Rear axle shifted when installing lift blocks
Discussion in '2nd Gen Tundras (2007-2013)' started by oleyeti, May 27, 2018.
  1. May 27, 2018 at 10:11 AM
    oleyeti
    oleyeti [OP] New Member
    Greg
    Southaven, MS/ Memphis, TN
    2007 White Tundra Limited
    Toytec boss coilover Toytec boss reservoir shocks Icon progressive AAL pack Rough country UCA Ceramic coating Debadge Assault soft tonneau cover bully dog BDX tune
    So I have a problem.... I thought I would install the rear blocks that came with my rough country lift kit myself and my mechanical prowess has led to the axle being shifted a quarter inch to the left and forward of the leaf spring pin. I have no idea how to get it back in place.
    So what happened...
    I had jack stands on the frame of the truck and I was working one side of the truck at a time. The passenger side tire was still on but I had the driver’s side off. I un bolted the driver side I bolts completely (this is where I went wrong) and started to drop the rear axle with the jack and then all hell broke loose because the rear axle hit the ground which sent me into panic mode. I get the axle jacked back up and to my horror the axle shifted and therefore will not line back up with the leaf spring pin.
    I have stuck the U bolts back on and tightened it up just enough so I won’t move anymore but I am scared to drive it anywhere now. I have never messed with leaf spring suspensions before and I’m at a loss. Does anyone have any ideas on how to get it back into alignment? I called around some shops and one guy suggested ratchet straps and a hammer but I’m not entirely sure how I would even do that. I’m a new member and I have been perusing the forums for about a month now and I have yet to find any threads on this issue.
    Spitz10 likes this.
  2. May 27, 2018 at 10:20 AM
    Welcome from Texas, sorry to hear your situation, hope you can get it back
  3. May 27, 2018 at 10:45 AM
    Tundramoney
    Tundramoney Old school
    Earth
  4. May 27, 2018 at 10:46 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    No matter what you do don’t drive it like that. With the wheels off, the u bolts removed and tension removed from the axle you should be able to reposition the axle to line it up.
    dcsleeper408 and 15whtrd like this.
  5. May 27, 2018 at 10:55 AM
    15whtrd
    15whtrd Mr. Blonde
    Loosen up both sides and re-position. Most likely everything shifted being that you let it drop to the ground. You couldn’t of messed up anything too bad it will go back into place.
    TXRailRoadBandit73 and Les7311 like this.
  6. May 27, 2018 at 10:56 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    TXRailRoadBandit73 and 15whtrd like this.
  7. May 27, 2018 at 11:02 AM
    art64
    art64 New Member
    If you have a ratcheting cargo strap, use it to align the center pin to the axle. Pull the axle forward, backward to align pin.
    FREEK and Berdine like this.
  8. May 27, 2018 at 11:04 AM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    That's what I did, ratchet strap to get mine lined up
    FREEK and art64 like this.
  9. May 27, 2018 at 11:07 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  10. May 27, 2018 at 11:17 AM
    art64
    art64 New Member
    I also used my 40 lb kettlebell to bump spring into place.:)
    040Tundra likes this.
  11. May 27, 2018 at 8:52 PM
    oleyeti
    Greg
    So here’s an update:
    I drove the car at rolling speed to firestone which is just around the corner from me. I had an appointment with them anyways to get the alignment done. The mechanic was able to get it in place no problem and only charged me the price of the alignment for everything. It was super scary driving it though
    TXRailRoadBandit73 likes this.
  12. May 27, 2018 at 8:53 PM
    Glad ya got it fixed
    FREEK likes this.
  13. Mar 26, 2025 at 7:55 PM
    FREEK
    FREEK New Member
    Darren
    Olathe, KS
    2019 Tundra Limited Crewmax 4X4
    THANKS FOR THE RATCHET STRAP IDEA!
    Literally saved me inter-cranial hemorrhaging!!!
    Spitz10 and art64 like this.
  14. Mar 27, 2025 at 11:28 AM
    art64
    art64 New Member
    You're welcome!!
    FREEK[QUOTED] likes this.
  15. Mar 27, 2025 at 11:38 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Does anyone have a zerk alignment chart for 2nd gens?
