Trail edition storage
Discussion in '2.5 Gen Tundras (2014-2021)' started by rag9836, Dec 15, 2020.
  1. May 1, 2023 at 8:27 AM
    #61
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    No. There were gaps in the bedliner on trucks that had the boxes from the factory. Or at least there were on mine. Below is a pic of where i put a tie down in the bolt location from where my boxes were removed.
  2. May 1, 2023 at 9:22 AM
    #62
    Bammer
    Monroe, CT
    I have a plastic liner, I should have specified.
    bulldog93 likes this.
  3. May 1, 2023 at 10:05 AM
    #63
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    Ah. That makes a lot more sense. I don't know for sure, but would guess that the plastic liner would need to be removed.
    Bammer[QUOTED] likes this.
  4. May 1, 2023 at 10:40 AM
    #64
    Bammer
    Monroe, CT
    Gracias :hattip:
  5. May 1, 2023 at 11:02 AM
    #65
    2mchfun
    If you haven't already looked into swing cases, those may or may not be a decent alternative. Another option might be a secondary bed floor with drawers or to follow my plan. I'm going to cut a plastic liner to fit on my factory liner between the boxes to gain a slick surface. Then build a secondary deck and cover that with rubberized roof coating. Follow up with busboy totes that will slide on the plastic base. Then simply use a pole with a hook to pull em out for access. Much cheaper than the decked system and I don't even think they make a decked unit to function with the Trail Ed. Boxes either. I just like the idea of weatherproof storage that is secured by the locked tailgate. Water will just flow around the totes, but the contents will stay dry. Topping off with over the bed rail black liner coated aluminum side toolboxes as well to gain a bed height about equal to the cab height. That said, my truck has the suspension mods necessary to handle the loading up of all the storage and it is probably far more storage than the average Joe might need. Good luck!
  6. May 1, 2023 at 11:22 AM
    #66
    Bammer
    Monroe, CT
    Thanks, interested to see how your project turns out. I looked into swing cases, not too keen on drilling holes. I have a crossover box in my truck, I have been swaying back and forth on the trail edition boxes for a year or so... cost, leaks, bedliner removal...:confused::confused::confused:
    2mchfun[QUOTED] likes this.
  7. Jul 9, 2023 at 5:45 AM
    #67
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    One part number is for both boxes?
  8. Jul 9, 2023 at 6:33 AM
    #68
    2mchfun
    I doubt that, I have them and not only are they mirror images of each other, one (drivers side) is also molded to be an insulated cooler. Could they be sold as a set only? Of course, just doubt it.
  9. Oct 15, 2023 at 10:36 AM
    #69
    BeastlyTundra
    BeastlyTundra New Member
    2010 Tundra Crewmax TRD
    Out of curiosity, has anyone tried adapting the storage boxes to an 07-13 Tundra Crewmax? I know the wheel wells in my 10 are more rounded, but I was wondering if the rectangular wells on the 14-21s are maybe a bit longer at the top and would let it fit.
  10. Oct 15, 2023 at 10:39 AM
    #70
    2mchfun
    Good question, maybe you can find a truck and take some measurements to get a better idea.
  11. Oct 15, 2023 at 12:51 PM
    #71
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    These fit any 2nd-2.5gen tundra crew max. The only difference between the gens are the tailgates.
    Meaning you can’t use a topper,cap, lid, etc from one gen to another. Everything else bed wise works 1000%
  12. Dec 30, 2023 at 1:55 PM
    #72
    Squished
    Squished New Member
    I was able to get a set of these installed in my 2016 Platinum Crewmax today with an ARE cap on it. A bit of a project but they fit. I do need to trim the bed mat more but the weather wasn't on my side. Good enough for now.
  13. Dec 30, 2023 at 8:50 PM
    #73
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    These storage boxes only fit on crewmax? Will not work on double cabs?
  14. Dec 31, 2023 at 1:45 AM
    #74
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    What hardware did you guys have to get to make these work? I'm picking up a used set of these boxes later today. Thanks
  15. Dec 31, 2023 at 5:12 AM
    #75
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Gotcha. Thanks
  16. Jan 2, 2024 at 11:40 AM
    #76
    Djayyykiddoh
    Djayyykiddoh New Member
    Deej
    Eastvale CA
    2021 WCP Tundra Platinum
    Once you remove your OEM Bed Rail Tie Downs these get sandwhiched between the OEM bed rails & the bed itself.
    You'll need to remove your inner tie down hooks (near the cab) on both sides, you can re-use that hardware with a large washer to create a seal.
    The rear tie down hooks will need to be removed, you can reuse the hooks but you'll need longer hardware + thick washer to cover the mounting holes.
    WFD473[QUOTED] and ryanwgregg like this.
  17. Jan 2, 2024 at 1:43 PM
    #77
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    That's perfect! Thank you!!
  18. Feb 12, 2024 at 4:17 PM
    #78
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Will I need longer bolts for the rail system?
  19. Nov 3, 2024 at 9:10 AM
    #79
    Kalashnikov 47
    Kalashnikov 47 New Member
    Minnesota
    2018 Sr5 double cab gang
    Quick question does anyone in here running it with the double cab 6.5ft bed? I want to get one, I know it's made for the crewmax and if possible it'll have a gap in the front near rear windows but I don't care for that.
  20. Mar 27, 2025 at 1:37 PM
    #80
    knuckleduster271
    knuckleduster271 New Member
    If anyone wants to know - these will fit on a 07-13 crewmax- I have them on my 2008
