Front diff drain plug
Discussion in '2.5 Gen Tundras (2014-2021)' started by CrazyE, Mar 31, 2025.
  1. Mar 31, 2025 at 7:40 PM
    CrazyE
    CrazyE [OP] New Member
    2020 Tundra Double Cab
    I’ve read that some have replaced the front diff drain plug with those from Kaon. Others have used the Lexus 14mm as a replacement. Has anyone ever used the 24mm steel bolt being sold on Amazon? Looks similar to the one sold by Kaon. Wondering if its worked for those who have.
    HulkSmurf14 likes this.
  2. Apr 1, 2025 at 4:54 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I am preparing to change front diff fluid and checked to be sure I can remove the drain and fill plugs. Was going to replace the drain plug with the Lexus 14mm plug. I found this https://www.autopartsco.com.au/KS0127 Which one on Amazon is it ?
  3. Apr 1, 2025 at 7:22 AM
    CrazyE
    In Amazon I searched for a front differential drain plug for Tundras and a few stainless steel ones with 24mm bolts rather than a hex appeared. They also appear to have copper washers. Not sure how good they are so I wanted to see if anyone has tried them.
  4. Apr 1, 2025 at 7:28 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    It's been awhile since I did my front diff fluid, what's the problem with the stock plug? I remember it being something but I reused mine without a problem.
    kevine0001 likes this.
  5. Apr 1, 2025 at 7:36 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    As usual: the previous guy who touched it was overzealous with torquing it down.
  6. Apr 1, 2025 at 7:36 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Notorious for getting impacted on and then getting stripped when trying to remove them with the hex bit.
    agrestic1 likes this.
  7. Apr 1, 2025 at 8:24 AM
    seydou
    seydou Distinguished Member
    For something as cheap as a drain plug, there is no way I am "trying" some unknown Chinese POS off of Amazon.
  8. Apr 1, 2025 at 8:35 AM
    Chip_Tundra
    Chip_Tundra New Member
    If your plug isn't rusted out, get a long 1/2" breaker bar and a proper 10mm allen socket. 18"- 24" of leverage will make it easy work to remove.
    I recently did my front diff fluid and can't figure out why this is so difficult for people lol
  9. Apr 1, 2025 at 8:40 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    Go with the Lexus hex head plugs. Allen head plugs are more prone to strip, and I hate the fact that Toyota continues to use them.
    I've replaced the front diff plugs on my '03 Tacoma, '18 Tundra, and '16 Sequoia all with the Lexus 14mm head head plugs
  10. Apr 1, 2025 at 9:51 AM
    kevine0001
    kevine0001 New Member
    Kevin
    I recall doing mine (been a little while), and had no issue reusing the OEM plugs for front, rear and t-case. I did replace with new OEM crush washers.
  11. Apr 1, 2025 at 11:35 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I haven't had any issues with mine, either, until this OCI. Apparently Kong was on the loose at the dealership when I had a leaking axle seal replaced. I purchased Snap-on allen sockets specifically for this job and even that has failed to break this thing free. It's frustrating to say the least.
