Sony xav9500es
Discussion in 'Audio & Video' started by LTR9, Feb 10, 2022.
  1. Feb 1, 2024 at 12:47 PM
    #61
    Goonrideit
    Goonrideit New Member
    Chad
    2018 Inferno CM
    Short build RC 6inch. Bilsteins B8 8125 coilovers, KMC FMJ 20×10 0 offset Nitto M/t 37x12.50r20 SSbuilt Front bumper inferno powder match Dirty Deeds 6inch KnN cold'ish Baja Design Squadron Pro flush, Diode Dynamics SS2 fogs Opt7 rock lights Aux Beam 6 gang switch Throttle Commander Tyger step boards Tyger 5.5 trifold bed cover
    I did not have a JBL system. Just standard Toyota shit. Since then I've upgraded everything with Kicker KSS componet series and RF 4x500 amp for speakers and am now adding 2 Infinity Reference 12s powered by a RF 1200x1. When doing my tests this weekend prior to installing and mounting the subs. I hooked up the subs and amp to everything to test. Nothing was coming out of the amp for signal. But power and gounds remote were good. Had to go through the settings and on the Sony HU and noticed there are 2 sub options. One you can switch sub from stereo or mono. In Mono it didn't work, because I used RCA cables instead of a mono jack output this was facorty set at Mono. Also in a different menu there was a Sub on and of with Gain settings which was off. Once switched sub to on and set to stereo boom got my bass. Also note that you can control wether it's playing in reverse. BASICALLY if you hook up the speaker wires backward it'll push the wrong way. It'll swap the polarity without having to change the wire position. I would check those options and play with it.
    Also if it is a factory JBL amp that was operating on 2ohms then you'll be a bit quieter because the head unit High level output is outputting 4ohms. Recommend checking all those if you haven't.
  2. Sep 28, 2024 at 9:57 AM
    #62
    cclg041994
    cclg041994 New Member
    Zechariah
    Tundra TRD Off-Road Crewmax
    I just bought the xav9500es from trail grid pro with maestro already added into it. I can't seem to find where to connect the usb-c wire for downloading updates and adding images. Anybody know where it is? It's already installed but its bugging me. I know it's somewhere and it'll be a duh moment lol.
    619Tundra likes this.
  3. Sep 28, 2024 at 12:30 PM
    #63
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    As far as the plug on the HU, it is here.
    As far as the actual update;
    You can either load the update onto a thumb drive or use your smartphone.
    Instructions are found here..
    Firmware Update to Version 2.00.01 | Sony USA
    Good luck..
  4. Dec 9, 2024 at 1:14 PM
    #64
    Snert
    Snert New Member
    2021 SR5
    And just to add, Trail Grid Pro includes the USB adapter in their bundles so the USB data port below the AC controls should be connected to the back of the head unit like in this diagram. I ordered the 9000ES from them and saw the USB connected when installing but I haven't tried plugging into the USB data port yet.
    1lowlife[QUOTED] likes this.
  5. Dec 12, 2024 at 5:47 AM
    #65
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Getting my 9500es from Trail Grid Pro. Can't wait. So u all talking about lack of mirroring, read up on app called AAAD. They supposedly have download for mirroring your phone on radio
  6. Dec 12, 2024 at 6:50 AM
    #66
    Sonicbluerider
    Dennis
    2019 Tundra
    So when installing radio do u disconnect the truck battery. I'm thinking yes ,but then my brain says with truck off there no power in that area.
  7. Dec 12, 2024 at 6:58 AM
    #67
    Sonicbluerider
    Dennis
    2019 Tundra
    I don't have my radio yet ?? With the ubs extension cable on back of radio coming, is the end that cable that comes with the radio going into truck have the ability to plug in a c connection? an how long is that cable? Thinking i might need to buy a c to c connecter to make it long enough to make it useful. An where do u run it. All my spaces are full. Thinking of running to passenger side an velcroing it on there.
  8. Dec 21, 2024 at 11:13 AM
    #68
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Does anyone with this head unit have major issues with wireless Android Auto? I just installed this in my wife's 2019 Highlander and both our phones (S22 Ultra and S24 Ultra) skip/lag like crazy using maps and audio. There are some threads on different forums with people claiming the same thing. Seems insane considering how long this unit has been out.
  9. Dec 21, 2024 at 11:36 AM
    #69
    Sonicbluerider
    Dennis
    2019 Tundra
    No nothing. However android forums are saying your android model is having lots of problems. After last 2 updates
  10. Dec 21, 2024 at 11:58 AM
    #70
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    It does seem like most people with issues are stating they have an S22 or newer. It's just weird because wireless AA works flawlessly in my Sierra HD.
  11. Dec 21, 2024 at 2:15 PM
    #71
    Sonicbluerider
    Dennis
    2019 Tundra
    Oh goody ,something else i need to worry about when mine finally gets here...lol if u find a cure post it up ....
  12. Dec 22, 2024 at 3:07 PM
    #72
    Sonicbluerider
    Dennis
    2019 Tundra
    Hay 1lowlife is that cable a c connecter on both ends? Will/ does it connect directly to the plug that is now on a 2019 tundra. My tundra has tha female connecter similar to the wall charger plug in picture. thanks
  13. Dec 22, 2024 at 3:13 PM
    #73
    1lowlife
    DADA
    2014 MGM DC SR5
    The radio has a yellow BATT always on wire.
    So I would disconnect it.
