  1. Mar 29, 2025 at 10:23 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    4th of July sale for Ironman... worth the wait!
    23Tundy, Mater and Tripleconpanna like this.
  2. Mar 29, 2025 at 10:33 PM
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
  3. Mar 29, 2025 at 11:54 PM
    PhoenixSR5
    PhoenixSR5 New Member
    Brandon
    Gilbert, Az
    2016 Tundra SR5 work in progress
    Front: Dirt King Long Travel Kit, DK spec King Coilovers, BMC and Pinch weld mod. Rear King 2.5 RR shocks, Deaver K37s, SDHQ Shackles. Fuel Hype 18x8.5 w/ Dirty Seven Maxxis RAZR MT
    Finished fitting the fiberglass just need a few clips for the grill. Closed the hood gaps and lots of shave fit shave fit. Never done anything like this before. Time for a DIY paint job on them. I guess we'll see that goes lol.
    Yota303, TNThunder, JMGmanAZ and 12 others like this.
  4. Mar 30, 2025 at 1:21 AM
    littlebus01
    Tobias
    21 trd off-road
    Looks great I don’t have the skill or patience
  5. Mar 30, 2025 at 3:32 AM
    PhoenixSR5
    Brandon
    Gilbert, Az
    The first go looked like shit lol. I have zero patience but I get ocd over some stuff lol
  6. Mar 30, 2025 at 5:22 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Installed the Free swing case from RealTruck I received from the rebate of the tonneau cover i bought. Wasn’t going to but then i said, wth. It may be useful.
    can’t say I wont use it now. 10 mins later and i already empty the inside cab and transfer to the case.
  7. Mar 30, 2025 at 7:18 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Nice! Looks similar to my 2014 Crewmax sans dents....;)
  8. Mar 30, 2025 at 7:18 AM
    Corndog123
    Sam
    Tennessee
    I really like that sort of thing! Well done!
  9. Mar 30, 2025 at 7:21 AM
    Corndog123
    Sam
    Tennessee
    Not today but yesterday I attempted to change out the gear oil in my 2 differentials and transfer case. Well, upon opening them up, they all had good oil in them. The transfer case was a little darker than the other 2 but still clear and seemed to be in good shape. I'm thinking I must have had them serviced when I took it in to get the transmission serviced.
    Henry1jg and HulkSmurf14 like this.
  10. Mar 30, 2025 at 7:56 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :eek2:
    Should have hit me up in a PM - If I had known you were needing one for the platinum I would’ve recommended the other one… you ordered the standard switch panel for the little pocket behind the shifter.
    23Tundy, Florida AF, NWPirate and 3 others like this.
  11. Mar 30, 2025 at 7:58 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Looks good in the end - glad you got it to work.
  12. Mar 30, 2025 at 9:24 AM
    Tboh1870
    Tboh1870 New Member
    Herman
    Just starting reno
    Lord I hope not or the boss will be pissed ... some pics so far
    20250330_120717.jpg 20250330_120705.jpg 20250330_120647.jpg 20250330_120622.jpg
  13. Mar 30, 2025 at 11:59 AM
    5.7TRDProm
    5.7TRDProm What's bothering you?
    Dara
    2018 Cement Tundra SR5
    All stock-ish. Powdercoated blue suspension.
    This scorcery.... The PITA was getting the axle out and back in. I assume it might have something to do with spline tolerance from the nitro gear which I had installed couple years back
    Florida AF, BR73, woods and 1 other person like this.
  14. Mar 30, 2025 at 1:14 PM
    centex
    centex New Member
    Axle seal?
  15. Mar 30, 2025 at 1:26 PM
    justcuz
    justcuz 2.5 Gen Member
  16. Mar 30, 2025 at 1:30 PM
    Gtboosted
    Gtboosted New Member
    Los Angeles
    2020 CSM Tundra 1794
    Yesterday, I added a cooler and used the outlet line to do a complete fluid change. I ran 14 qts thru it. Also added an inline filter before the cooler. Will run the thermostat pinned open for a couple weeks to let the filter catch anything just in case. But I doubt it's really needed. Fluid was black but did not smell burnt.
    2020 Tundra 1794 with 75k.
    Coolant was changed a couple weeks back. Diffs, transfer case, brake, and power steering were done in January. She's set for a while.
    20250328_183347.jpg 20250329_095129.jpg 20250330_111017.jpg 20250330_113436.jpg 20250330_115300.jpg 20250330_131651.jpg
    Piki, DPF88130, Yota303 and 17 others like this.
  17. Mar 30, 2025 at 1:33 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    That looks nice. What product did you use? Got an Amazon link?
    BR73 likes this.
  18. Mar 30, 2025 at 1:54 PM
    justcuz
  19. Mar 30, 2025 at 1:55 PM
    HulkSmurf14
    2014 Tundra Limited
    It was time, for sure! Nice work and finishing of the cooler install!
  20. Mar 30, 2025 at 2:04 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Went out this morning to the test loop. Truck felt good still need to get comfortable again. Made some rebound changes to the bypass tubes. And did a quick roll on at 50mph and clearly it has some traction issues. Pretty wild
    https://youtu.be/IpGKz9fHbzE?si=K1pR0IIKGEnazN59
  21. Mar 30, 2025 at 2:38 PM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    Man I want to do the cooler if anything for easier fluid flushes but it's so dang expensive.
  22. Mar 30, 2025 at 2:53 PM
    Gtboosted
    Los Angeles
    Badass!
  23. Mar 30, 2025 at 2:59 PM
    Gtboosted
    Los Angeles
    Yeah it was about $700 all in for the cooler. Fluid was another $120. You can do it much cheaper with a Hayden cooler and diy'ing the mounting bracket. If you skip the oem hardlines and hoses, you can probably be in it under $300 for the thermostat, cooler, and transmission hose. You just need to get creative and route or protect the transmission hose from the exhaust heat.
  24. Mar 30, 2025 at 3:56 PM
    TheMuffinMan
    Idaho
    2021 DCLB SR5
    When I looked at the kit it was $1200? Could you message me what you did, $700 is more palatable then $1200. I'd rather do the OEM hard lines.
  25. Mar 30, 2025 at 4:11 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    That’s how it’s supposed to be. You have a platinum and they don’t have the cut out. He has a pretty extensive write up on his build/vendor page about having to cut the leather and how to secure it.
    Tripleconpanna likes this.
  26. Mar 30, 2025 at 4:25 PM
    Gtboosted
    Los Angeles
    Yeah that kit is $1299 or $1338 after shipping. I don't know if they charge sales tax.
    I just added my total after taxes and shipping and I was at $740.07. So I saved $600, almost half the price.
    Keep in mind I ordered the oem parts during a 25% off sale. They do them a couple times a year.
  27. Mar 30, 2025 at 4:34 PM
    v-eight
    v-eight New Member
    2013 Tundra Rock Warrior CrewMax
    That's nuts, was on the fence about supercharging mine.
    Let's say I'm not on the fence anymore :thumbsup:
    Henry1jg, woods, HulkSmurf14 and 3 others like this.
  28. Mar 30, 2025 at 4:37 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    Yeah I bought the kit earlier in 2024 but would have gone DYI to save $500 big heads ....oh well it is what it is
    bulldog93, woods and Tripleconpanna like this.
  29. Mar 30, 2025 at 4:40 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Do it! Mind you this is a bit on the extreme end of the spectrum lol
    bulldog93, Mdl, HulkSmurf14 and 3 others like this.
  30. Mar 30, 2025 at 5:44 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Look at these booties
