  1. Mar 27, 2025 at 2:44 AM
    #9211
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    Looks great. Is that removable to get to inside the fuse box underneath?
  2. Mar 27, 2025 at 4:50 AM
    #9212
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4
    Talon. I purchased the same one about two weeks ago and it arrived within a few days. They are also a site sponsor.
    Sacul[QUOTED] likes this.
  3. Mar 27, 2025 at 5:01 AM
    #9213
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    Great minds think alike?
    (although I just used some VHB tape to mount my BlueSea)
    jacquesc likes this.
  4. Mar 27, 2025 at 5:15 AM
    #9214
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Very nice work. Definitely doing something similar. Thanks for the inspiration.
    Reubenski[QUOTED] likes this.
  5. Mar 27, 2025 at 6:24 AM
    #9215
    Okietundra
    Okietundra New Member
    OKC OK
    2025 Lunar Rock Platinum
    Hopefully finally take delivery of the truck from the dealer after 3 weeks. :turtleride:
    MAC25Tundra and SoCal_Erik like this.
  6. Mar 27, 2025 at 6:47 AM
    #9216
    buzzkill42
    buzzkill42 New Member
    Joe
    2024 Tundra 4x4
    Looks great. Is that body colored fog light bar OEM, wrapped or aftermarket?
  7. Mar 27, 2025 at 7:44 AM
    #9217
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    Thanks! It’s body color painted oem part. I ordered it from paintedoemparts.com
    buzzkill42[QUOTED] likes this.
  8. Mar 27, 2025 at 7:51 AM
    #9218
    buzzkill42
    Joe
    2024 Tundra 4x4
    Excellent, thanks and it looks really good. Last question - how was the install of it?
  9. Mar 27, 2025 at 8:22 AM
    #9219
    Reubenski
    Reubenski New Member
    2025 Limited CM, TRD Off-road package, 3" lift
    It just comes off with the fuse box lid
    60centenergy[QUOTED] likes this.
  10. Mar 27, 2025 at 10:29 AM
    #9220
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Came up with a simple solution for my EZ-Pass since the Rubigrid is in place. Used some magnets I had in my toolbox. Also cleaned up the cord earlier this week. IMG_7872.jpg
    ngoshawk, Volator, mikev25 and 2 others like this.
  11. Mar 27, 2025 at 11:42 AM
    #9221
    RDW
    RDW New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
    Stealing this idea, this looks great!
    SilveradoSwap[QUOTED] likes this.
  12. Mar 27, 2025 at 12:23 PM
    #9222
    SilveradoSwap
    Can you supply a link where you bought the console piece? TIA!
  13. Mar 27, 2025 at 1:28 PM
    #9223
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Phase 2 of operation voided warranty, potato pic for plausible deniability
    VF tuner 93 octane +TCU maps, allegedly…
    SnowToy likes this.
  14. Mar 27, 2025 at 1:50 PM
    #9224
    SilveradoSwap
    Well the VF Tuner once removed is supposed to be undetectable so it won’t void warranty if you remove it prior to service.
    Not sure about those maps, I thought the reason for a box like a VF Tuner was to trick the ECU since its locked?
  15. Mar 27, 2025 at 1:56 PM
    #9225
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    There is no box with VF tuner, it’s all direct ecu/tcu flashing, and your vehicle logs every error code. This system sets off all kinds of codes during the flash so I’m absolutely certain they could tell as there is a log of codes. I can absolutely flash it back to OEM but I am assuming that “undetectable” is a fallacy.
  16. Mar 27, 2025 at 1:57 PM
    #9226
    SilveradoSwap
    Looks like an OBD connection, close enough for me, lol. Just not something that stays installed?
    Regardless, always that risk
  17. Mar 27, 2025 at 2:04 PM
    #9227
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    the OBD is just a way to interface with a laptop for flashing. Easily removable and not needed once you’ve flashed everything so it’s not obvious unless you go looking through the code log. Unclear to me how long those are stored but if I can find them, I am sure dealers could too.
  18. Mar 27, 2025 at 2:07 PM
    #9228
    SilveradoSwap
    So whats the improvement?
  19. Mar 27, 2025 at 2:11 PM
    #9229
    Sacul
    Sacul New Member
    2024 Tundra Limited TRD
    Nothing yet
    Nice. Thanks
    SoCal_Erik[QUOTED] likes this.
  20. Mar 27, 2025 at 2:19 PM
    #9230
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
  21. Mar 27, 2025 at 2:20 PM
    #9231
    Daedalus
    Daedalus New Member
    The VW realm I was in for a long time had a ECU modification flag called TD1.
    If you altered anything on the ECM it tripped that and was non reversible
    Goobax[QUOTED] likes this.
  22. Mar 27, 2025 at 2:28 PM
    #9232
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I’ll have dyno numbers tomorrow
  23. Mar 27, 2025 at 9:02 PM
    #9233
    Reubenski
    Ya, I thought about using some super aggressive sticky double sided Velcro but erred on the side of more secure.
    Just need to buy a CANM8 interface and reader to link my new light bar in the Pro grille to the high beams.....
    99ways2die[QUOTED] likes this.
  24. Mar 27, 2025 at 9:18 PM
    #9234
    RadixRyder
    RadixRyder New Member
    Anon
    2023 Tundra TRD Pro
    I like the silver mustache on yours.
  25. Mar 28, 2025 at 3:32 AM
    #9235
    SilveradoSwap
    How is the paint and plastics holding up going through a car wash every 3-4 days? Hearing that makes me cringe, lol
  26. Mar 28, 2025 at 9:11 AM
    #9236
    BlackNBlu
    Rich
    MN
    5100's in process. Perch installed at position #4; +1.8"
    Question to anyone that has installed 5100's:
    What the hell is this washer for?
    The hole diameter is way too small for the piston rod.
    It does fit over the top hat studs, but can't go there.
    Zudrick likes this.
  27. Mar 28, 2025 at 9:13 AM
    #9237
    eddiefromcali
    eddiefromcali New Member
    Eddie
    100% Stock
    Are those the Amazon spring compressors? How did they hold up?
  28. Mar 28, 2025 at 9:14 AM
    #9238
    BlackNBlu
    Rich
    MN
  29. Mar 28, 2025 at 9:51 AM
    #9239
    eddiefromcali
    Eddie
    100% Stock
    Good to know. I bought one under the "Shankly" brand but looks exactly the same. Havent used it yet though
  30. Mar 28, 2025 at 10:03 AM
    #9240
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    BlackNBlu[QUOTED] likes this.
