Cracked Moog Knuckle for 5” Lift Package
Discussion in '1st Gen Tundras (2000-2006)' started by Jester711, Mar 27, 2025.
  1. Mar 27, 2025 at 3:12 PM
    Jester711
    Jester711 [OP] New Member
    2003 Tundra SR5
    Suspension Lift
    I am changing out my hub bearings on my passenger side of my 03’ Tundra and when pressing out the hub from the bearing it cracked the outside edge. Almost looks like a snap ring. Should I file it down to accept the new seal, try and JB weld it back on and sand down, or am I screwed and have to buy a new knuckle?
  2. Mar 27, 2025 at 5:31 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    You need a new knuckle.
  3. Mar 27, 2025 at 5:32 PM
    Moog makes a 5” lift knuckle? You sure??
    FirstGenVol likes this.
  4. Mar 28, 2025 at 5:39 AM
    Jester711
    2003 Tundra SR5
    Suspension Lift
    Figured new one is the case
  5. Mar 28, 2025 at 5:42 AM
    Jester711
    2003 Tundra SR5
    Suspension Lift
    Yes, it no longer carries their badge but my original off of the truck had their stamp on it. Might be Tuff Country now
  6. Mar 28, 2025 at 6:34 AM
    Huh
  7. Mar 28, 2025 at 7:04 AM
    I'm only aware of two companies that mass-produced 5" lifted knuckles, Tuff Country and RCD.
    And unfortunately, one of those two companies (Tuff Country, I think?) recently stopped making the kit, so you may be hard-pressed to find replacement parts if it's the TC kit.
    Your best bet is to call them, and I'd recommend (since they're discontinuing) buying one for the other side while you're at it, since you may never be able to get replacement parts again for that kit.
