Transmission Service, Drive Belt
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by xmytruck, Mar 27, 2025.
  1. Mar 27, 2025 at 9:53 AM
    xmytruck
    xmytruck [OP] New Member
    Hello
    I went to the dealer today get an my 60K oil change and I requested for them to change the transmission oil as well and the mechanic stated that since I don't tow it does not need to be changed until 100K. Does that sound right? I did not do my 4running until 90K but everyone tell me at 60k you must change the transmission oil.
    He did recommend changing the drive belt because it was glazing and miscolor is that normal for 60K? In the mornings I do hear some squeaking.
    Thx
  2. Mar 27, 2025 at 11:24 AM
    Ericsopa
    Ericsopa Old man and the sea
    Change the tranny fluid! Period! Drive belt? You mean the serpentine belt? Not a bad idea to change that too, depending on not just mileage, but however old you truck is (you don't indicate year).
  3. Mar 27, 2025 at 12:10 PM
    xmytruck
    Sorry its 2021 trd pro reading the service manual it only states to it if you tow.
  4. Mar 27, 2025 at 12:14 PM
    _Spencer_
    _Spencer_ New Member
    2002 Tundra AC 4x4
    Definitely change the fluid, probably a good idea to change the belt since you are hearing a squeak.
    S. Equoia likes this.
  5. Mar 27, 2025 at 12:42 PM
    xmytruck
    Out of curiosity if my transmission had an issue would be evident when they change oil? Truck drive fine i have not real issues. I was taken back when the mechanic said it was not needed.
  6. Mar 27, 2025 at 12:51 PM
    Ericsopa
    You shouldn't see anything in the fluid, except it will likely be a little more toward a shade of reddish brown instead of pretty red color when you compare old to new. If it's really dark, and smells burned, you have the beginnings of a problem. After 60K miles you should be fine, and see very little difference. But this idea of "lifetime" fluid and 100K changes is not good, whether you tow or not. I personally would not go over 50K.
    _Spencer_ likes this.
