  1. Mar 26, 2025 at 8:34 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Looks great!!
    pitch likes this.
  2. Mar 26, 2025 at 10:05 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    New shoes - Falken Wildpeak AT4W 295/70R18
    Just short of 94k miles on the Falken AT3W in the same size that just came off.
    Also got the Coachbuilder outer tie rod ends installed and aligned, and ended up putting on the 1” Bora wheel spacers as well.
  3. Mar 27, 2025 at 8:26 AM
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    I agree. When one of mine began leaking, I found this out. Luckily, the repair facility is just over the border in Washington and the repair was done in a couple of weeks. IIRC, my shop had a spare that they were able to throw on for the duration of the repair. Love the BP51 setup otherwise. Can’t imagine a better ride, but I’d sure be swayed by shocks that could be repaired by my guys…
  4. Mar 27, 2025 at 9:38 AM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    I also recently swapped out the Southeast Toyota "OEM" version for this one on ebay. The ebay version is much better for the newer phones. Night and day difference. Install was also easy, used the original wiring from the SE Toyota version and it plugged right in. Got to remember that wireless chargers are relatively inefficient...but overall way better with this newer version
    bulldog93 and BR73 like this.
  5. Mar 27, 2025 at 11:08 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
  6. Mar 27, 2025 at 11:49 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    And she’s back. SPD cat-back and the American racing headers is no joke. I’ll try and get some sound clips as we put some miles on the new trans
  7. Mar 27, 2025 at 3:56 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  8. Mar 27, 2025 at 4:03 PM
    RobertD
    Robert
    DFW, Texas
  9. Mar 27, 2025 at 4:04 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
  10. Mar 27, 2025 at 4:09 PM
    CaptRussia253
    Ruslan
  11. Mar 27, 2025 at 4:13 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
  12. Mar 27, 2025 at 4:36 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    I Work in Greenville and live near Clemson / Seneca. Up and down 123 and 85 all week long. The Tundra is my daily driver. 99,000 miles in 4.3 years.
  13. Mar 27, 2025 at 6:30 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Was your tie rods or tie rod boots hitting the coilovers?
  14. Mar 27, 2025 at 6:32 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  15. Mar 27, 2025 at 6:32 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Spare unit
    Tripleconpanna likes this.
  16. Mar 27, 2025 at 7:37 PM
    VUDUBLU
    VUDUBLU New Member
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Replaced my front bumper with a Chassis Unlimited steel bumper. I did a lot of research to find one that I could color match easily to match my OEM plus look I was going for. Finally no more rubbing. I’m really happy with the quality of the bumper and will lily be adding their rear bumper soon. I also put my new MT tires on. Went with 305/70/18 since they measures out to a little over 35” tall.
  17. Mar 27, 2025 at 7:49 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    What made you choose atw4 over K03s? Brand loyalty since your atw3 setup worked so well?
  18. Mar 27, 2025 at 9:35 PM
    Gtboosted
    Gtboosted New Member
    Los Angeles
    2020 CSM Tundra 1794
    My OEM parts I needed for my cooler install finally came in today. They must have got a lot of orders for the 25% off sale.
    After work, I started assembling the cooler and thermostat in anticipation for the weekend. The cooler is very high quality. I lined up the atf fluid for a photo and seeing all makes me so happy to know that by this weekend it will be all fresh fluid in the transmission and everything else. I already did the coolant a couple weeks back. Two months ago the truck got a brake fluid flush, power steering fluid flush, and all new fluids in the diffs and transfer case. So much satisfaction and peace of mind:bananadance:
    All in for the cooler I'm at about $700. Then the 18qts of atf ws fluid and 3 gallons of coolant was $160. I got so much atf fluid because a local mechanic sells it cheaper by the case of 6 so I figured might as well have extra and run the fluid till it comes out clean. I may run 14qts thru it and leave 4qts for a drain and refill in a couple years.
    Henry1jg, Jego, WAtundra4x4 and 9 others like this.
  19. Mar 27, 2025 at 10:00 PM
    RainMan_PNW
    Casey
    Clark County, WA
    No.
