Having a hard time torqueing anything below 15 ft lb
Discussion in '1st Gen Tundras (2000-2006)' started by StrawberryBlowpopPrincess, Mar 25, 2025.
  1. Mar 25, 2025 at 8:12 AM
    StrawberryBlowpopPrincess [OP] New Member
    2002 sequoia RWD
    I own a torque wrench that says it goes down to 10 ft lb but it truely doesnt. it pretty much stops at around 25ish lb. Dont know why and i never gave it much thought, its very rare i have to torque anything under that...until today
    so im trying to torque down spark plugs at 13 ft pound and valve cover bolts at 7 ft lb.
    is there any tip or tricks for torqueing something that low? im so afraid im going to snap something since the low spec but when i tried to tighten it, i really felt like it had so much play left so i kept tightening it until i decided to give it a rest and come here for help.
    it seemed like the spark plugs never really "catched" and just had so much more room to still be torqued down. is it normal for spark plugs to feel kinda "loose" (well not loose, but just not screwed in very tight, i was barely using any force at all and they just kept turning and turning, was using a 3/8 ratchet)
    same exact thing for valve cover bolts, barely using any force at all, and it just felt like they were still so loose despite me cranking them down quit a bit.
    Buying a inch pound torque wrench is not in the budget unfortunately, so hopefully someone here has some tips or tricks for these low stress bolts/ low torque specs
  2. Mar 25, 2025 at 8:35 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    $15, pick it up today.
  3. Mar 25, 2025 at 8:37 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Plugs….hand tight and 1/8 to 1/4 more or 2 ugga duggas
    VC….53 “ lb = hand tight and couple uggas
    All else fails….German spec always works: Guttentite
  4. Mar 25, 2025 at 8:59 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If you're on a budget, go by feel. You know what 25ft-lb feel like, pull on the same length wrench with roughly half the force. Most small fasteners like that I don't usually bother to "torque to spec" since it's so low. Get it snug plug a little extra.
  5. Mar 25, 2025 at 9:23 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    It's too bad there's not like a loaner tool program out there that maybe an auto parts store offers
    ATBAV8 likes this.
  6. Mar 25, 2025 at 9:26 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    That would be genius.
  7. Mar 25, 2025 at 9:34 AM
    ATBAV8
    Tempe, AZ
    Not sure what you're using for a torque wrench, but this is one item that you get what you pay for. A $20 torque wrench might say it goes down to 10 ft-lbs., but just by the nature of $20 chineseum there's no way it's going to be accurate or even calibrated. Now, I'm not saying you need to go out and buy a Snap-on for some ungodly price, but you can pick up decent ones for around $100. If you're going to be doing much wrenching, it's a worthwhile investment. As for your problem at hand: get the spark plugs screwed down until contact, then just a bit more with a normal 3/8" ratchet. Same with the valve cover bolts.
  8. Mar 25, 2025 at 9:55 AM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
    I own four torque wrenches that span from 11in/lb to 150ft/lb and use all four of them mostly equally... and often. I highly agree with the comments above that they are a worthwhile investment.
    chunk likes this.
  9. Mar 25, 2025 at 10:06 AM
    Snert
    Snert New Member
    2021 SR5
    Harbor Freight has a 3/8” drive 5-80 ft. lb. on sale for $14.99 right now. I have one that I got before I inherited my late father in laws lifetime of tools that included a set of Proto torque wrenches. I’ve used the Harbor Freight one and compared it to the 3/8” Proto and it’s close enough to spec I can’t feel the difference. Probabaly won’t last as long as an higher quality one, and for critical torque specs I’ll always grab the Proto, but the Harbor Freight one does just fine and is dirt cheap. For infrequent use and as a loaner to friends it’s a great cheap tool.
  10. Mar 25, 2025 at 10:15 AM
    bfunke
    bfunke Tundra Curmudgeon
    You’re best off having two torque wrenches. A big one for lug nuts and crankshafts and a smaller inch pound wrench for lighter work.
  11. Mar 25, 2025 at 10:49 AM
    Fedtime
    Fedtime New Member
    This. I use my foot pound and inch pound torque wrenches often because, as you point out, the foot pound wrench either does not adjust down far enough or is not accurate at lower settings. And it is easy to convert inch pounds to foot pounds, and vice versa. Just multiply or divide by 12 - or use an online converter.
