Help. Changing brakes and this is happening
Discussion in '2.5 Gen Tundras (2014-2021)' started by Damie Street, Mar 29, 2025.
  1. Mar 29, 2025 at 1:09 PM
    Damie Street
    Damie Street [OP] New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Does anyone know what this could be?
  2. Mar 29, 2025 at 1:22 PM
    Tundra family
    Tundra family New Member
    do you have the caliper apart? im looking at the front of a rotor but it looks like the pad is still on the backside. Im pretty confused at what im looking at.
  3. Mar 29, 2025 at 1:23 PM
    JRS
    JRS New Member
    2012 DCLB
    Were you trying to change the pads, or legit, the brakes (calipers)? Cause you just unbolted your caliper. That's the brake fluid port which transfers fluid between both sides of the pistons.
  4. Mar 29, 2025 at 1:51 PM
    Damie Street
    Edsel
    Cool. That's what I thought. I think i removed too much. Haha.
    I just need to top off the brake fluid and I should be good?
  5. Mar 29, 2025 at 1:51 PM
    Damie Street
    Edsel
    It's my first time changing brake pads on the Tundra
  6. Mar 29, 2025 at 1:56 PM
    JRS
    JRS New Member
    2012 DCLB
    You'll need to bleed that corner. There's a few ways of doing it, so look it up. I always work solo and really like the cheap pneumatic kits.
    Be sure to clean the rotor really well with a fast drying brake specific spray.
    ColoradoTJ and Damie Street[OP] like this.
  7. Mar 29, 2025 at 2:17 PM
    Damie Street
    Edsel
    I cleaned them with brake cleaner.
  8. Mar 29, 2025 at 2:18 PM
    Damie Street
    Edsel
    So I need to bleed the corners. What exactly do I look up. Sorry I'm a noob
    ColoradoTJ likes this.
  9. Mar 29, 2025 at 2:20 PM
    AZTundra
    Paul
    Phoenix, AZ
  10. Mar 29, 2025 at 2:48 PM
    We all were noobs at one time or another. Hell, I'm just beside myself you are learning to take pride in your own vehicle.
    Blufin, Terndrerrr, ID-Matt and 6 others like this.
  11. Mar 30, 2025 at 3:36 PM
    Damie Street
    Edsel
    I bleed the fronts today. Everything works great now. Thank you guys! Going to replace the rear pads and bleed the line later this week.
    AZTundra and ColoradoTJ like this.
  12. Mar 30, 2025 at 5:30 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    There are 2 bolts in the back of the caliper to remove the entire caliper from the hub. Do not separate the calipers.
  13. Mar 30, 2025 at 6:04 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Plenty of videos on youtube.. probably should check it out prior to do the rear.. so you have a good idea of what to expect..
  14. Mar 30, 2025 at 6:17 PM
    Tundra family
    You can just pull just the bottom one and flip the caliper up out of the way I believe
  15. Mar 30, 2025 at 6:23 PM
    Danman34
    Danman34 New Member
    Danny
    True. That too. But in reality, you don’t need to remove the caliper at all to change the front brake pads
    Tundra family[QUOTED] likes this.
  16. Mar 31, 2025 at 3:50 PM
    Toyotaloop
    Toyotaloop New Member
    Pittsburgh
    2021 SR5 Crewmax MGM
    Very little so far
    I'll likely get flamed for this, but brakes are best done the 1st time with someone who knows what they are doing showing you how. Not for a self-described total noob who doesn't know what they're taking apart and has to be told to bleed your brakes after opening the brake fluid system.
    This truck is a 3 ton behemoth and your attempt at working on the primary safety mechanism is putting everyone on the road in danger.
    Stick to oil changes until you find a friend who can teach you how to do brakes. YouTube and forums like this can be great resources but can also be very dangerous for the over-eager newbie.
    MadMaxCanon likes this.
  17. Apr 21, 2025 at 8:56 AM
    Damie Street
    Edsel
    I appreciate your point of view. However mistakes are how I learn to do better the next time for this is a mistake that I will not repeat. I didn't endanger anyone because I didn't drive on the road until it was fixed. And I asked the forum for help that it why this community is si great.
    Maybe think back to when you first learned how to do something. But again everyone can have an option. Have a good day
  18. Apr 22, 2025 at 1:38 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Great you got it done...Now you know. And a classic example of a drilled and slotted rotor, holes filled in...
  19. Apr 22, 2025 at 2:09 PM
    That streak in the middle is not good either.
  20. Apr 22, 2025 at 3:57 PM
    Damie Street
    Edsel
    What streak are you referring to?
  21. Apr 22, 2025 at 4:45 PM
  22. Apr 23, 2025 at 7:14 AM
    Damie Street
    Edsel
    Do you think I need to resurface my rotors?(or whatever it's called)
  23. Apr 23, 2025 at 7:15 AM
    Damie Street
    Edsel
    So do you not recommend slotted and drilled rotors?
  24. Apr 23, 2025 at 7:20 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Yeah they simply look cool, surve not function and get filled with brake dust. Next time just go with OEM rotors and Pads.
  25. Apr 23, 2025 at 7:30 AM
    agrestic1
    2016 CrewMax
    Not necessarily . Many use them and like them, personal preference. Me, not so much. My opinion the holes make the rotors weak due to less metal, drilled and slots lead to less surface area for pad contact, .. I do have a set of EBC slotted only rotors, noisy when braking, and the slots have filled in, their time is up and ordered a set of plain rotor and Akebono pads.... Again my take on it..
  26. Apr 23, 2025 at 8:16 AM
    The combination od slotted and drilled are known to cause hot spots and pulsation. Slotted only and cryo treated is a better alternative.
  27. Apr 23, 2025 at 8:18 AM
    Usually slotted and driller rotors are not able to be turned for resurfacing. I'm not aware of any lathe machine that is capable.
  28. Apr 23, 2025 at 8:33 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    OP I wouldn't stress or even think about all the shit everyone above is saying. If the brakes don't pulse, you're fine. The slight discoloration in the center of the rotor would not worry me. The slots and dimples would not worry me, I have those on my truck and have been totally happy with them. Opinions are like assholes, and you're getting a lot of opinions thrown at you that frankly don't matter. If the brakes feel fine and consistent when you push on them, don't sweat it and have fun. And congrats on getting your brake pads installed, I completely agree with your sentiment and think it's great you're willing to dive into things.
    Damie Street[OP] and AZTundra like this.
  29. Apr 23, 2025 at 8:39 AM
    The set on my 2013 pulsated and shook the steering wheel pretty bad...that's why I pointed out the discolored band.
  30. Apr 23, 2025 at 8:43 AM
    snivilous
    SW UT
    If his brakes pulse and shake that's one thing, if his brakes just look like that and feel fine there's no point in him overthinking that something is wrong.
