Torque specs front suspension
Discussion in '1st Gen Tundras (2000-2006)' started by Aaol1, Oct 27, 2023.
  1. Oct 27, 2023 at 9:20 AM
    Aaol1
    Aaol1 [OP] New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
    Hey I'm putting back my front suspension today and having a hard time finding a few torque specs
    Lower shock bolt
    Upper shock top mount bolts ( X3)
    Ball joint castle nut
    Can anyone help me out?
  2. Oct 27, 2023 at 9:27 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Torque the lower shock bolts, LCA bolts, and anything else with rubber bushings once the truck is off jacks and sitting under it's own weight.
    From the 2004 FSM:
  3. Oct 27, 2023 at 9:27 AM
  4. Oct 27, 2023 at 9:27 AM
    If you have the FSM, they’re typically shown in both lb-ft and N-m in the exploded diagrams.
    Riverdale21 and des2mtn like this.
  5. Oct 27, 2023 at 9:42 AM
    Aaol1
    Sam
    Yea I searched around but couldn't seem to find it , typical lol. Anyways all good, thank you!
  6. Oct 27, 2023 at 10:10 AM
  7. Oct 27, 2023 at 10:36 AM
    Aaol1
    Sam
    Thanks, much appreciated
  8. Oct 27, 2023 at 10:37 AM
    Aaol1
    Sam
    Man the power steering bolts are so high torque, I did not expect that
  9. Oct 27, 2023 at 10:47 AM
    Jack McCarthy likes this.
  10. Oct 27, 2023 at 11:19 AM
    Aaol1
    Sam
    How much do we torque down the center nut? Instructions mention something about finger tighten first then 5-6 turns for proper pre-load, but I'm not sure if this is what they are referring to
  11. Oct 27, 2023 at 12:48 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Should be about 18ft-lbs. I used a crows foot socket on my torque wrench in order to use a wrench to hold the piston still.
  12. Oct 27, 2023 at 12:51 PM
    Riverdale21
    OTP ATL
    Yup 18.
    des2mtn likes this.
  13. Oct 27, 2023 at 1:06 PM
  14. Oct 27, 2023 at 1:08 PM
    I usually just keep going until it runs out of threads. :notsure:
  15. Oct 27, 2023 at 1:14 PM
    Aaol1
    Sam
    Kk fair enough, doesn't sound like it's a super crucial one, as long as it's tightened enough. I've got about 6 threads showing on top of the nut, should be good
  16. Oct 27, 2023 at 2:19 PM
    This one clicks?
  17. Oct 27, 2023 at 2:44 PM
    I don’t think it did when I read the details. I figured it was one of those torque wrenches that use deflection for torque measurement.
    If it is, they last a lifetime but they don’t click.
  18. Oct 27, 2023 at 2:50 PM
    No, I'm saying, it does. Why wouldn't it?
  19. Oct 27, 2023 at 3:15 PM
    I guess they do. I always thought they were quiet.
  20. Oct 28, 2023 at 2:28 PM
    FYI since you guys were discussing it. HD has Husky torque wrenches on sale too. There was also a 3 pack you could buy. 1/4, 3/8 and 1/2 drive.
    des2mtn likes this.
  21. Oct 28, 2023 at 3:00 PM
    des2mtn
    SW
    Tonto cover
    I have the 1/2" Husky and I like it a lot.
  22. Oct 28, 2023 at 5:32 PM
    I prefer my split beam, personally. But the Husky stuff is probably a good start for any DIY/home mech.
  23. Oct 28, 2023 at 6:47 PM
    Well I would hope so. Yours cost $100 more. :spending:
  24. Oct 29, 2023 at 5:10 AM
    And yet $600-800 cheaper than the Snap-On equivalent, I’m sure. So definitely not “pro level” parts pricing we’re talking about. But pro-level function/quality.
    I think this is one of those places where you want to spend a little extra $$. Not on the smaller wrenches/fasteners that require less torque, it’s the important fasteners that tend to require more torque (100lbft+)
    The wrenches Big Orange is selling are fine, as long as you remember to set them back to zero after every use. I have a couple in smaller sizes, it’s not like I don’t use that style of wrench. I think the split beam style I linked does up to 250lbft, do any from HD hit those numbers? That may be the separating factor. But with split beam you don’t need to bother with zeroing out while in storage.
    EDIT
    : I see the sign now, and the 1/2” drive model does go to 250, impressive. So major difference is just the design - the design of the Husky should require returning to zero (or <10lbft) after use to keep it in proper calibration. My original comment still stands: “I prefer my split beam, personally. But the Husky stuff is probably a good start for any DIY/home mech.” Depending on Husky’s warranty, and whether they offer free or discounted recalibration would really push it over the edge on any Tekton offerings you may find on the jungle website.
  25. Mar 31, 2025 at 1:56 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Thank you! I been looking for the torque specs for the LCA bolts.
    Me and Casey thought they were 125 ft lbs for some reason.
    I've got the KPO cam eliminators now and they said to go with factory torque specs.
