60centenergy's 2024 Lunar Rock SR5 TRD Sport
Discussion in '3rd Gen Builds (2022+)' started by 60centenergy, Aug 5, 2024.
  1. Mar 25, 2025 at 4:15 PM
    #61
    Reubenski
    Reubenski New Member
    2025 Limited CM, TRD Off-road package, 3" lift
    I almost wired my bed lights the same way but at the time I just didn't like using a wire tap on that wire where it's exposed. I'm curious how you go about yours. There's a guy in the Tacoma forum that makes wiring harnesses for niche setups like this on the Tacoma. I thought about hitting him up to see if he would make a splice/ interrupt plug n play harness for the Tundra's trailer light plug under the bed. The same way RSI uses a Y cable to splice into the brake lights.
    This is his website but apparently you have to PM him on the Tacoma forum to contact him.
    https://fbchs.square.site/
  2. Mar 25, 2025 at 5:50 PM
    #62
    60centenergy
    60centenergy [OP] I'm not superstitious, but I am a little stitious
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    I hear ya. All the wire connections I’ve done/will do to this truck are different than my last Tacoma. I’m not doing any T-taps. I decided all I’m doing will be removable if needed. I think I’m doing similar to the guy you’re talking about from TacomaWorld from how I read it.
    What I do is I find out what wire I want to come off of for the mod I’m doing by using the routing and circuit sheets for our trucks. Then I find the part number of the connector and search it on Google. Usually places like AliExpress have a male to female wire harness that’s the cheapest out there but long delivery time. I’ll order that then use the wire(s) I need off that harness and I’ll plug it in line with the spot I want to “tap” into. This way there is no disruption of any OEM wiring. I can simply remove the harness and connect OEM plugs again.
    I just came back in from trying all this out on the bed lights and the LEDs were dim in the truck bed. I’m thinking I don’t have enough current to power them as bright as they could be from that tap location for the center light... I tested the LEDs before installing them to the rails in the bed and they are very bright coming from a direct source of power so that leads me to my tap point not being good enough.
    Now, I’m deciding what to do. I really wanted to tie it in to that center stop light assembly so it could be on that switch and come on when doors, tailgate, etc open up. I might do the same thing I did for the hood lights and have them on a momentary plunger switch so when the tailgate is opened they would come on. There will inevitably be that time I want to see in the bed when the tailgate is closed though, so still deciding what to do.
    I’m open to ideas!
  3. Mar 25, 2025 at 5:58 PM
    #63
    Reubenski
    Yeah, you're spot on with your interpretation of my post. I wasn't super happy about it but I just wired 3 rock lights with magnetic bases directly off the battery with a switch installed on the inside corner of the bed and tailgate. As much as I wanted them tied to the tailgate, it has worked out pretty well. I have a smart cap on the truck so I still get the bed/ dome light when I open the tailgate but I also get super illumination from three rock lights when I want. It's handy when I open just the back window or the side win-doors. In the end, I'm not nearly as disappointed that I have a separate switch.
  4. Mar 25, 2025 at 6:07 PM
    #64
    60centenergy
    Zack
    GVL
    Right on! I like the sound of that setup. I’m slowly deciding that I’ll just run it to under the hood. I’ll poke around the circuit diagrams later and see if there’s another idea I come up with but it’s looking like direct power is the best with adding a manual switch.
  5. Mar 25, 2025 at 8:43 PM
    #65
    Reubenski
    I ran the power and switch wires along the frame directly from behind the battery down to the frame and then all the way back to the rear tail light. Drilled two holes in the aluminum corner pillar of the bed with a step bit. Top hole for light power wires, bottom hole at about 7/8" for the round switch that has a snap in fit. I bought some pretty bright rock lights from Amazon for $22 for 4. Bolted rubber coated magnets to them and used Deutsch connector y cables to split the power across the three lights. I also used magnet zip ties to secure the split conduit.
  6. Mar 26, 2025 at 3:28 AM
    #66
    60centenergy
    Zack
    GVL
    Looking good. Now if you don’t already have them, time for some bed lights.
    RealTruck likes this.
  7. Mar 26, 2025 at 3:30 AM
    #67
    60centenergy
    Zack
    GVL
    Well done:hattip:
    I like the illuminated switch. Only illuminated when pressed and lights are on?
  8. Mar 26, 2025 at 8:06 AM
    #68
    KMAGS
    KMAGS New Member
    Ken
    STL MO
    2025 iForceMax 1794 Lunar Rock
    Heads Up | PRBs/TG | Tow Mirrors | X4TS Cover
    The 2025 1794 has lights in the bed itself :)
  9. Mar 26, 2025 at 1:17 PM
    #69
    60centenergy
    Zack
    GVL
    Well, I'm stumped on where to pull the power from circuitry back around the tailgate/truck bed. I was outside probing around different connector pins during my lunch from work and didn't come up with anything to use. Looks like Toyota really went out of their way to make wire harness and pin differences for those that weren't blessed with the factory bed lights or tailgate handle light from factory lol
    I think I'm just resorting to running this to under the hood. I'll go to the fuse box again like I did for my under hood lights. I may even just use the same add a fuse location as the under hood lights. I'll measure amp draw for both sets of lights to make sure it's safe enough.
  10. Mar 26, 2025 at 4:06 PM
    #70
    KMAGS
    KMAGS New Member
    Ken
    STL MO
    Maybe this post might help?
    Guy was trying to tap into the same lead for the bed lights near third break light - for his puddle lights.
    Ultimate TUNDRA Wiring Diagrams Collection | Page 7 | Toyota Tundra Forum
    #182/183
  11. Mar 26, 2025 at 5:36 PM
    #71
    60centenergy
    Zack
    GVL
    Thanks for sending. That thread is great @RainMan_PNW did an excellent job gathering all into. The routing and circuit PDFs are the first thing I downloaded for my truck.
    I’ll have to check that spot from those posts. I did check further downstream from that connector and the line wasn’t in the harness near the tailgate. It might be back there though and they used a different harness further downstream that dropped the wire for lower trims like mine.
  12. Mar 30, 2025 at 12:17 PM
    #72
    60centenergy
    Zack
    GVL
    Bed Lighting
    This one took me a while. Probably the most involved one I've done so far but that's because I thought I could come off the +12V lead from the top center third brake light - which didn’t work out. I found the circuit for that and even made my own harness tie in for the lead. Turns out, either I don't have enough current flowing that line to power the bed lights AND the center light and/or my bed lights just naturally need more current. I never ended up measuring the current they really needed and what was in the line.
    I really just wanted the ability to have them come on with the center lights and when doors/tailgate was opened as well as be switched from that inside switch. I still got them wired up though and it's through the battery like most do.
    Parts/tools I used:
    • Tools:
      • A couple beers
      • Wire strippers
      • Solder/butt connectors/some means of connecting wire to each other
      • Multimeter
      • Something to fish with (I use a landscape flag)
      • About half-day to full-day of time (what it took me from all the business of trying to tie into the center light - should be quicker if you just go by my writeup)
    I fished the positive +12V wire from the bed area back to the fuse box near the battery. You could do it the other way around if you wanted.
    The kit gives plenty of wire for this. I ended up making two wire runs bonded together about half the distance (one for +12V and other for ground). Then took a single wire past that to under the hood. The ground wire stopped at an OEM ground bolt at the frame (I’ll show that later).
    Start by tapping on the lights around the bottom of the frame rails. I started on the passenger side where the wire connection would be and walked it around the bed. I tried centering up the lights as best I could on the rails.
    I wrapped the harness run with my harness cloth tape. I found a good spot to take from the truck bed to cavity of the truck (passenger side). There’s a little hole around the bottom of rail/top off the side bed where the rear pillar of the truck bed is.
    Then I took the tail light off and laid to the side to access this cavity area.
    You can see the green of the flag where this pokes through.
    Then I needed something flexible, with some length to it to fish the wire through. My solution? More flags! lol I had this from an old go kart. A broom, extension pole - really anything will work here since it’s a large cavity. I taped the other end to the pole and pushed it through.
    Just leave some extra around where the tail light opening is as we’ll make final connections here later.
    Here’s a pic of the wire through the cavity. I got it above that structural member around the wheel well. I circled a section of the wire here so you can see.
    Here’s the other end of the pole and then I used a zip tie to a bracket for this wire loom where I’m pointing. This is to try to help with support from that long run from the bed location.
    After a zip tie goes there to hold it up, I let it drop down following that loom then went on the INSIDE of the frame following the brake lines and did a could more zip ties (didn’t get a picture of this step).
    Now this is where the 2 wires will split around halfway down the frame. You can see I have wrapped with the cloth tape up to this split. You can also see, I used the round ground connector that comes in the kit here for one wire. Also notice that one wire is green here - I ended up using some trailer wire I had left over but you can get by with using only what’s sent in the kit as he sends plenty - it’ll just all be the same black color so will somehow need to keep them identified.
    There’s a ground point in the top of the frame here. I just backed that bolt out and added my ground wire in line and tightened everything back up.
    Then I just followed those brake lines up the frame towards the front passenger wheel.
    Then I popped the hood and used my go kart flag to fish the wire up towards the fuse box. Here are a couple pics of the location I used.
    Then I routed it by hand under the large wires between the battery and fuse box. Can’t really see the wire here but I have the path drawn in red.
    Then I routed around the fuse box and up the entry where the other wires come in.
    I tested and came up with many constant hot places in the fuse box that weren’t occupied but went with this one for ease of installation. I just used the 5A fuse that came with the kit.
    Okay, so now you’re done with everything upstream. Now to finish the connections downstream where the switch will be for the lights.
    There are 2 switches that come with the hood + bed lights kit. I didn’t use their switch for the hood lights so had both to choose from. I decided to go with the push button one vs the toggle style. Just personal preference really - you could use either one here.
    Here I soldered on a couple longer leads to what came on the push switch then wrapped with my cloth tape.
    Then I poked that through the hole where the bed light wires were ran from back earlier in the post.
    Here are the final connections. The green going to the red wire in this picture is the run from the +12V at the fuse box directly to the bed lights. Then, the 2 black wires are to the switch. I am switching from ground circuit.
    Everything is then wrapped with cloth tape and then zip tied together in a little spool. Then I zip tied this to the small tab that is on a bracket in the well of the tail light area. I did look at this and that’s not used by the tail light when it’s connected so should be good to use.
    Now you should have something like this on the inside of the bed. Now, you can bolt back on your tail light that you took out - just be careful with the wires behind it not to pinch anything.
    Now, how do we secure the switch? I thought about this a good bit. I could have simply drilled a hole in the bed and had this mounted nicely there but my mission is completely reversible and no extra holes. So… I made myself a fancy holder for this on my 3D printer!
    I did a quick design where it is mounted to the back of the bed rail. My bed rail is dropped on brackets and has space in the back since I have the top tri-fold cover. I designed it where I can use an M8 bolt with a captured nut on the back end since I couldn’t get a tool up there to hold the nut when tightening the bolt from the front end.
    I used some transparent PETG. Yes, I probably should have used black but I ran out of it recently and this is all I had. Don’t roast me too bad lol
    Here it is installed on the rail. It allows other items to slide past it on the rack.
    This is the final product! Best pic I got once finished. Everything works great and my mount for the switch is very secure - that PETG material is strong.
  13. Mar 30, 2025 at 12:56 PM
    #73
    60centenergy
    Zack
    GVL
    Illumination Wires Source
    This is a little project to tap into the ILL+ and ILL- circuit from the combination switch assembly. I had originally tapped into the radio harness for this circuit but decided I wanted to change this. I also have future plans for the combination switch assembly (possibly going to add my own switches here one day).
    Parts/tools:
    • Harness male to female for the 90980-12553 connector - $10.59 shipped - funny enough this harness is advertised as 12pin but I looked at the pic carefully and also confirmed when it came in it is actually the 16pin connector we need and does indeed match the OEM connector part number that we were looking for
    • ~5’ of wire - 2 colors (5’ each wire) (preferably green and white to match OEM colors) - I had some lying around the shop
    • Wire cloth tape (see my above posts where I’ve used this)
    • Tools:
      • Wire strippers
      • Solder and soldering iron
      • Landscape flag for fishing
    Use your wire strippers to GENTLY strip back about a quarter of an inch of sleeve to expose the #8 and #9 wires roughly in the middle of the run from the harness.
    I try and follow the OEM colors for things. #8 is ILL- and #9 is ILL+.
    Then I wrapped the solder points with electric tape then some length of the cloth tape on top of that.
    Then I took apart the dash up to the combination switch assembly. Then I tied on the end of the wires from that hadn’t been connected yet to the end of the glad and led down the cavity with the color end of the flag.
    I routed it along the under side of the steering wheel and then popped the driver side access panel to get the wires from the other end. You can see the rough route here.
    Then I changed up my connections from my past mods to date from the previous run I did. The blue wire nut is the ILL+ connections, orange wire nut is still the grounded connection (for my footwell lights), and the grey wire nut is for ILL- connections.
    Then I plugged the wire harness in line with the combination switch assembly and tried everything out and it went great! Then I disconnected the illumination wires from the modified radio harness from my anytime backup camera mod I did earlier.
    This will be useful for any other switches I add in the future I can come off these wires as a single source point.
  14. Mar 30, 2025 at 1:31 PM
    #74
    lapoolboy
    lapoolboy New Member
    The wire nuts were only used for testing purposes and you're not leaving them, I hope? Wire nuts have no place in a vehicle.
    60centenergy[OP] likes this.
  15. Mar 30, 2025 at 1:38 PM
    #75
    60centenergy
    Zack
    GVL
    I hear ya. I just have them there for now. They’re taped tight too (after that pic I posted).
  16. Mar 30, 2025 at 8:18 PM
    #76
    60centenergy
    Zack
    GVL
  17. Apr 2, 2025 at 6:18 AM
    #77
    Yawtzee
    Yawtzee New Member
    2010 Rock Warrior
    This is gorgeous!
  18. Apr 2, 2025 at 1:31 PM
    #78
    60centenergy
    Zack
    GVL
    Thanks!
  19. May 13, 2025 at 12:05 PM
    #79
    60centenergy
    Zack
    GVL
    Wireless Charger Addition / Upgrade
    My rig didn't come with the wireless charger... Oh well, I heard it was crap anyway. The best ones I have seen so far are the Slee Offroad version, Beat-Sonic version and EEF version which all utilize the current wireless charger location. It looks like the Slee Offroad and Beat-Sonic ones give you 2 wireless charging pads and the EEF just has the one. The only other contender I've seen is the scAmazon one that works in the top center tray area but have heard bad things about phones getting hot there due to direct sunlight exposure.
    I didn't want to pay the prices of Slee, Beat-Sonic or EEF so I decided to create my own. My design is meant to cover up the center cavity area and make it a tabletop with wireless charger insert. I get how this may not be super popular, but if you're like me, that center cavity area is just a spot for extra junk anyways so I didn't mind covering it up. The best part is it's not a permanent install and all of it is reversible to any OEM parts in that area. I hope some here find this helpful!
    This upgrade is geared more towards those that didn't get the wireless charger from factory. The steps on creating the wire harness and the connector I used and all that you can still do if you want, but it may be easier to just come off the wireless charger connector closer to the trim piece if your rig came with the factory wireless charger.
    Parts:
    • (1) Belkin Magnetic Wireless Charging Pad 15W - $36.96 - link
      • Yes, this is an expensive magnetic wireless charger but I was looking for something that had a step feature so I could hide it and have a small bit protrude in my assembly - also Belkin makes great products so you're paying for quality
    • (1) 58802-0C030-C1 center console wireless charger trim piece (pic on the right) - $34.98 upload_2025-5-13_14-24-36.png
      • Those that have this piece installed from factory, you won't need to get another one! You will just need to take it out and uninstall the wireless charger piece from the trim piece
      • Those that have the standard non-wireless charger trim piece (like I did) here will need to get ahold of one of these pieces for my mod here to work
      • I did create a version that could be installed with the non-wireless charger ready trim piece (like I had from factory), but there wasn't a good way to get the wires routed to it without making a gap in the trim somewhere - if you're interested in this other version, just let me know I still have the files
    • (1) 12V to 5V 3A 15W USB output converter - $8.99 - link
    • (1) 90980-12498 male 2 pin connector with wire - $4.23
      • I got mine on AliExpress but looks like the link is dead now. Here's one on scAmazon you could check out but price is high
    • 3D printed Flat top wireless charging insert
    • 2 sets of ~3ft of wire - two separate colors - free (I had some lying around from past projects)
    • Harness cloth tape - free (I had some lying around from past projects)
    • (1) two pin wire connector - free (Had this lying around from another project - This is to connect the wire to a USB end - you could terminate any way you want)
    Tools:
    • Pry trim tools
    • Wire strippers
    Remove the top center tray and unplug the cigarette lighter plug end and connect your new harness in WITH THE TRUCK TURNED OFF. connect your 2 pin male connector with short pigtail wires to the plug end in the truck. Then connect your multimeter to the wires. Turn the truck to on position (don't have to start it) and see what the readout of voltage is - if it's negative, then swap the multimeter leads to get positive. Once you get positive ~12V readout then you know which one is your positive and which is your negative.
    Create your wire harness from the male connector. I made my positive the "green" wire and my negative the "black" wire below.
    Now you will need to take out all the trim up to the get out the center multi-switch panel (the one with the E-stop on there). This gives you space to feed your tape or landscape flag (in my case) to feed the wires. Notice this is an older pic from another mod where I still had my solid non-wireless charger trim piece installed.
    You can go ahead and feed the wires down with the tape or flag or whatever you used to feed wire.
    Next step for those WITHOUT the 58802-0C030-C1 wireless charger trim piece
    Now, I had to pop up the entire cupholder and shifter trim piece to get the non-wireless charger solid trim out of the cavity. I was able to do it without removing the shifter knob but it is very tight. Removing the shifter knob will help with this and clearance but I just dread doing that. Once I got that out, then I switched it with the 58802-0C030-C1 wireless charger trim piece that has the opening for the charger itself.
    Next step for those WITH the 58802-0C030-C1 wireless charger trim piece
    I won't know these steps very well, but for those that have the factory wireless charger trim piece, you'll still need to remove it so you can remove the wireless charger from the trim piece itself. I don't know how this is done but it may be disconnecting a plug and then some screws that hold the wireless charger in place.
    Now you can put all trim back together, being careful not to pinch any wires. Then feed your newly created harness with open wire ends through the large opening.
    Now I connected my DC converter to the wire ends with a 2 pin connector I had. You could connect this a number of ways but this is a combination of what I had lying around the shop and ease of installation.
    Now's a good time to introduce my design for the wireless charger mount. I have a universal insert that is Tundra themed with the wireless charger trim insert snapped into that, then a cover on the back for the opening where the factory wireless charger used to be.
    Here is my assembly model showing everything.
    I printed the universal center console insert and the wireless charger insert out of PETG. The hole cover is out of TPU as I wanted that flexible. Don't get caught up on the black vs. white pieces I just wanted to print in different colors to show the difference in the pieces. Production run of these would all be black (unless someone wanted a different color and that could be done).
    Here are some pics the prototype pieces sub-assembled. The white piece here snaps into the black piece. The white piece has snaps designed to hold this specific Belkin wireless charger.
    Going back to the wireless charger install from the wiring, I connected my female USB end to one of the cords I got in my entertainment package for the truck to connect to the Belkin wireless charger. Then I snapped the wireless charger in place in the white piece.
    Then I inserted my TPU cover piece in the hole where the wireless charger would be - notice I have a small cutout for wires to pass through on the bottom right.
    It's hard to see, but I wrapped my tabs that hold the universal center console insert with some of the cloth tape I wrapped for the wires. This is so the tabs don't scratch the inside of the cavity and so there's no noise or vibration. I've had my prototype installed for a month or so now and it's sitting in there nicely.
    The last step is just to nestle it in place and it fits in nice and snug. You can always lift it right back out to do anything you want in the center console area or remove it if you need to.
    Enjoy!
    Oh, and the reason I am calling this main black piece a "universal" center console insert is because my plan is to have different things you can "snap" in place where the white piece is. For example - I could make 2 cutouts with partitions for 2 of these wireless chargers if you wanted to have 2 instead of 1 like I have in the prototype. I also am thinking about relocating some switches and buttons and this is a good spot for something like that. Stay tuned for some of those updates in time...
    ElJefe77 likes this.
  20. May 13, 2025 at 12:22 PM
    #80
    Linuxrules
    Linuxrules New Member
    2024 Tundra
  21. May 13, 2025 at 12:30 PM
    #81
    60centenergy
    Zack
    GVL
  22. Jul 7, 2025 at 8:09 PM
    #82
    60centenergy
    Zack
    GVL
    Slim Credit Card Key Fob Programming
    I decided to go for this slim key fob that lots were talking about. I ended up getting mine from Fred Anderson Dealer for $178.78 out the door shipped to me. That was a steal considering it retails for ~$320. It was a 4th of July sale and free shipping. The only other thing I paid for was the activation code for $15. Here's a thread that talks more about this key card.
    I programmed this myself after I got the key. You don't need the dealer if you have the right tools and process and I'll go over that below.
    Background - I did try and first get this from fleBay for ~$100. It DID NOT WORK. Many folks on the main thread talk about this but I saw some fleBay reviews on how some were able to get it programmed so I decided to try it since there were free returns. I can definitely say it wasn't due to the process I followed, it was definitely the key that was the issue. I received this key without it being in the OEM packaging even though it looked and felt like the real thing. There was some issue with it. So just get one from the dealer, don't try fleBay.
    Parts & Tools:
    • 8990H-A1010 for the slim key fob
    • 69515-12350 for the slim metal physical key OPTIONAL (I haven't gotten this, yet - may one day but decided I'd start with the fob)
    • Computer with Techstream or access to Techstream (V18 is what I have and used)
    • Techstream OBDII dongle to USB (If you have Techstream, you should have this)
    • Phone (or something with a camera that can access the internet) to purchase a Toyota Rolling Code (I paid $15 for mine)
    • Make sure your truck is DTC free (I believe this means error code free - you'll need to confirm this with a scan tool or Techstream before continuing)
    • About 30min of time
    This is what my key fob looked like coming in from Fred Anderson. I like ordering from them since they are always great with prices and they are not too far away (NC shipping to SC is pretty quick).
    You need to connect your cable from OBDII to computer, turn the truck to ON position (don't start engine, just press the start button twice to get to ON), then jump into your Techstream.
    Then under All ECUs, click on Entry&Start, then continue.
    Then click Utility and continue
    Then Key Code Registration and continue
    You'll see a screen with some instructions you’ll have to confirm then this is where it gets interesting. Like I said earlier, make sure your truck is DTC free before continuing!
