38gl gas tank in a 2nd generation
Discussion in '2nd Gen Tundras (2007-2013)' started by Red Freighter, Jan 23, 2016.
  1. Jan 23, 2016 at 8:57 PM
    Red Freighter
    Red Freighter [OP] Red Freighter
    Fred
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    Just wondering If anyone ever looked into this.
  2. Jan 24, 2016 at 3:43 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I don't see why it wouldn't fit pre-14 models since they are basically the same.
    From what I understand, the parts for the Toyota 36 gal tank is substantially more expensive than 46 gal Transferflow tank. If I were to get one, I would be getting a Transferflow.
    JROCK915 likes this.
  3. Jan 24, 2016 at 8:36 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've read that there may be a cross member that would be an impediment as well as the cost. This has been covered. It shouldn't take but minimal effort to dig up the info.
  4. Mar 30, 2025 at 10:01 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    I did this to my 2010
    Installed the Toyota 38 gallon tank. The transfer flow tank wasn't carb certified at the time and cost more than the Toyota tank. (That was 6 years ago) I'm sure things have changed by now.
    You need the extra front tank cross member.
    Move a couple of brakes lines (bend gently)
    Locate the emergency brake pivot up a few inches.
    The rest is plug and play.
    Your 26 gallon tank fuel pump swaps right over.
    All tanks are the same depth.. The 38 gallon one is just longer.
    I ordered all new straps so I could use the Toyota skid plate. They have studs to mount the skid plate.
    MTRock and Wynnded like this.
  5. Mar 30, 2025 at 10:19 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
