  1. Mar 27, 2025 at 11:42 AM
    #9241
    RDW
    RDW New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
    Stealing this idea, this looks great!
    SilveradoSwap[QUOTED] likes this.
  2. Mar 27, 2025 at 12:23 PM
    #9242
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Can you supply a link where you bought the console piece? TIA!
  3. Mar 27, 2025 at 1:28 PM
    #9243
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Phase 2 of operation voided warranty, potato pic for plausible deniability
    VF tuner 93 octane +TCU maps, allegedly…
    SnowToy likes this.
  4. Mar 27, 2025 at 1:50 PM
    #9244
    SilveradoSwap
    Well the VF Tuner once removed is supposed to be undetectable so it won’t void warranty if you remove it prior to service.
    Not sure about those maps, I thought the reason for a box like a VF Tuner was to trick the ECU since its locked?
  5. Mar 27, 2025 at 1:56 PM
    #9245
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    There is no box with VF tuner, it’s all direct ecu/tcu flashing, and your vehicle logs every error code. This system sets off all kinds of codes during the flash so I’m absolutely certain they could tell as there is a log of codes. I can absolutely flash it back to OEM but I am assuming that “undetectable” is a fallacy.
  6. Mar 27, 2025 at 1:57 PM
    #9246
    SilveradoSwap
    Looks like an OBD connection, close enough for me, lol. Just not something that stays installed?
    Regardless, always that risk
  7. Mar 27, 2025 at 2:04 PM
    #9247
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    the OBD is just a way to interface with a laptop for flashing. Easily removable and not needed once you’ve flashed everything so it’s not obvious unless you go looking through the code log. Unclear to me how long those are stored but if I can find them, I am sure dealers could too.
  8. Mar 27, 2025 at 2:07 PM
    #9248
    SilveradoSwap
    So whats the improvement?
  9. Mar 27, 2025 at 2:11 PM
    #9249
    Sacul
    Sacul New Member
    2024 Tundra Limited TRD
    Nothing yet
    Nice. Thanks
    SoCal_Erik[QUOTED] likes this.
  10. Mar 27, 2025 at 2:19 PM
    #9250
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
  11. Mar 27, 2025 at 2:20 PM
    #9251
    Daedalus
    Daedalus New Member
    The VW realm I was in for a long time had a ECU modification flag called TD1.
    If you altered anything on the ECM it tripped that and was non reversible
    Goobax[QUOTED] likes this.
  12. Mar 27, 2025 at 2:28 PM
    #9252
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I’ll have dyno numbers tomorrow
  13. Mar 27, 2025 at 9:02 PM
    #9253
    Reubenski
    Reubenski New Member
    2025 Limited CM, TRD Off-road package, 3" lift
    Ya, I thought about using some super aggressive sticky double sided Velcro but erred on the side of more secure.
    Just need to buy a CANM8 interface and reader to link my new light bar in the Pro grille to the high beams.....
    99ways2die[QUOTED] likes this.
  14. Mar 27, 2025 at 9:18 PM
    #9254
    RadixRyder
    RadixRyder New Member
    Anon
    2023 Tundra TRD Pro
    I like the silver mustache on yours.
  15. Mar 28, 2025 at 3:32 AM
    #9255
    SilveradoSwap
    How is the paint and plastics holding up going through a car wash every 3-4 days? Hearing that makes me cringe, lol
  16. Mar 28, 2025 at 9:11 AM
    #9256
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    5100's in process. Perch installed at position #4; +1.8"
    Question to anyone that has installed 5100's:
    What the hell is this washer for?
    The hole diameter is way too small for the piston rod.
    It does fit over the top hat studs, but can't go there.
    Zudrick likes this.
  17. Mar 28, 2025 at 9:13 AM
    #9257
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Are those the Amazon spring compressors? How did they hold up?
  18. Mar 28, 2025 at 9:14 AM
    #9258
    BlackNBlu
    Rich
    MN
  19. Mar 28, 2025 at 9:51 AM
    #9259
    eddiefromcali
    Eddie
    100% Stock
    Good to know. I bought one under the "Shankly" brand but looks exactly the same. Havent used it yet though
  20. Mar 28, 2025 at 10:03 AM
    #9260
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    BlackNBlu[QUOTED] likes this.
  21. Mar 28, 2025 at 10:06 AM
    #9261
    Raven67
    Kentucky
    Installed ARK front splash guards today. Easy install & they fit well & look good. 20250328_124811.jpg 20250328_125141.jpg 20250328_125148.jpg 20250328_125657.jpg 20250328_125705.jpg
  22. Mar 28, 2025 at 10:33 AM
    #9262
    BlackNBlu
    Rich
    MN
    Dangit! I was hoping someone would say they suck and I wouldn't have to buy them. :D:spending:
  23. Mar 28, 2025 at 10:37 AM
    #9263
    BlackNBlu
    Rich
    MN
    Back to the garage.
    Time to do some sketchy shit, doo-dah, doo-dah.
    Hope I get away with it, all the doo-dah day. :boom::annoyed:
  24. Mar 28, 2025 at 10:41 AM
    #9264
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    The washer is for under the bumpstop, it is a spacer to raise the bumpstop.
  25. Mar 28, 2025 at 10:44 AM
    #9265
    BlackNBlu
    Rich
    MN
    THANK YOU!! :headbang:
    Raven67 likes this.
  26. Mar 28, 2025 at 11:18 AM
    #9266
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Are those not good? They are free
    https://www.oreillyauto.com/detail/...macpherson-strut-spring-compressor/ren1/67051
  27. Mar 28, 2025 at 11:23 AM
    #9267
    mach1man001
    mach1man001 New Member
    Rob
    MA
    2024 Limited Crewmax
    Does that use all factory holes or do you need to drill any?
  28. Mar 28, 2025 at 1:40 PM
    #9268
    Volator
    Volator New Member
    Vassalboro, Maine
    2025 Tundra CrewMax TRD - MGM
    Alu-Cab Contour with Crossbars Decked Drawers - Gen 2 Rough Country HD2 Steps Custom 2nd row platform for Dog Kennels Bullet Point Rubigrid Weathertech HP Matts Ceramic Coated Chrome Delete (Vinyl wrapped) Spigen Tempered Glass Screen Protector JDMCAR Central Control Gear Shift Panel Trim Cover Cornfed 2nd Gen 1.5" Front Lift Cooper Discoverer Stronghold AT 295-70/r18 Toyota TRD Exhaust Tip Rok Block tailgate gap seal GG Offroad Camera Relocation kit GG Offroad brake light cable GG Offroad Camera Suction Cup Mounts
    Got my new shoes today... Cooper Stronghold AT in 295/70/R18
    And did the Cornfed 1.5 front leveling kit at the same time.
    Excuse the dirt... mudseason here... and snow coming tomorrow...
    Dfrink, ngoshawk, BlackNBlu and 3 others like this.
  29. Mar 28, 2025 at 1:58 PM
    #9269
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    My engine arrived at the dealership and Monday it’s reborn after 51,000 miles
  30. Mar 28, 2025 at 2:19 PM
    #9270
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    Dave - I'm about to pull the trigger on the bumper - do you see anything that would keep me from removing that Mid-tube ? I'd plan to plasma cut /grind and re-coat it.....Did you do the IM lights in or something else ?
    Look forward to hearing how your Motor swap goes and hopefully positive feedback on the new smoothness...
    PapaDave418 likes this.
