2014 Platinum Tundra Headlights Wiring
Discussion in '2.5 Gen Tundras (2014-2021)' started by smlacey73, Mar 29, 2025.
  1. Mar 29, 2025 at 9:44 PM
    smlacey73
    smlacey73 [OP] New Member
    2014 Tundra Platinum
    Hey All... New to the forum with a mystery I can't seem to solve. Trying to swap the headlights on my 2014 Platinum tundra with some new old stock OEM lights I found on ebay. After taking the original lights out I see a wiring harness that I'm not sure what it goes to. As you can see in the photos the new light does not have the same harness or hole open in the light housing. Any ideas?
  2. Mar 30, 2025 at 4:41 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    What does that extra plug look like from the front?
  3. Mar 30, 2025 at 5:47 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I’m guessing the old light has the DRL strip at the bottom. Let’s see the front of the old light.
  4. Mar 30, 2025 at 12:09 PM
    smlacey73
    You are 100% correct. I suspected that might be the issue but I'm no mechanic. So should I be OK to use the new lights without including that connection. Pics of current and new lights attached?
    BlueRibbon4x4 likes this.
  5. Mar 30, 2025 at 12:50 PM
    BlueRibbon4x4
    Geno
    Yep, that light strip isn’t really necessary. The main functions should still work. I would still check all functions so you’re 100% sure.
  6. Mar 30, 2025 at 1:00 PM
    smlacey73
    Awesome!!! Thank you so much!!! I've always wanted to join this forum. Glad I did. This issue has been driving me crazy for longer than I'd like to admit. You solved it in less than 24 hrs. Really appreciate your time and expertise.
  7. Mar 30, 2025 at 1:05 PM
    BlueRibbon4x4
    Geno
    No worries! Plenty of us here with lots of experience that are happy to help!
  8. Apr 2, 2025 at 5:50 AM
    scottb2240
    scottb2240 New Member
    Scott
    2015 Tundra SR5 Black
    Glad you got it sorted out! I sent you a PM regarding your original Platinum headlights.
