Spark Plug part numbers: Denso K20R-U, NGK BKR63YA
Discussion in '1st Gen Tundras (2000-2006)' started by ATBAV8, Mar 27, 2025.
  1. Mar 27, 2025 at 10:18 AM
    ATBAV8
    ATBAV8 [OP] Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Hi all,
    Having a hard time finding spark plugs. I've cross referenced Denso and NGK on their sites and it seems these are non-existent. The recommended plugs for 2000-2004 V8 are Denso K20R-U or NGK BKR63YA. I've checked at RockAuto and Summit and neither part numbers come up. I can order from Toyota and still get Denso K20-RU. Anybody have a different, current part number that can be used in place of OEM recommendations. Nothing other than Denso or NGK, please.
  2. Mar 27, 2025 at 10:24 AM
    In cases like this, I go to the following places to look up the part number:
    Denso: www.densoautoparts.com
    NGK: https://ngksparkplugs.com/en/part-finder
    NOTE: At NGK's site you may need to click 'Car/Truck/SUV' box to reveal the year/make/model selector.​
    Given the owner's manual clearly lists those two brands as OEM-level replacements, Id' feel confidence about ordering the higher-end version of either.
  3. Mar 27, 2025 at 10:26 AM
    PS - saving a brother a click:
    I'd personally go Iridium, or at least the Platinum. Iridium is good for 60k IIRC, Platinum for half that.
  4. Mar 27, 2025 at 10:29 AM
    ATBAV8
    Tempe, AZ
    Thanks. Great advice as always.