    0c7b43c8-54b3-4755-9f31-a6fbc87347f1_7d140c21b83b1a621dd294afc73f05b2335d37a3.pngb9f81525-2e4e-457d-90d8-9186c8b9543c_e1bdea115533e9985e5313019760285792956596.png
  14. Dec 22, 2024 at 3:27 PM
    #74
    1lowlife
    DADA
    2014 MGM DC SR5
    If replacing the stock radio, you'll need an adapter to retain your dash USB connector.
    I think this one but you can probably find it cheaper...
    Amazon.com: Maestro Acc-USB-TO2 Factory USB to Male USB Adaptor for TO2 Vehicles : Electronics
    Go to Radio, Amplifier and Radar integration solutions | iDatalink Maestro and it will tell you what you need.
  15. Dec 28, 2024 at 4:13 PM
    #75
    shroomzofdoom
    shroomzofdoom New Member
    2019 TRD Pro
    S22 ultra here, I'm having the issues you mention. Based on my research, it's not a Sony problem but an issue with AA wireless on Samsung. If I connect to the USB without wireless, audio is fine. Since I've finally had enough of Samsung after 10 years, I'll update you when my Pixel 9 Pro XL arrives in a few days.
    BuckWallace[QUOTED] likes this.
  16. Dec 28, 2024 at 4:48 PM
    #76
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Thanks for confirming. I came to the same conclusion after doing some more research. The S24 skips way less than the S22, but it's still there somewhat. We tried an iPhone and CarPlay works totally fine. Seems like it'd be an easy fix for Samsung, but too many cooks in the kitchen, I guess.
  17. Dec 31, 2024 at 9:57 AM
    #77
    Sonicbluerider
    Dennis
    2019 Tundra
    On its way this p.m....question..anyone mount their microphone by your right knee side by the psi/ nanny panel. I have a open spot down there, rather than on steering wheel column.
  18. Dec 31, 2024 at 10:14 AM
    #78
    Snert
    Snert New Member
    2021 SR5
    I mounted up in the factory location in the headliner, the panel up there is pretty easy to take apart and there's a little empty spot inside for the microphone to go. Trail Grid Pro makes/includes with their head units a little mount that fits perfectly up there. Tuck the wire in the headliner over to the A pillar, remove the a pillar and route the wire down into the dash, and then across the dash to the back of the head unit.
  19. Jan 2, 2025 at 8:21 PM
    #79
    shroomzofdoom
    2019 TRD Pro
    Pixel 9 Pro XL, wireless android auto works fine, even with the phone in my pocket. Some things I miss about the Samsung, but so many things have been broken the past two years. They really don't care about updating anything older than a year.
  20. Jan 3, 2025 at 1:55 PM
    #80
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    I've been so close to trying out a Pixel, but usually keep my phones for three years before upgrading and Samsung usually gives me ~$600 for my 3-year-old S Ultras. Makes it hard when Google offers around $200 and the Pixel Pro XLs are priced similar to the S Ultra.
  21. Jan 4, 2025 at 6:34 AM
    #81
    Sonicbluerider
    Dennis
    2019 Tundra
    ?? Mine goes in this coming week! I'm putting it in close to dash! How is the navigator view from passenger seat ?? Wondering if I need to set a angle towards that side ! Example! Last summer 15,800 miles to an from Alaska ,I only drove 15,800 miles lol .. wife gives me all the info when traveling , so I what the best view for her !!!
  22. Jan 4, 2025 at 1:04 PM
    #82
    Sonicbluerider
    Dennis
    2019 Tundra
    Help from someone that installed theirs.. the front camera lead is tape to another yellow lead into the mm unit, I'm i suppose to untape that an plug my. Rear camera into it an just let that rear camera lead hang ? #2 DOES that ubs cable just plug in the dash plug?
  23. Jan 5, 2025 at 2:54 AM
    #83
    Sonicbluerider
    Dennis
    2019 Tundra
    These r pics .do I just remove black tape in put rear camera plug there. An does gray connecter just plug into usb on dash
  24. Jan 5, 2025 at 2:55 AM
    #84
    Sonicbluerider
    Dennis
    2019 Tundra
    Anwhat r these to plugs for the little black one anthe little pink one.
  25. Jan 6, 2025 at 6:38 AM
    #85
    Sonicbluerider
    Dennis
    2019 Tundra
    Well tgp got back to me on a sunday..Great service one would say..!! Closed today over there "snow" storm. So maybe u all can answer me this .rear camara rca plug wheres it plug into .me thinking camera one connecter..
  26. Jan 9, 2025 at 5:42 AM
    #86
    Sonicbluerider
    Dennis
    2019 Tundra
    All hooked up..oh well xm works but not gps
  27. Jan 16, 2025 at 9:56 AM
    #87
    shroomzofdoom
    2019 TRD Pro
    Sorry for not updating sooner. Confirmed that the Pixel 9 Pro XL does not have anything near the problems skipping I experienced with my Samsung. On wireless AA, there is a momentary skip/audio drop for example when Waze is updating the map or sending new directions (maybe 1/2 second). I have concluded years ago that wireless (anything) will never be as effective as wired (anything) I ran ethernet all over my house, still love residential fiber phone service, and I'll probably wind up connecting this with a USB whenever possible. Every time that audio drop occurs it kinda pisses me off.
  28. Apr 1, 2025 at 1:30 PM
    #88
    Sonicbluerider
    Dennis
    2019 Tundra
    ??? On my 9500 , gauge screen , the fuel gauge isn't showing % , actually nothing . is there a setting in unit a need to turn on ?
  29. Apr 1, 2025 at 3:00 PM
    #89
    airosey
    airosey 2009 CrewMax Limited 4x4
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
  30. Apr 3, 2025 at 2:58 PM
    #90
    Sonicbluerider
    Dennis
    2019 Tundra
    Just did it. Should of read how first however I succeeded
