Mirror glass help
Discussion in '2nd Gen Tundras (2007-2013)' started by Vito_R, Mar 24, 2025.
  1. Mar 24, 2025 at 7:20 PM
    Vito_R
    Vito_R [OP] New Member
    Few Scout II, RCSB, and many 2 wheel motos
    Stock RCSB 4X4 TRD
    A friend accidentally broke my driver side mirror. Problem is mine had a color matched top, so I had to pop out the glass. Old one came out as expected, but the new one would not budge and I broke the glass. Well not that is out I see it mounts differently. And I cannot find a replacement online.
    Does anyone recognize this mount? Any idea where I can get a replacement? Or a part number? I does have a CC-151205-L in the molded plastic, but so far that has not helped me.
  2. Mar 24, 2025 at 7:59 PM
    07RCSB
    07RCSB New Member
    2007 Tundra RCSB
    none yet
    I had my drivers side off this weekend when I installed the spotter mirror with turn signal in it. My RCSB is a 2007 and it did not look like that at all. Unfortunately I didn’t take a pic when it was off.
  3. Mar 24, 2025 at 8:44 PM
    Vito_R
    Stock RCSB 4X4 TRD
    Nice, mine is a RCSB too. Yes my original slid straight up with 4 tabs. That is what I expected, but not what I found in the new assembly.
  4. Mar 26, 2025 at 8:41 AM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I have a 2011 SR5, and I recently replaced my side mirror glass (both sides). Mine has the 4 tabs that slide/pop up to remove the glass.
    The one in the picture you posted looks like a replacement for a non-OEM housing. I say that because I tried ordering a cheaper after market housing to replace the housing on the driver's side due to a small damage blemish from the previous owner. The mounting for the glass in the replacement housing looks a lot like the one in your photo. (Caveat: I was installing SpotterMirrors. My SR5 has the heated and power adjustment side mirrors, and I wanted to have the turn signals along with the blind spot mirrors, and I wanted to keep the heated and power adjustment features. I decided that I would replace the driver's side housing while I was at it, so I ordered a cheaper Limited housing that was not OEM. It ended up not working for me because the glass mount in the cheaper housing looked like the one in your photo, and the SpotterMirror glass has the mounts that fit my original housing. I ended keeping my original housing and just living with the blemish). That's what I get for trying to be thrifty.
    The glass in your photo looks like a replacement for an aftermarket housing, and I don't think it will work in your factory housing without some "alternative engineering".
  5. Mar 26, 2025 at 8:55 AM
    Thumper_6119
    Here is a possible option for replacement:
    https://www.1aauto.com/toyota-sequoia-tundra-driver-side-mirror-glass-trq-mga08562/i/1amrg00248/1126697/2007?gad_source=1&gbraid=0AAAAAD_ve_mcq7djihlactF7J8b-YfALg&gclid=Cj0KCQjwy46_BhDOARIsAIvmcwOB9v6hsiNse_Ja11ahmgN5rnsnv8lGLhzuc3qTN1Mlu51URsUFHkQaApliEALw_wcB
    Otherwise, you're likely going to have to look at an OEM replacement for a Toyota parts house. Here is what I was able to find for OEM:
    https://parts.olathetoyota.com/oem-parts/toyota-mirror-glass-879060c030?c=bD04Jm49U2VhcmNoIFJlc3VsdHMmYT10b3lvdGEmbz10dW5kcmEmeT0yMDA3JnQ9bGltaXRlZCZlPTUtN2wtdjgtZ2Fz
    (you'll to double check the specs on that).
    If you're interested in SpotterMirrors, you can get them here:
    https://spottermirror.com/p/toyota/tundra/blind-spot-mirror-for-2007-2021-toyota-tundra-new-design/
    They sell them individually, for each side, and unless you want to have the blind spot mirror on one side and not the other, you'll need to order the pair. It does require connecting the new glass wires to the factory harness. (Easy install if you're comfortable doing that).
  6. Mar 26, 2025 at 5:36 PM
    Vito_R
    Stock RCSB 4X4 TRD
    Thumper_6119 thanks for your comments and looking into this for me. I don't know home any searches I have done to figure it out. Unfortunately the slid stock mirror will not mount to the housing on the truck. I have been hoping not to have to replace it. When I get a chance I post where the mirror mounts. I guess this is what happens when you purchase a used Tundra. But it is in immaculate shape.
