  1. Mar 29, 2025 at 6:56 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    My truck is almost identical to yours. Except I have the Diamondback cover, vinyl wrapped my bumpers, removed the Tundra, SR5 emblems and replaced the 5.7 badge with a black one..
    Looks great!
  2. Mar 29, 2025 at 7:07 PM
    VUDUBLU
    VUDUBLU New Member
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Yup. Had to add them to keep my factory wheel with the new upper control arms.
    dherring256[QUOTED] likes this.
  3. Mar 29, 2025 at 7:26 PM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Did LED dome, map, bed, and reverse lights. For just a few bucks it really modernizes the truck.
    ATV25, woods, HulkSmurf14 and 2 others like this.
  4. Mar 29, 2025 at 7:57 PM
    NWPirate
    Zach
    WA
    Ball joint looks a little gooey, I'd clean it off and keep an eye on it.
    Let me know how your Autel works out, I'm tired of going to Discount to get the sensors synced twice a year.
    HulkSmurf14 and Tripleconpanna like this.
  5. Mar 29, 2025 at 8:54 PM
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
    Does anyone have an idea when Ironman bummers will be on sale again?? Thx
  6. Mar 29, 2025 at 10:23 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    4th of July sale for Ironman... worth the wait!
    23Tundy, Mater and Tripleconpanna like this.
  7. Mar 29, 2025 at 10:33 PM
    littlebus01
    Tobias
    21 trd off-road
  8. Mar 29, 2025 at 11:54 PM
    PhoenixSR5
    PhoenixSR5 New Member
    Brandon
    Gilbert, Az
    2016 Tundra SR5 work in progress
    Front: King 2.5 EXT RR, Freedom Offroad Uniball UCA, Sway Bar Delete, BMC and Pinch weld mod. Rear King 2.5 RR shocks, Icon AAL. Fuel Zephyr 18x9 +1 w/ Dirty Seven Maxxis RAZR MT
    Finished fitting the fiberglass just need a few clips for the grill. Closed the hood gaps and lots of shave fit shave fit. Never done anything like this before. Time for a DIY paint job on them. I guess we'll see that goes lol.
    Yota303, TNThunder, JMGmanAZ and 12 others like this.
  9. Mar 30, 2025 at 1:21 AM
    littlebus01
    Tobias
    21 trd off-road
    Looks great I don’t have the skill or patience
  10. Mar 30, 2025 at 3:32 AM
    PhoenixSR5
    Brandon
    Gilbert, Az
    The first go looked like shit lol. I have zero patience but I get ocd over some stuff lol
  11. Mar 30, 2025 at 5:22 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Installed the Free swing case from RealTruck I received from the rebate of the tonneau cover i bought. Wasn’t going to but then i said, wth. It may be useful.
    can’t say I wont use it now. 10 mins later and i already empty the inside cab and transfer to the case.
  12. Mar 30, 2025 at 7:18 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Nice! Looks similar to my 2014 Crewmax sans dents....;)
  13. Mar 30, 2025 at 7:18 AM
    Corndog123
    Sam
    Tennessee
    I really like that sort of thing! Well done!
  14. Mar 30, 2025 at 7:21 AM
    Corndog123
    Sam
    Tennessee
    Not today but yesterday I attempted to change out the gear oil in my 2 differentials and transfer case. Well, upon opening them up, they all had good oil in them. The transfer case was a little darker than the other 2 but still clear and seemed to be in good shape. I'm thinking I must have had them serviced when I took it in to get the transmission serviced.
    Henry1jg and HulkSmurf14 like this.
  15. Mar 30, 2025 at 7:56 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :eek2:
    Should have hit me up in a PM - If I had known you were needing one for the platinum I would’ve recommended the other one… you ordered the standard switch panel for the little pocket behind the shifter.
    23Tundy, Florida AF, NWPirate and 3 others like this.
  16. Mar 30, 2025 at 7:58 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Looks good in the end - glad you got it to work.
  17. Mar 30, 2025 at 9:24 AM
    Tboh1870
    Tboh1870 New Member
    Herman
    Just starting reno
    Lord I hope not or the boss will be pissed ... some pics so far
    20250330_120717.jpg 20250330_120705.jpg 20250330_120647.jpg 20250330_120622.jpg
  18. Mar 30, 2025 at 11:59 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    This scorcery.... The PITA was getting the axle out and back in. I assume it might have something to do with spline tolerance from the nitro gear which I had installed couple years back
    Florida AF, BR73, woods and 1 other person like this.
  19. Mar 30, 2025 at 1:14 PM
    centex
    centex New Member
    Axle seal?
  20. Mar 30, 2025 at 1:26 PM
    justcuz
    justcuz 2.5 Gen Member
  21. Mar 30, 2025 at 1:30 PM
    Gtboosted
    Gtboosted New Member
    Los Angeles
    2020 CSM Tundra 1794
    Yesterday, I added a cooler and used the outlet line to do a complete fluid change. I ran 14 qts thru it. Also added an inline filter before the cooler. Will run the thermostat pinned open for a couple weeks to let the filter catch anything just in case. But I doubt it's really needed. Fluid was black but did not smell burnt.
    2020 Tundra 1794 with 75k.
    Coolant was changed a couple weeks back. Diffs, transfer case, brake, and power steering were done in January. She's set for a while.
    20250328_183347.jpg 20250329_095129.jpg 20250330_111017.jpg 20250330_113436.jpg 20250330_115300.jpg 20250330_131651.jpg
    Piki, DPF88130, Yota303 and 17 others like this.
  22. Mar 30, 2025 at 1:33 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    That looks nice. What product did you use? Got an Amazon link?
    BR73 likes this.
  23. Mar 30, 2025 at 1:54 PM
    justcuz
  24. Mar 30, 2025 at 1:55 PM
    HulkSmurf14
    2014 Tundra Limited
    It was time, for sure! Nice work and finishing of the cooler install!
  25. Mar 30, 2025 at 2:04 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Went out this morning to the test loop. Truck felt good still need to get comfortable again. Made some rebound changes to the bypass tubes. And did a quick roll on at 50mph and clearly it has some traction issues. Pretty wild
    https://youtu.be/IpGKz9fHbzE?si=K1pR0IIKGEnazN59
  26. Mar 30, 2025 at 2:38 PM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    Man I want to do the cooler if anything for easier fluid flushes but it's so dang expensive.
  27. Mar 30, 2025 at 2:53 PM
    Gtboosted
    Los Angeles
    Badass!
  28. Mar 30, 2025 at 2:59 PM
    Gtboosted
    Los Angeles
    Yeah it was about $700 all in for the cooler. Fluid was another $120. You can do it much cheaper with a Hayden cooler and diy'ing the mounting bracket. If you skip the oem hardlines and hoses, you can probably be in it under $300 for the thermostat, cooler, and transmission hose. You just need to get creative and route or protect the transmission hose from the exhaust heat.
  29. Mar 30, 2025 at 3:56 PM
    TheMuffinMan
    Idaho
    2021 DCLB SR5
    When I looked at the kit it was $1200? Could you message me what you did, $700 is more palatable then $1200. I'd rather do the OEM hard lines.
  30. Mar 30, 2025 at 4:11 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    That’s how it’s supposed to be. You have a platinum and they don’t have the cut out. He has a pretty extensive write up on his build/vendor page about having to cut the leather and how to secure it.
    Tripleconpanna likes this.
