Should I swap 20s for 18s?
Discussion in 'Wheels & Tires' started by blee, May 7, 2024.
  1. May 7, 2024 at 8:13 AM
    blee
    blee [OP] New Member
    2017 Tundra XSPX
    IMG_2772.jpg IMG_9730.jpg should I switch out my 20s for some 18s ? The bottom picture with the XSPX is my current set up and the tundra in front of the garage is what I’m looking at doing. Also, I’m your experience is there significant savings on the price of tires for 18 inch wheels vs 20 inch?
  2. May 7, 2024 at 8:14 AM
    blee
    2017 Tundra XSPX
    I want some meatier looking tires also which is why I want to make the change
  3. May 7, 2024 at 8:18 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    17s are where the cost savings really come into play and open up C load tires as well
    blee[OP] likes this.
  4. May 7, 2024 at 8:18 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    I like my tires like I like my women...meaty, run the 18's.
    Ebrperk, bulldog93 and blee[OP] like this.
  5. May 7, 2024 at 8:21 AM
    blee
    2017 Tundra XSPX
    Yea I don’t really want to go lower then 18s I feel like the wheel looks to small if you get lower then that
  6. May 7, 2024 at 8:24 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I'm just glad OP isn't referring to wheels as rims, go 18.
  7. May 7, 2024 at 8:31 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Always a fan of the smallest wheel you can run. The more sidewall there is the better the ride usually is.
  8. May 7, 2024 at 8:57 AM
    blee
    2017 Tundra XSPX
    Yea I wouldn’t mind improving the ride a little for sure.. but I also like the look of a more beefy tire. I think I’ll go with Nittos this time
    BreyTundy likes this.
  9. May 7, 2024 at 8:59 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    If you plan on buying different wheels anyway, then go 18. It looks better and rides better. If you want to change just because the 18" tires are less expensive, then buying a $2000 set of wheels to save $20 per tire is not worth it.
    blee[OP] and bulldog93 like this.
  10. May 7, 2024 at 9:02 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes
  11. May 7, 2024 at 9:05 AM
    blee
    2017 Tundra XSPX
    Yes I’m more wanting to change for the look and better ride … but a little tire savings would just be an added bonus .. I’m going to need new tires soon anyway
    Boerseun likes this.
  12. May 7, 2024 at 9:08 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Sounds like a win win win right there
  13. May 7, 2024 at 9:40 AM
    Psv
    Psv New Member
    Chicago
    2019 Tundra Sr5
    I had 20s before, switched to 18s. In my experience, it's a much more comfortable ride, specially here where I live with potholes and terrible roads. As far as looks go both look good with a nice wheel/ tire setup
  14. May 7, 2024 at 10:56 AM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    It depends on the wheel you go with. I went from 20s to 17s. My truck looks much better, rides smoother, and gas mileage went up since I switch to a lighter wheel\tire combo. Both times I was at 35" tires.
  15. May 7, 2024 at 11:01 AM
    blee
    2017 Tundra XSPX
    good to hear … I’d love a little smoother ride for sure
  16. May 7, 2024 at 11:04 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    This is very true, however, hitting a pothole/curb/rock can damage a wheel or sidewall and likely make you loose hours of your time... Sure, you'd have to go fast to do that.
    Offroading and 20's have no business being together.
    @blee If the above scenarios are not a concern, perhaps the savings are not there at all. Plush-ish ride is what you're left with.
  17. May 7, 2024 at 11:53 AM
    Thegreatwhitetundra_821
    Thegreatwhitetundra_821 Jaeger Ferrara
    JAEGER
    Anaheim Hills
    SR5 2015 Tundra Crewmax
    List of Mods. Suspension- @fox Shocks 2.5 With reservoirs with DSC Front and Back. @deaver_suspension_inc in the rear suspension U748 LEAFS. @camburgracing shackles @dirtking-spindles @camburgracing - KINETIK BILLET UNIBALL Upper control arms. @bajadesigns - Lights XL80's. Tires Toyo Open country MT’s 37×12.50 Wrapped in a @methodracewheels bead grip technology 704 Wheels. There Amazing. From 30 PSI To 17PSI or 18 PSI very strong wheels. Zero offset RoofRack @prinsuracks Exhaust- @blackwidowexhaust with side cut out by @dirtskum Gears 1; 4:30. Cold intake- @sbfilters Straps @alpine_offroad
    I would do 17’s more meat on the tire. Or 18 if you don’t do to much wheeling on the dirt
  18. Feb 24, 2025 at 5:42 PM
    blee
    2017 Tundra XSPX
    I ended up going with this set up. 18inch Fuel rebel 5 wheels with 275/65 R18 Nitto Ridge Grappler tires. Wish I could have went a little bigger on tires but this looks fine I think.. any bigger and I think I would have some rubbing without modifying stuff since I don’t have a lift. There are the same height as my previous tires with the 20s
    Sleeper16plat likes this.
  19. Feb 24, 2025 at 6:24 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    O.K. Your final setup looks good.
    But let's not lose sight of what ya get with 20's:
  20. Mar 1, 2025 at 8:30 AM
    blee
    2017 Tundra XSPX
    I swapped for a little bigger tire.. looks
    Much better I think 275/70/R18
    Sleeper16plat and flyfisher like this.
  21. Mar 31, 2025 at 11:55 AM
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    Doing the same. My 2025 has 20's, my 2022 had 18's...
    Bought a set of aftermarket 18's back in 2023 [OEPLUS w/ +15 Offset] that I really like, then traded that truck in on a 2025. Put original OEM rims back on before the trade.
    Didn't like the stock rubber that came with the 25' so I pulled them off and installed a set of winters I had on a rack from a 2016 F150 [winter season when I got the 25's] that fit the 20's.
    Now going to put the 18's back on with KO3's [275/70 R18's].
  22. Apr 1, 2025 at 4:57 AM
    Yawtzee
    Yawtzee New Member
    2010 Rock Warrior
    I like the 18's much better! Looks great
  23. Apr 1, 2025 at 5:02 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Any issues with caliper clearance with 17's? Need to be careful placing wheel weights on the inside?
