Is it the end?
Discussion in '2nd Gen Tundras (2007-2013)' started by CM2007, Mar 25, 2025.
  1. Mar 25, 2025 at 7:10 PM
    CM2007
    CM2007 [OP] New Member
    Northern California
    2007 CrewMax SR5
    TRD Exhaust, Dark Tint, Bluetooth (2020 or earlier) License Plate Camera (2021) Tyger T1 Roll Up Tonneau (2021) Loncky leather steering wheel wrap (2021) Dechromed with Plasti-Dip (2021) Osram Reverse Bulbs (2021) Bilstein 6112s up front (April 2021) 2022/2023: New Head Unit (Android?) Sliders/concealed running boards
    I’ve had a 2007 crewmax for a few years and it’s been flawless until a few months ago. Transmission tops out at 4th gear and at 70mph I’m just above 3000rpm— I have an appointment at a transmission shop since the couple mechanics I called said they done deal with transmissions.
    About a week ago I was making a late night run to wal-mart and a forgotten ratchet strap wrapped around the axle and tore a 20” gash from bed rail to wheel well. It was an awesome sound, but I stood there, stunned, for at least 10 minutes in silence on the dark road. Surprised at the strength of the 1” husky ratchet strap and by my stupidity.
    Yesterday all my door windows stopped rolling down and the power locks only work from the remote. The rear window still works. I went to autozone today and swapped out the pink 30A fuse to no avail, then tried a new P/W Relay in the #1 then #2 spot. Neither worked. After getting home I opened the hood and can now clearly hear the relays trying (clicking) when I press the window switches.
    Is this truck gonna make it?
    was in the process of welding on a loIMG_1494.jpg watertight rack for a rooftop tent and stopped.
    Black@Blue19 likes this.
  2. Mar 25, 2025 at 7:33 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Pictures
  3. Mar 28, 2025 at 8:12 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Bruh...
    Sometimes its better to stop and double check your work some times. Prevents alot of heartburn...
    transmission, drain and fill 1st, pull codes and if you can clear the codes, do it and see if they come back. Worst case a solenoid may need to be replaced.
    Windows, you should look up the TSB for the master window switch and see if your VIN falls within the troubked ones.
  4. Mar 28, 2025 at 8:25 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Your gash is impressive
    vtl, mtucker and Black@Blue19 like this.
  5. Mar 28, 2025 at 8:50 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Dang some giant thought the truck was a tuna can.
  6. Mar 28, 2025 at 8:53 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    That happens only in the cartoons!!!! Dam man that is a sight! Fricken Awesome talking point!:) WOW!
    That would make me sick, sorry you had to go thru that ordeal and being something you did to top it off! I might have took it the extra step and put the ole girl down with a bullet. Then I really would have been sick!
    Retired...finally likes this.
  7. Mar 28, 2025 at 10:15 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Holy SHIT!! That's an impressive strap. Had to be a cringeworthy sound.
  8. Mar 28, 2025 at 11:40 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Fuck it. Just duck it.
    And drain and fill the atf.
  9. Mar 29, 2025 at 5:33 AM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    Hate to say it, but that’s funny shit right there
  10. Mar 29, 2025 at 5:39 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Buy some good rivets and HD rivet gun, I guess?
    SBGibson, OldGuy03 and SD Surfer like this.
  11. Mar 29, 2025 at 6:18 AM
    Tundra family
    Tundra family New Member
    I use those straps (rated at 400 lbs) to hold down a 1400 lb camper. I have them pinched, twisted and knotted and they refuse to break. Never thought I'd see something like this though, I'm both deeply saddened and highly impressed at the same time. Probably good it didn't get into that filler neck, that coulda been even uglier
    Randydw likes this.
