the engine is not running nor powered up during the bleeding process. This is not my first rodeo. The wheels turning/brake testing was after the brakes were bled. I had the rear up on stands to replace all the brake components so raised the front up too because why the hell not. makes bleeding and adjusting the e brake cable easier.
    Yeah the truck is on 4 - 3 ton jack stands, she solid. I might try bleeding with the ABS on if you think that'll help. Getting no air bubbles in the lines.
    Thanks for this tip, I adjusted the arm, moved the locknut/sensor hose up about 3/4". Im thinking Willwood prop valve.
    As it stands now, just drove the truck around, it brakes how it always has but its not great. Was hoping all these new parts and adjusting the bell cranks and cylinders might improve the performance. Going to look into the Willwood manual prop valve conversion to get these rear drums doing a little more.
  16. Apr 2, 2025 at 2:42 PM
    Dracko
    2005 Tundra SR5
    Gonna look at getting one of these,
  17. Apr 2, 2025 at 4:13 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Thought mine weren't doing anything recently but after scuffing rotors and doing hard braking to bed in pads, I can see by fresh marks on rotors that rears are working now. At least working enough to bed pads anyway.
    Have you tried something like that to visually tell if rear is doing anything during real use?
    Also i assume you added fresh grease on slide pins/bolts for rear calipers? All 4 of my rear pins were totally dried and slightly gummed up when I took them out. Kinda sticky rather than slick.
  18. Apr 2, 2025 at 4:18 PM
    ATBAV8
    Tempe, AZ
    This is 1st Gen forum. These trucks have rear drums.
    noahrexion and FrenchToasty like this.
  19. Apr 2, 2025 at 6:04 PM
    Totmacher
    Daniel
    West TN
    Some
    Wow. I though they were disc.
    Been a looong time since i worked on drums. Odd that both sides do same thing. Maybe a you made an error positioning cylinder and error repeated both sides?
    Parking brake working makes me think has to be fluid not moving (either obstruction or stubborn air pocket) or cylinders not connecting right.
    Can you tell if cylinder is moving at all?
    Do you have a diagram to confirm the strut, leveler, lever, and all springs and other bits in there are correct, didnt hook one in wrong spot?
    Weagle and ATBAV8 like this.
  20. Apr 2, 2025 at 6:15 PM
    rouxster70
    04ac2wdv65spd
    Homemade adapters, the round one for Toyota mc and the aluminum is for gm A bodies. Brakes and clutches are soooooo easy, almost fun.IMG_1333.jpg
    tvpierce, Dracko[OP] and BroHon like this.
  21. Apr 3, 2025 at 9:11 AM
    Dracko
    2005 Tundra SR5
    That’s awesome! Thanks. No more bugging the wife to pump the brakes haha
  22. Apr 3, 2025 at 3:52 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    You and I are like brothers from a different mother. I've had my Motiv for 20 years too, bought it when I had Euro brands with screw-on reservoir caps. I made the same adapter with the rubber plumbing fitting for my Toyota vehicles. Also like you, I just use it as a pressure vessel, and refill the brake reservoir. I used it once with fluid in the can, and it just made a mess -- never again.
  23. Apr 3, 2025 at 6:18 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Nice!
    I'm in the opposite camp. I bought the power probe adapter (cnc aluminum with o-ring) and DIY'ed the pressure vessel using a garden sprayer.
  24. Apr 4, 2025 at 4:29 AM
    tvpierce
    Maine
    My DIY Toyota adapter never made a perfect seal. It would hold pressure well enough to almost bleed one wheel completely before it lost pressure. When I saw the aluminum one that locks on and has an o-ring (saw it linked here on the forum) I bought one. But I haven’t used it yet. I have 3 Toyotas in the family that are due for a brake flush this spring.
  25. Apr 4, 2025 at 9:08 AM
    Dracko[OP], tvpierce and rouxster70 like this.
  26. Apr 5, 2025 at 5:06 AM
    tvpierce
    Maine
    Yeah, that Scamazon cap is the one I have, but haven't used yet.
    Dracko[OP] likes this.
  27. Apr 5, 2025 at 10:40 AM
    Dracko
    2005 Tundra SR5
    These are all awesome setups! I gotta get one soon.
    I notice after using the eBrake now, I go under and the main cable is slack (goes to the PS rear wheel) and the DS is tight like a piano wire. That middle arm that the 2 cables connect on is solid, should that be free to pivot? Anybody replaced it or is it something you can just take apart and clean?
  28. Apr 5, 2025 at 10:59 AM
    rouxster70
    04ac2wdv65spd
    FYI for any diy brake bleeder builders. Use a ball valve, then nipple into a pvc bushing, adapter 1.5 pvc, then a rubber sleeve 1.5 with clamps. No glue. This is works for Toyota mcs’ . Cost less than $10, because we all have 1/4” ball valves around.
  29. Apr 6, 2025 at 6:50 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Are you just recommending this because the ball valve maintains pressure while you unscrew the fernco adapter to refill the reservoir? If you have em' all it does make sense (shit, I probably do if I search) but the cap is pretty slick for a no frills quick disconnect that costs only slightly more then the sum of parts listed.
    I've almost pulled trigger on motive several times in the past. What's so messy with using the actual vessel with fluid in it rather than continually refilling the master cylinder?
  30. Apr 6, 2025 at 7:01 AM
    rouxster70
    04ac2wdv65spd
    The ball valve allows more control over process. For instance, I’ll attach the adapter to mc, close the valve and pressurize the line. Then open the valve slowly to pressurize the mc reservoir. If my clamp isn’t tight enough, I can close the valve and adjust adapter for a great seal. The valve is most useful when the jug is filled with fluid to do a flush, without the valve you’d have run the jug out of fluid to not make a mess. Just close the valve and bleed off the fluid in excess of reservoir, till level is below top of reservoir. Then almost no mess. Hope this is helpful.
    tvpierce and noahrexion like this.
