DC rear attic storage
Discussion in '2.5 Gen Tundras (2014-2021)' started by j6y, Sep 9, 2024.
  1. Sep 9, 2024 at 10:40 PM
    j6y
    j6y [OP] Recovering Perfectionist
    16’ Moby Dick
    Has anyone come up with a solution using some kind of pre existing mounting points to mount a roof net in the rear?
    I’ve not gotten around to removing the headliner to take a peek at possibilities..
    Cheers
  2. Sep 10, 2024 at 12:03 AM
    Camshaft700
    Camshaft700 New Member
    Cam
    2021 tundra trd sport
    You can always use rivnuts if any open holes exist behind panels
    j6y[OP] likes this.
  3. Sep 10, 2024 at 12:10 PM
    j6y
    16’ Moby Dick
    That’s a great idea thanks!
    Hopefully there is a spot above the seatbelt.
  4. Sep 10, 2024 at 2:31 PM
    Gobstopper
    Gobstopper New Member
    This is a really cool idea, interested if anything comes up. I have a rear 60% seat delete and this could be a great way to add functionality where head height isn't an issue.
    j6y[OP] likes this.
  5. Oct 2, 2024 at 9:53 PM
    j6y
    16’ Moby Dick
    BE058449-3192-4E1E-A72C-97E6E8BFF87D.jpg C4669989-B806-49F1-914E-387F7B0CA9E2.jpg 5FCECA47-5B99-4BCF-BED7-6A8CA797F8DC.jpg
    This is my fairly simple setup for the rear - m6 rivnuts with SS m6 threaded eyelets.
    Everything is hidden behind the headliner/panel and the fit/finish is pretty good. I’ll be making some sort of bracket off the front belt area, to keep it high and out the way but currently I’ve just hooked it up to the central pillar grab handles to give you a good idea.
  6. Mar 26, 2025 at 12:27 PM
    j6y
    16’ Moby Dick
    IMG_3551.jpg IMG_3577.jpg Just a little update on this project.. Ended up making some ali eyelet/brackets that sit out past the headliner for easy removal of the net and then added some high mounted eyelets on the pre existing grab handle upper mount. Still not 100% sold on the mount behind the headliner because the sheet metal I placed the rivnuts in, is pretty thin BUT its pretty stout and shits high.
