Best shop for Regear in Arizona
Discussion in 'Performance and Tuning' started by Mudstik, Mar 26, 2025.
  1. Mar 26, 2025 at 6:45 AM
    Mudstik
    Mudstik [OP] New Member
    Dylan
    2020 White Tundra TRD Off Road
    Bilstein 6112/5160, Icon wheels, RAS System
    Hey everyone I hope this is in the right forum if not please let me know. Towards the end of this year I’m looking to buy 5.29 gears and get them installed, do any of you have a shop that you recommend in Arizona in the Mesa, Gilbert, Chandler area? Thank you appreciate it!
  2. Mar 26, 2025 at 7:04 AM
    Tundra family
    Tundra family New Member
    AZ differential. They took great care of my Camaro.
  3. Mar 26, 2025 at 7:11 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Erick and Ben at AzToypros took care of mine last year. I've had no issues since.
  4. Mar 26, 2025 at 7:13 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Make sure to take your gears to Ayers gear shop first to get Polished and Cryo treated
    FrenchToasty and TRDFerguson like this.
  5. Mar 26, 2025 at 7:14 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  6. Mar 26, 2025 at 7:15 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    This. I just used them on my Motive 5.29 set. And I’m going to use gearinstalls.com aka Zuk up in Prescott for the install.
    Vizsla likes this.
  7. Mar 26, 2025 at 7:15 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I have nothing to say on the matter.
    FrenchToasty and Vizsla like this.
  8. Mar 26, 2025 at 7:18 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    @Zuk is the best. I believe he’s in Prescott.
    FrenchToasty and mart1nezdaniel like this.
  9. Mar 26, 2025 at 7:20 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    This is true, but you'll need to do leg work first.
  10. Mar 26, 2025 at 7:21 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Yeah, little bit of downtime, but def worth knowing the best guy for the job got it done. I’d at a minimum suggest REM polishing the gears before any gear work gets done.
  11. Mar 26, 2025 at 7:24 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Zuk (gearinstalls.com) near Prescott does impeccable work. You'll have to bring the differentials to him though, he only works on them if they're off the truck, doesn't remove/ install them from the vehicle.
    1. You can remove and take your stock diffs to Zuk if you have the ability to take them out and let the truck sit for a bit.
    2. Find spare diffs to have built by Zuk, then swap them out yourself (what I did), then sell your stocks as cores
    3. Find spare diffs (cores) to have built by Zuk, then have an offroad shop remove your stock and install your built diffs, then sell the stock cores.
    Mater, TRDFerguson and Vizsla like this.
  12. Mar 26, 2025 at 7:29 AM
    Mudstik
    Dylan
    Silly question but what is the benefit from polishing and cryo treating? From the little information I’ve read it makes gears stronger and the “break in” procedure isn’t needed, is that correct?
    TRDFerguson[QUOTED] likes this.
  13. Mar 26, 2025 at 7:36 AM
    Mudstik
    Dylan
    Thanks for the recommendation, did the guys do the break in procedure for you?
  14. Mar 26, 2025 at 7:38 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That’s it. High marks for Mr Ditto!
    Vizsla and Mudstik[QUOTED][OP] like this.
  15. Mar 26, 2025 at 7:40 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    They would have but it wasn't entirely needed since I had mine polished and cryod
    TRDFerguson likes this.
  16. Mar 26, 2025 at 7:41 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You’ll have to do the break in procedure yourself unless you get gears REM polished ahead of time. I think it was $150 a set when I had Ayers do it, and $50 each for cryo.
    Ben/Erik at AZ Toy Pros might sell them pre-polished. But I think Ben only installs gears that are bought through him/State 48 Off-road
  17. Mar 26, 2025 at 7:42 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    How do they do the break in for you? Just drive it around for 500 miles? Legitimately curious
  18. Mar 26, 2025 at 7:45 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I'm going with option 1 in my case, but I'm a little nervous about getting them up to him and back, and then installed, prior to Tundras to Sedona...
    Vizsla likes this.
  19. Mar 26, 2025 at 7:49 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    I think i misunderstood the question. Erick at AZ Toypros mentioned they would do some heat cycling driving within the first few miles after install. The remaining ~500 miles of driving would have been on the customer.
  20. Mar 26, 2025 at 7:53 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Ah gotcha. That makes more sense
  21. Mar 26, 2025 at 8:31 AM
    Mudstik
    Dylan
    Thanks guys for the recommendations!
  22. Mar 26, 2025 at 8:48 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    :hattip:
  23. Mar 26, 2025 at 9:51 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Cryo treatment straitens out the metal molecules so the the metal is stronger. You may or may not need this.
    REM polishing takes that layer of metal off that will get cut in the break in process. Many benefits from this
    1. No need to perform the entire break in process.
    2. All that metal mush from the uncut process won’t be inside your diff housing. No matter how many times you drain n fill, you’ll never get it all out, and this can effect bearing life as well. So REM prevents this.
    If you do both, I think it’s recommended to get the REM first, then cryo treatment. If you go with ZUK, ask him what he prefers. Truthfully unless you’re hammering the diff with high speed, cryo may not be justified. But REM, I’d def recommend.
  24. Mar 26, 2025 at 10:09 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I've got an email thread with him recommending REM polish with cryo treatment.
    texoma[QUOTED] likes this.
  25. Mar 26, 2025 at 11:33 AM
    Another vote for Zuk
  26. Mar 29, 2025 at 12:16 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Yup. Zuk was the one that sent me to Ayers gear shop. I guess he used to work with thos guys.
    Another good thing about Cryo is it sets you up if you ever want to add a supercharger to your rig.