    Things were close, but clear.
    I just wanted a splash of red mostly. And @memario1214 happened to be there when I had a moment of weakness and a pocket of cash.
    Mater, Tunrod, bulldog93 and 9 others like this.
  20. Mar 27, 2025 at 10:05 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    What are those guages on the steering column?
    BR73 likes this.
  21. Mar 27, 2025 at 10:15 PM
    RainMan_PNW
    Casey
    Clark County, WA
    In the 300k miles on my first Tundra, I ran two sets of Duratracs and two sets of KO2s after the factory tires. The KOs performed better for me in our PNW conditions than Duratracs, but 50k miles was a stretch to get to for life and at the end they would get loose on wet pavement (but not nearly as bad as the duratracs)
    I had still planned on KO’s on this truck when I bought it because that’s what I was familiar with (I think the KO3 was just becoming available at that time), but everyone was getting excited for the Wildpeaks and the price back then was significantly cheaper than the KOs (I paid $210/tire for the Wildpeaks in 2020). So I took a chance for what was easily a $500 discount over the KOs for me.
    Fast forward to about two months ago when I started seriously looking at replacements - I had over 90k on a set of tires that was still working as well for me in our winter conditions as they did when I got them over 4 years before, while never wearing strange or getting loud. And the price for new ones is essentially the same or still a little less than the current KO in the same size.
    So, yeah, maybe a bit of a gamble that their new version actually meets/exceeds the previous generation, but also easy to go back to a brand when I’ve had such good luck with what they claim to have improved on.
  22. Mar 27, 2025 at 11:18 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Which grill marker lights are you running? I kinda wish mine weren't smoked, but they fit like yours as well. I prefer these style than say Yota LED's being a small 'dot'
    Tboh1870 likes this.
  23. Mar 28, 2025 at 3:57 AM
    Tboh1870
    Tboh1870 New Member
    Herman
    Just starting reno
    Sharp bumper!
    Easy install?
    Search Chassis Unlimited ... ?
    Anxious to check out the rear too ...
    Vr0ck, HulkSmurf14 and BR73 like this.
  24. Mar 28, 2025 at 4:43 AM
    centex
    centex New Member
    Looks like boost and AFR.
    HulkSmurf14 likes this.
  25. Mar 28, 2025 at 5:45 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Painted the inside of the tail lights. Inspired by @TRDFerguson and @BlueRibbon4x4 build thread. i was not about to cut up the expensive oem piece. Ordered a pair from Amazon for $60, can of krylon fusion satin black, some clear silicon and went to town. Turned out good, imo. The plastic cutting disc for the dremel is a little thick in my opinion. End up using 2/3 tube of the 3oz permatex clear silicon sealant. Look really messy from the back. From the front? Looks real nice. Perfect amount of darkness. I was going to pay $150 to get them and the 3rd brake tinted. But, im happy with how it turned out. Hopefully i sealed it good enough to keep condensation away. Fitment was rather good. Driver’s side had a slight gap at the top. But you wont notice it unless you’re looking for it. But that could also from me cutting it and then misaligned when glueing back. It shifted slightly down.
  26. Mar 28, 2025 at 6:02 AM
    HulkSmurf14
    2014 Tundra Limited
    They look sharp!
    Tripleconpanna and BrandonL812 like this.
  27. Mar 28, 2025 at 6:15 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Turned out great! Awesome mod to keep the brightness of the OEM lights.
  28. Mar 28, 2025 at 6:19 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Nice job!
  29. Mar 28, 2025 at 6:20 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Aem gauges- left side is air fuel ratio, right side is boost psi.
  30. Mar 28, 2025 at 6:35 AM
    VUDUBLU
    VUDUBLU New Member
    2019 TRD PRO Tundra
    I had no issue with purchase or delivery from Chassis Unlimited. They are based out of California. it’s a three piece bumper to it assembles easy, and install wasn’t bad. I did it in the garage with a floor jack, and the help of my 9 year old. The rear bumper is built in the same 3 piece design.
