Moisture at flange points in exhaust, normal?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundrav82019, Mar 26, 2025.
  1. Mar 26, 2025 at 8:11 PM
    Tundrav82019
    Tundrav82019 [OP] I have all the duckies
    Leo
    2019 Tundra Limited TRD Off Road
    Hello all,
    noticed I have drips from almost every connection point on truck during first starting in AM.
    after vehicle warms up it goes away. No suit of any kind on exhaust.
    others have this normal phenomena too?
    thanks in advance!
  2. Mar 26, 2025 at 8:13 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Normal
    Tundrav82019[OP] likes this.
  3. Mar 26, 2025 at 10:03 PM
    Tundrav82019
    Leo
    Are they meant to drip? Yours does the same?
    At first I thought I had gasket leaks everywhere haha
  4. Mar 27, 2025 at 5:23 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    My ‘21 does the same thing. Normal to me.
  5. Mar 27, 2025 at 5:26 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Normal. Its condensation from warming the engine.
  6. Mar 27, 2025 at 6:03 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Condensation from warming the exhaust.
  7. Mar 27, 2025 at 9:53 AM
    Tundrav82019
    Leo
    Are there weep holes at the base of each connection point and gasket?
  8. Mar 27, 2025 at 9:54 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Just poor connections. Never happens on other cars, with properly machined surfaces and gaskets.
  9. Mar 27, 2025 at 10:01 AM
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    Water is a byproduct of combustion, is sent out the exhaust manifolds as vapor and condenses in the exhaust system.
    AZBoatHauler likes this.
  10. Mar 27, 2025 at 10:08 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    But how does it taste?
  11. Mar 27, 2025 at 10:21 AM
    BeauDacious
    14 DC 4x
    Like bud-light
    Silver17[QUOTED] likes this.
  12. Mar 27, 2025 at 10:26 AM
    Tundrav82019
    Leo
  13. Mar 27, 2025 at 11:17 AM
    Ericsopa
    Ericsopa Old man and the sea
    I considered it pretty normal. But if a liquid can get through, then a vapor, e.g. exhaust gasses, can for sure. When I noticed mine starting to drip, it wasn't too long before I could hear the exhaust leaks. I replaced the gaskets (they were indeed shot) and there are no more leaks of water or exhaust. If you want to be sure, start your truck and without touching (ouch!) the flanges, feel for any exhaust being blown out against your hand. There will be water in the exhaust system and it will evaporate once the hot exhaust heats up the entire exhaust system. Some mufflers have a weep hole at the end of the can to rid the muffler of water.
  14. Mar 27, 2025 at 11:26 AM
    Tundrav82019
    Leo
    I’ll have my buddy look at it, I agree, previously trucks I had never did that. Thank you!
    is the gasket just a insert between the two flanges? Pretty easy to do on own?
  15. Mar 27, 2025 at 12:33 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Yes, they are inserts and super easy to replace. You'll need 2 for the front and 1 in the rear. The rear one is a different size.
    Here is what I used for the fronts..
    The rear FelPro part# 60461
    You can find them at local auto parts store ore Keith at @dirtydeeds sells them on his site
    https://dirtydeedsindustries.com/
  16. Mar 27, 2025 at 12:42 PM
    Ericsopa
    Just did it a couple weeks ago. Not difficult. Might have to soak the bolts over night with a good penetrating oil. Then it's just 30-40 minutes. You do have to completely separate the joints. Check posts 16641 and 16644 in this thread .. https://www.tundras.com/threads/wha...2nd-gen-tundra-today.68/page-555#post-3876030
    TacomaTRD4x402 likes this.
  17. Mar 27, 2025 at 1:13 PM
    TacomaTRD4x402
    Southern California
    Nice! I only knew about the FelPros. I'll probably give those BRE ones a try next time I have to remove my exhaust.
  18. Mar 27, 2025 at 2:13 PM
    Tundrav82019
    Leo
    Thanks all! Appreciate it!
    any videos of install or pictures?
