ABS/Parking Brake/ATRAC Control Lights
Discussion in '2nd Gen Tundras (2007-2013)' started by worktruckwhite, Apr 20, 2022.
  1. Apr 20, 2022 at 5:00 PM
    worktruckwhite
    worktruckwhite [OP] bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Hey y’all,
    Had this problem a few weeks ago they shut off while driving. Merged on the interstate yesterday, dash lit up with those lights.
    Were on for the entire drive of like 2 hours. Parked the truck, next morning they’re gone.
    Called a friend at the dealer (who said I was probably good to drive it, which is why I did) and she said probably a speed sensor. Does that sound correct?
    thanks
  2. Apr 20, 2022 at 5:05 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Probably need her to connect Techstream to see what the speed sensors are reading. Otherwise she's merely guessing which is about all that can be done without some sort of data.
    worktruckwhite[OP] likes this.
  3. Apr 20, 2022 at 6:31 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Well there are at least six speed sensors on your truck, so that's a good play on the odds. There are codes to read that would indicate what needs to be looked at.
  4. Apr 20, 2022 at 8:13 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    4 wheel speed sensors, 1 per wheel and tire that feed a signal to the ABS Ecu. The ECU is throwing the trouble code and generally it does these when it’s not happy with one or more of the wheel speed sensors.
    2 speed sensors in the transmission but they are only used by the engine ecu to monitor shaft rotation speed for shifting/transmission control. They are not tired to the ABS System.
    Agree, when the dash lights up like crazy again, drive to Toyota and put Techstream on it to read the codes. Careful as somtimes turning the key off can reset the codes.
  5. May 5, 2022 at 8:21 AM
    worktruckwhite
    Charleston, SC
    2010 White Crewmax
    Alright, I got the codes.
    C1300 - Skid Control ECM
    C1226 - SA2 Solenoid Circuit
    C1225 - SA1 Solenoid Circuit
    going to do some googling but any advice would be appreciated
  6. May 5, 2022 at 2:22 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Also worth checking, a dying battery on its way out will cause all sorts of odd issues and alerts, as the systems don't get full voltage all the time to function as they should. Worth a check especially since your alerts come and go.
    True about all the sensors and checking for any codes mentioned above. But quick and easy is checking battery condition and any auto parts store can do a free battery load test.
  7. Sep 17, 2022 at 11:44 AM
    GDH75
    GDH75 New Member
    2011grey tundra Dbl cab TRD offroad
    I am having the same codes on my 2011 tundra. Were you able to find what caused it? My sensors looked fine, not sure what else to look at.
  8. Apr 22, 2024 at 4:39 PM
    Brittonv
    Brittonv New Member
    Having the exact same codes. What did y'all do to fix it?
    Out of curiosity I am running 35" tires. Could that be a contributing factor
  9. Nov 1, 2024 at 11:46 AM
    Websale
    Websale New Member
    Yesterday on Halloween I have the exact same thing going on with my 2011. It seems as soon as you get up to about 15 mile an hour when the door is locked the lights come on as well. I cleared the 3 codes One time and now Next time I drove it I got two different codes and these three so far have not come back. I now have a C1310 Active booster solenoid EV and HV System malfunction, and C0278 Open circuit in ABS solenoid
  10. Mar 27, 2025 at 6:09 PM
    FyreFysn85
    FyreFysn85 New Member
    I just had this exact situation come up. Did you find a resolution? I’ve changed 4 wheel sensors and got a new battery. Still no solution. I noticed alternator is running 13.3 volts when idling with headlights and A/C on. Unsure if the alternator is dying and causing electrical issues? Mechanic believes it’s the actual
    ABS module which is a $1900 repair
