Stuck Rear Shock Lower Bolt
Discussion in '1st Gen Tundras (2000-2006)' started by sloppylbjs, Mar 25, 2025.
  1. Mar 25, 2025 at 7:13 PM
    sloppylbjs
    sloppylbjs [OP] New Member
    04 SR5 DC 4x4 4.7
    Just my luck that the ‘easy’ bolt gives me problems. I’m replacing the rears and front with 4600s but currently the lower bolt for the driver side rear shock is stuck. I’ve taken the nut off but the bolt won’t budge out. I’ve tried wedging stuff in there but the bolt just spins along with the spacer/bushing. I have the truck jacked on the diff only. I tried fully removing the top portion of the strut and extending it out. I have not tried a proper smaller pry bar but that might be the next step.
    Any tips?
  2. Mar 25, 2025 at 7:21 PM
    Use a drill or impact on the head while you wedge something against the threaded side and the leaf mount
  3. Mar 25, 2025 at 7:22 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    The best way I've found when the bolt is completely fused to the inner metal collar, is to just cut off the bolt with a sawzall and replace the bolt.
    tvpierce and BroHon like this.
  4. Mar 25, 2025 at 7:39 PM
    TILLY
    Massachusetts
    Another reason I recommend cutting it off is because it's almost impossible to isolate and wedge the inner collar and not have it spin in the surrounding rubber. Just my 2 cents of course.
  5. Mar 25, 2025 at 8:12 PM
    Air hammer would make extremely quick work of that.
    KNABORES likes this.
  6. Mar 25, 2025 at 11:59 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Have you tried wacking it with a Big F'n Hammer?
    KNABORES and JasonC. like this.
  7. Mar 26, 2025 at 4:33 AM
    Lots of good answers already but I would lift the bottom of the shock with a pry bar or long screwdriver to take some tension off it and then whack it the bolt out with a dead blow hammer.
  8. Mar 26, 2025 at 4:35 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Inductive bolt heater would come useful in this situation.
    tunder construction likes this.
  9. Apr 8, 2025 at 7:26 PM
    sloppylbjs
    04 SR5 DC 4x4 4.7
    Wanted to give an update in case someone else runs into this. I removed the saddle for the leaf springs to give myself more room but whacking it did nothing. The spacer was basically fused with the bolt at this point. I think heat might of worked but I ended up just cutting the bolt. Gave me an excuse to buy some more tools at least. Total PITA but I’m glad it’s out.
    FirstGenVol, BroHon and rouxster70 like this.
  10. Apr 8, 2025 at 7:32 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    I did lca on a 4Runner with zero rust. Couldn’t get the concentrics out, stuckkkkk. Had sawzall all 4 out, 2b blades a cut. F me that suckkkkeddddd. Glad ya got out. Best
    sloppylbjs[OP] likes this.
  11. Apr 8, 2025 at 7:34 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Given how "simple" of a job you'd expect it to be (two bolts), it's pretty regularly a pain in the ass. Even if everything goes smooth, that top nut is pretty annoying.
  12. Apr 8, 2025 at 7:49 PM
    sloppylbjs
    04 SR5 DC 4x4 4.7
    On 1 side the bottom bolt was stuck, on the other side the top bolt was stuck. Classic.