  12. Mar 25, 2025 at 11:02 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    When I need to torque in 5 or 6 foot pounds I use an inch pound (1/4 inch drive) wrench. Tekton makes a nice one and it's a good value.
  13. Mar 25, 2025 at 11:05 AM
    AZBoatHauler
    So.Arizona
    That only gets you a little over half way for the LCA bolts. ;)
    Yota303 likes this.
  14. Mar 25, 2025 at 11:58 AM
    Harbor Freight's torque wrenches held up really well in Project Farm's video also, IIRC. But different internal brands from HF than that $15 one IIRC. Hopefully this is the right video.
    https://www.youtube.com/watch?v=HP4uECoH8cc
  15. Mar 25, 2025 at 12:45 PM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Another vote for the HF 1/4" lbs/in torque wrench. It works great.
  16. Mar 25, 2025 at 2:02 PM
    One other point though, maybe it's helpful for folks replying in this thread.
    I don't know who needs to hear this, but a LOT of the cheaper torque wrenches - especially the non-split-beam once that require you to twist a sleeve on the shaft to adjust the torque settings - MUST be set to a specific value when you put them away to avoid them getting out-of-spec.
    Almost every one I've owned or passed on, that is setting it back to the 0ftlb-10ftlb range, and it was etched into the handle or printed. REALLY REALLY cheap ones like the scAmazon Basics brand, may only have that info in the instructions! If you get a good split-beam wrench, you don't need to worry about this. But leaving the torque wrench set to anything ABOVE (or potentially below) that setting can and will result in your torque wrench getting out of calibration.
    Here's an example from Tekton's line, below. I will say, I've been using the larger Tekton split beam (model number TRQ 62203) for a number of years. It's big, it's beefy, and it's never out of calibration. But it won't loosen, only tightens, and is unfortunately a range of like 40-250ftlb I think?
  17. Mar 25, 2025 at 5:18 PM
    atc250r
    atc250r New Member
    I don't think it's just the cheap ones that you're supposed to back off on for storage. I have one Mac and one Snap On I bought in the late 90's, both tool guys made it a point to tell me to back it to the minimum setting for storage.
    w666 likes this.
  18. Mar 25, 2025 at 6:39 PM
    That style pictured, doesn't matter who makes it, I don't think I've ever seen one you didn't need to set to a low (1%-5% level) setting before storage. I'm not a torque wrench guru, but I don't think you need to do it with split beam versions, and the old school ones that flex, with an arrow to point to your torque value. Dunno about the torque sticks they use at tire shops either, never owned one.
    atc250r[QUOTED] likes this.
  19. Mar 26, 2025 at 5:10 AM
    atc250r
    atc250r New Member
    If you're referring to the one in your previous post that's the style I have from Mac and Snap On and that's what the fool dealer instructed me to do. I'm not an expert either. ;)
    shifty` likes this.
  20. Mar 26, 2025 at 6:49 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I agree with multiple torque wrenches. You can "get away" with halfway decent, 10-150 ft/lb wrench for most of what we do. But if you get into doing more and more work, you'll want multiple. I have an inch/lb wrench for lower torques, and I've probably used it 5 times. But when I need it, I need it.
    And on the other side, 150 ft/lb isn't all that high, like AZboathauler said. My torque wrench was a Pittsburgh 10-150 ft/lb model. It did last me almost 10 years. But just last weekend, tightening a third 125 ft/lb bolt, it broke. Maybe it was just time, but I think with the slightly cheaper wrenches, getting up to the higher torques is too much for them.
    What you should expect is that any torque wrench is most accurate in its middle-range. So my former wrench was probably, to make up numbers, most accurate between maybe 50-100 ft/lbs. Much lower or higher and the error gets larger. Not a huge deal with higher torques, but with low-torque stuff that will strip or crack if you go too tight, it's really better to either go by feel like other people mention, or get an inch/lb torque wrench.
    I'm going to Harbor Freight tomorrow when I'm in a bigger town and buying an Icon that goes from 50-250 ft/lb. Might pick a lower ft/lb wrench too, since that leaves a gap between where my inch/lb wrench tops out, and the bottom end of the ft/lb wrench.
    atc250r likes this.
