  1. Mar 26, 2025 at 9:44 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Yea, that's where I am stuck, the backside which is the 3 clips closest to the console is where I am having trouble with.
    The top side, I can pop it but then it is stuck where the top is and then I am stuck, again....
  2. Mar 26, 2025 at 10:16 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Weird... If you can get a pry tool in there with a flat but somewhat wide blade, you should be able to twist the tool and pop one of the first clips. They are a bit tight the first time, but will pop with firm but steady pressure...
    Another option is to have 2 pry tools, slide one in (leave it in place), then slide the second tool in near the 1st one, move it to where it runs into one of the clips then twist the tool to pop the clip.
    Also, the tool goes in easiest a few inches away from a clip (less retention pressure), then once it's in between the plastic, I slide it toward a clip and begin to twist to pop the clip...
    Or once you have the tool in, slide it closer to a tab, twist the tool enough to create a small space between the plastic pieces then place your finger tips partially into the opening caused by the tool and pry up with your hands/fingers to pop the clips
  3. Mar 26, 2025 at 10:50 AM
    justcuz
    justcuz 2.5 Gen Member
    Removed the decals with rubber eraser to complete debadging process IMG_0242.jpg IMG_0245.jpg
  4. Mar 26, 2025 at 11:04 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Travis, if you decide you want it, and want to cut it by all means it's yours. I *think* the only difference is the length under the seat, but I could be wrong.
    I have that Yota one as I didn't want the newer AJT one. Be prepared to use an exacto knife to trim it a little around the edges. I'm not unhappy with it however.
  5. Mar 26, 2025 at 11:25 AM
    Ghost Rider
    Ian
    Cypress, Texas
    I thought that is a whole sticker, no?
    I used a heat gun to get it soft and peel, then goo be gone to get it cleaned up....
    woods, ATV25 and Tunrod like this.
  6. Mar 26, 2025 at 11:33 AM
    justcuz
    yes that is one piece. I don’t have a heat gun and have had good results with the eraser in the past. Very little residual glue left.
    ToyoMafia, woods, ATV25 and 2 others like this.
  7. Mar 26, 2025 at 11:44 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    I feel like I'm missing something here because I don't see any wire coming off the charger.
  8. Mar 26, 2025 at 11:47 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Take a picture of said unit and let us see? I mean, if there is no wire coming off the charger I am not sure if it is a workable unit, that's how you connect the power to wireless charge.....
  9. Mar 26, 2025 at 11:53 AM
    atc250r
    atc250r New Member
    Image posted by BR73 had no visible wires coming from the charger. I'm very familiar with the Magsafe system and have it in 3 of our cars in various forms but this has me scratching my head.
    https://www.tundras.com/threads/wha...5-gen-tundra-today.713/page-3361#post-3883406
    bulldog93 likes this.
  10. Mar 26, 2025 at 12:10 PM
    Ghost Rider
    Ian
    Cypress, Texas
    I know this is not the exact same one as @BR73 has, I have the same/similar one that he has but since has taken it off and give it to @memario1214
    But the below picture shows a wire "underneath" the unit itself, which you have to route via the grooves to the back and connect to the 12V cigarette lighter wiring to gain power.
    bulldog93 and atc250r[QUOTED] like this.
  11. Mar 26, 2025 at 12:12 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Definitely haven't installed that yet... :anonymous:
  12. Mar 26, 2025 at 12:12 PM
    atc250r
    atc250r New Member
    Ah now I get it. I didn't realize it was the whole little panel that he replaced. I'm new to these trucks (coming from a Tacoma).
  13. Mar 26, 2025 at 12:14 PM
    Ghost Rider
    Ian
    Cypress, Texas
    Right, it is more a whole piece, screw on from the underside.
    It is neat and the finish is clean for sure, but I felt it was PITA to do it, so many little screws to not lose, and the wiring routing ain't exactly ideal, and maybe I have Android, it overheats very easily....
    So I took it off..... But it was a very useful mod for a very un-used area in the arm rest....
    atc250r[QUOTED] likes this.
  14. Mar 26, 2025 at 12:41 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    The wire is routed through the console lid and hinge down through the inside of the console.You're replacing the insert in the lid.You disassemble the lid top and also take the back cover off the console where the acc plug is located then plug the adapter harness into the back of the acc plug then plug the acc harness back up.When I get home I'll send pics.
  15. Mar 26, 2025 at 12:45 PM
    Ghost Rider
    Ian
    Cypress, Texas
    It's OK. I think he got it, I found another unit that showed the wiring.
    BR73[QUOTED] likes this.
  16. Mar 26, 2025 at 2:14 PM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
  17. Mar 26, 2025 at 2:22 PM
    Ozone generator or air purifier.
    Florida AF likes this.
  18. Mar 26, 2025 at 2:23 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
  19. Mar 26, 2025 at 2:31 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    https://youtu.be/TfpgFAeXdA8?si=t-_eTV7GQ5a9JwGx Link to a good YouTube video with Nitro Fish but it's an OEM wireless charger but same install
  20. Mar 26, 2025 at 3:44 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Out with the old and apparently we were hoarding more dune sand
    Mdl, equin, Terndrerrr and 17 others like this.
  21. Mar 26, 2025 at 3:46 PM
    Tundra family
    Tundra family New Member
    You'll never get it all out. :rofl:its worse than road salt.
  22. Mar 26, 2025 at 4:00 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    No doubt lol
  23. Mar 26, 2025 at 5:03 PM
    centex
    centex New Member
    Had one of those as a work car and it was assaulted every time I took off. It had just enough pep that it would flag the camera nanny for abrupt acceleration. Definitely drove it with the mentality of “it’s more fun to drive a slow car fast than a fast car slow.”
  24. Mar 26, 2025 at 6:21 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Long tube action (TWSS)
  25. Mar 26, 2025 at 6:22 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Perfect fit!
    reywcms likes this.
  26. Mar 26, 2025 at 6:27 PM
    PrairiePredator405
    PrairiePredator405 New Member
    2016 4x4 Crewmax 1794
    Great looking truck. I saved it for my own reference when I get around to adding a few things!
    1UP and RustyShackle323 like this.
  27. Mar 26, 2025 at 6:34 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Anyone know of a 3-D printed or other solution to replace the small cup holders in the center console? I already have the chalk-bag mod but would like to replace the console cup holders.
  28. Mar 26, 2025 at 7:01 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    I use two of these. https://www.amazon.com/Expander-Org...874&sprefix=cup+holder+spartan,aps,133&sr=8-1
    bulldog93 and koditten like this.
  29. Mar 26, 2025 at 7:08 PM
    3rdTundra
    Central Texas
  30. Mar 26, 2025 at 8:27 PM
    pitch
    pitch New Member
    Flagstaff, AZ
    2018 TRD CrewMax 4x4 5.7
    Helped the ‘18 grow up! Mish mash lift installed, with new wheels and shoes:
    Eibach springs and sport struts, Coachbuilder .25” shims on each side, Freedom Offroad UCAs, diff and swaybar drops. Rear: ProForm 1.5 shackles, RC shocks, Coachbuilder carrier bearing drop, Torque air bags and cradles, Icon Rebound wheels, and Kumho Road Venture AT51 295/70r18 tires.
    Then, alignment at the local Toyota dealer, and a wash!
