  1. Apr 3, 2025 at 3:22 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
  2. Apr 3, 2025 at 6:50 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I've been looking at these but am curious how it attaches. If you can get a picture of the fronts from inside the wheel well I would really appreciate that.
  3. Apr 3, 2025 at 8:59 AM
    Florida AF
    Logan
    North Florida
    I emailed Retrax on a whim and they are sending out replacement parts now.... so my search is on hold with high hopes.
  4. Apr 3, 2025 at 9:10 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I got one of those autel. How easy was it to add the 5th tpms to the display?
  5. Apr 3, 2025 at 9:33 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    easy if you have push button start, simply scan the sensor in your spare after you scan the other four and the OBD rewrite will take care of it. doesn't seem to work on keyed ignition vehicles.
  6. Apr 3, 2025 at 9:42 AM
    BrandonL812
    Brandon
    Awesome. I do have PTS. Thanks for the info.
    Tripleconpanna likes this.
  7. Apr 3, 2025 at 9:55 AM
    Cthulhu
    Installed, will see how much it collects after 1,000mi. I’m NA, so hopefully not too much.
  8. Apr 3, 2025 at 10:54 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I've got the same one on my N/A '15 5.7. Per their instructions I've emptied it every 2500 miles, though I have done as far as 4000 miles since installing it. Rarely is it higher than half full. One suggestion I do have, lube the o-ring with some sort of grease or vasoline. It gets pretty sticky and hard to remove. I usually have to use a pair of channel locks to get it broken loose.
  9. Apr 3, 2025 at 10:58 AM
    thetastelingers
    thetastelingers Master Baiter
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    I put the same one on mine about 10 months ago. It catches about a tablespoon every 1000 miles or so.
    Was leftover from when someone crashed into my GT350.
    Good quality.
  10. Apr 3, 2025 at 11:12 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Just ordered one myself.... and now we wait.
  11. Apr 3, 2025 at 11:17 AM
    Florida AF
    Logan
    North Florida
    whoa.... can this feature be added if it isnt currently on the display at all?
  12. Apr 3, 2025 at 11:54 AM
    Cthulhu
    Great advice Russ, thanks! :hattip:
  13. Apr 3, 2025 at 12:21 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    This has worked on two 2021 push bottom stat vehicles via a couple extra button pushes on the tool and scanning the extra sensor. The before state on the display does not show the spare but does afterwards. Not clear what other years this will work on but so far it appears to not work on a key start truck.
  14. Apr 3, 2025 at 12:21 PM
    Florida AF
    Logan
    North Florida
    ok, so most likely not available on my 17
  15. Apr 3, 2025 at 12:23 PM
    Dsptundra
    Austin TX Area
    Hard to know without trying. If you were in Central Texas we could try it.
    Florida AF[QUOTED] likes this.
  16. Apr 3, 2025 at 12:25 PM
    Florida AF
    Logan
    North Florida
    I will see if I can look around with my scanner.... If all goes well, I will be away from Central Texas for some time... All my exes and what not.
  17. Apr 3, 2025 at 12:51 PM
    mr_schiz
    mr_schiz New Member
    Caleb
    2020 TRD Sport Double Cab
    Fox 2.5 Resi's, 315/70R17 Toyo MT, Diamondback Switchback Tonneau
    Here you go. The provided hardware screws into the existing plastic fender liner grommets. It takes a bit of force to push them in and get the threads to grab but its kind of like a drywall anchor. The instructions recommend an electric ratchet and my milwaukee electric ratchet made quick work of them. The rears are very similar except a portion of the flap is sandwiched between the fender liner and the metal hanger. IMG_3930.jpg
    Tripleconpanna, 23Tundy, BR73 and 2 others like this.
  18. Apr 3, 2025 at 12:52 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    Thanks so much, that's exactly what I was wanting to see.
    RobertD likes this.
  19. Apr 3, 2025 at 5:46 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Received yesterday & today :yay:
    Eibach Pro 2R & DK UCA's.
    Thank you @memario1214 :cheers:
    Got the Bora 1.25" spacers on order to run with some OEM 18's freshly powder coated that's been sitting on the shelf.
    Was thinking of installing the suspension this weekend but probably best to wait for the spacers and tires(which I haven't decided on yet)
    She's really comin together now.
    Also got an extra AFE dry filter for my Stillen CAI for about $30 off from Amazon. Good for quick swap when washing and being inpatient.
  20. Apr 3, 2025 at 5:47 PM
    RobertD
    Robert
    DFW, Texas
    :curls:
  21. Apr 3, 2025 at 5:52 PM
    TacomaTRD4x402
    Southern California
    And thanks to you @RobertD for pointing me towards the Eibachs :fistbump:
  22. Apr 3, 2025 at 5:54 PM
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    If I can ever get home and get my ‘17 back together and you’re up for it, I can throw an extra sensor in mine and check it out for the group. I never got the ones that came in my wheels working and I still have all of my factory ones.
    Dsptundra[QUOTED] likes this.
  23. Apr 3, 2025 at 5:56 PM
    DiamondW
    Kent
    CenTex
    ‘17 CM
    I haven’t put many miles on mine, but I am really impressed with the ride quality, you will likely be very pleased.
  24. Apr 3, 2025 at 6:17 PM
    TacomaTRD4x402
    Southern California
    Yeah, that's what I'm looking forward to. Not needing anything too aggressive since she's a pavement princess. Just wanting a smoother and more quality ride.
    I'll save the offroading for my Taco but that's currently down at the moment :(
  25. Apr 3, 2025 at 6:19 PM
    Hutzell
    Hutzell New Member
    Nathan
    2020 Tundra Platinum
    To do list!
    New shoes and alignment today, 285/65/20 Baja Boss A/t’s. Absolutely love the stance now and clean look with factory rims!IMG_3618.jpg IMG_3619.jpg
  26. Apr 3, 2025 at 6:23 PM
    DiamondW
    Kent
    CenTex
    ‘17 CM
    Can’t keep a good taco down, it will live again. I regret selling mine every day.
  27. Apr 3, 2025 at 6:25 PM
    TacomaTRD4x402
    Southern California
    Very nice! Are you running spacers?
  28. Apr 3, 2025 at 6:27 PM
    koditten
    Kirk
    Midland of the Mitten
    Can you offer deets on suspension upgrades, if any?
    I hate my 20's and so want to go back to 18's.
    I don't really want much lift, I just hate how small the rubber looks in the wheel well.
    BR73 likes this.
  29. Apr 3, 2025 at 6:31 PM
    Hutzell
    Hutzell New Member
    Nathan
    To do list!
    yes 1.25 Spidertrax, was able to get a set next day to make sure I cleared the UCA’s for the front, I’m not disliking the side profile without any on the rear but I may add them, still undecided
  30. Apr 3, 2025 at 6:36 PM
    Hutzell
    Hutzell New Member
    Nathan
    To do list!
    3.5” front, 1” rear RC, put it on this weekend. I’ve had 20’s on other trucks of mine (sierra and Silverado), with a basically 35” tire I think it fills it out well and doesn’t look too much like a rubber band :rofl:
