Dashboard noise
Discussion in '1st Gen Tundras (2000-2006)' started by NorseFirefly, Mar 29, 2025.
  1. Mar 29, 2025 at 2:46 PM
    NorseFirefly
    NorseFirefly [OP] New Member
    2000 Toyota Tundra Limited
    I bought a 2000 Tundra 4WD at an auction and when I start it, there is a weird noise coming from the center console that will continue even when you turn it off and take the key out. It almost sounds like it's a tape deck or a cd looking for something to load (it does have both and I haven't put anything in it yet) is this normal? Why is it making this noise?
  2. Mar 29, 2025 at 2:49 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    What aftermarket accessories are inside your center console? Any wiring running to it? Really, there shouldn't be anything in there. Pics might help.
    Edit: You have a tape deck and CD player in your center console? Maybe one of them really is acting like it's trying to load something. Pull the fuse and see if it stops :notsure:
  3. Mar 29, 2025 at 3:04 PM
    NorseFirefly
    Well I just picked it up today from the place I got it from. I may have misspoke about center console...it's in the center of the dash. I don't know if this is aftermarket or not[​IMG]
  4. Mar 29, 2025 at 3:05 PM
    NorseFirefly
    The sound is coming from somewhere around this...and it continues for a few minutes even after you turn the key off
  5. Mar 29, 2025 at 3:08 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yeah, that's a factory setup. Nothing electric is behind that as the HVAC is all mechanical so it's either the headhunt or something aftermarket behind it. Pull the audio unit fuse and see if the noise stops.Screen Shot 2025-03-29 at 5.08.35 PM.png
  6. Mar 29, 2025 at 8:01 PM
    Pull the RADIO fuse and see if it stops.
  7. Mar 29, 2025 at 8:03 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    That’s a super cool original piece, I would definitely recommend keeping it even if ya get another head unit. Could be the oem cd is trying to load from the changer or switching between sources, that could make odd sound. I’m not sure about tundra, but 4Runner factory radios left a lot on the table that a HU and speaker upgrade was always needed.