    You'll be greeted with the next screen that will have a seed number with 4 lines of data, then another box that asks for a Pass-Code number.
    On your phone (or tablet or whatever you have as another device that can access the internet and take pictures), go to this site to purchase a Toyota rolling code. This was the best and least expensive site I could find that offered this service. I stumbled across this from a FB post. I also didn't want to ask a sketchy locksmith through WhatsApp for a code...
    Scroll down on that page and you'll need to check the box to acknowledge there's not DTCs or that if the process fails, there is no money back guarantee.
    Then you'll need to input your VIN, then Data 1 (line of info under VIN), then Data 2 (line of info under Data 1), then Data 3 I just chose ADD KEY. Finally, you'll need to take a pic of your Techstream page and attach it there under Data 3.
    Here is a snapshot to help:
    Then click add to cart and checkout - make sure your email address is correct.
    During all this part, make sure you STAY ON THE SCREEN IN TECHSTREAM. DON'T LEAVE OR LET YOUR COMPUTER GO TO SLEEP.
    You'll get an email confirming your order. Then I only had to wait a minute or two and I got another email with the one-time Pass-Code. I then typed this into the Pass-Code box in Techstream then click next.
    You'll see a screen showing the number of available keys and number of registered keys. I had 2 registered from purchasing the truck, like we all should have. The key here (lol pun intended) is to make sure the number of available spaces is more than 0 then click next.
    Now, I didn't get pics of the rest of the process because I was worried about running out of time. At this point you aren't under a time constraint but once you get past the instructions and ready to go you only have 30sec per step to get it done. Yes, it's plenty of time but you'll want to be quick.
    Here is a reference from NHTSA starting on step 13 from the page you open this to and on that shows the screens you should see just so you get an idea of what to expect. Just make sure to separate the keys like it tells you to. You don't want to risk them being too close to each other or the truck ignition to mess it up.
    I followed these steps and it programmed perfectly. Once I got to this final screen, I tested the new fob and it worked just like my other keys!
    I hope this helps others get this done because it truly is a thin key and should work great over time! Now crack open a "beverage" and enjoy :muscleflexing:
    #82
  23. Jul 7, 2025 at 9:30 PM
    #83
    Retroboy1989
    Northern Utah
    This is really cool, but a fair bit of work.
    #83
  24. Jul 8, 2025 at 3:19 AM
    #84
    60centenergy
    Zack
    GVL
    Agree it’s made to be more difficult than it should. I read that Toyota used to let you just add a key in Techstream without the pass code, as long as you still had one working key. That’s the part I find dumb and excessive. Wish it could all just be done there without a code.
    They changed it to require a one time code for all key activity. Just making it more difficult and expensive.
  25. Jul 9, 2025 at 5:53 AM
    #85
    buffaluphagus
    buffaluphagus —————————————
    This is perfect. I was wondering if that rolling code website was legit.
    #85
  26. Jul 9, 2025 at 6:03 AM
    #86
    60centenergy
    Zack
    GVL
    It worked for me. I was wondering the same thing too. For $15, I decided to try it and it worked just fine.
    ScottieBones likes this.
  27. Aug 1, 2025 at 7:44 PM
    #87
    60centenergy
    Zack
    GVL
    AJT Design Oversize Cup Holder
    This one was pretty straight forward. I wanted the full/oversize cup holder and was about to order the one on scAmazon from AJT but then realized they had more color offerings from their website. I ordered this one in Lunar Rock. I finally had some time to install it. Only took about 30 min. The hardest part was getting the shift knob off... Most folks mention that in the disassembly videos but it's for real. So unnecessarily tough.
    There is a nice disassembly video on AJT's site from the link above and they also show how to remove the hinged cup grippers from the original holder to the new one. They're a great company and I think it came out great!
    Pizzanaut and chrisgibbs707 like this.
