TRD skid plate mounting with ready lift SST kit diff drop Success
Discussion in '3rd Gen Tundras (2022+)' started by Timmy23, Jan 27, 2023.
  1. Jun 8, 2024 at 5:31 PM
    619mattr
    619mattr New Member
    2024 Tundra HV Limited CrewMax TRD OR
    Fox 2.5 PES LT275/65R20 BFG KO3
    **FOX 2.5 Performance Elite Series**
    To get my TRD skid to fit, I used Black Aluminum Spacer 3/4" OD X 5/16" ID × 6 from metalspacersonline.com. The OD could be larger but they work fine for me. I bought stainless steel M8 1.25 pitch 60mm bolts and 5/16 galvanized steel spacers (they’re a bit thicker). Pics attached, I also still have my front aero and it works perfectly fine no issues or error messages. :thumbsup:
    I'm sure this same method could be used with the 3” TRD Lift just measure your sway bar bracket and buy that as a length for the spacer.
    chrisgibbs707 and Yaboy like this.
  2. Aug 27, 2024 at 4:16 AM
    maldo012
    maldo012 23 tundra hybrid
    Eric
    Chicago
    23 Tundra Hybrid-Limited
    3inch dobinsons ims struts w/Rough Country 1.5inch spring/M1 shocks in the rear— Icon Uca — Hostile maniac 20inch w/general grabber atx tires — Perry parts front bumps - alpharex luxx headlights— swapped many parts with trd body components— race off-road trd grill etc
    appreciate the good info. Truthfully I ordered the spacer set from metalspaceronline that has a whole bunch of different lengths of the 3/4ODx5/16id spacers and a m8 grade 10 bolt kit and just gonna test fit for best Fitment. Thanks for the info on the spacers and appreciate the website. These are literally the same type of spacers that ready lift/icon is selling but you get a better quality spacer in my opinion
    619mattr[QUOTED] likes this.
  3. Sep 11, 2024 at 3:32 AM
    maldo012
    Eric
    Chicago
    Just installed mine last night definitely going to be swapping for a small size spacer but I ended up installing with a 1 1/2 inch spacer with 60mm bolts
  4. Sep 11, 2024 at 3:36 AM
    maldo012
    Eric
    Chicago
    I did end up spray painting this bad boy though lol wasn’t a big fan of the aluminum look
    Bayou Spartan likes this.
  5. Sep 11, 2024 at 4:26 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    I really like this idea
  6. Sep 11, 2024 at 4:50 AM
    maldo012
    Eric
    Chicago
    It went smoother than I thought to be honest. Grabbed a single can of rustoleum enamel spray paint. Nice little sand down just to smooth it out. From what I heard you don’t need to do that step butttt in my experience with spray painting it is worth the time to prep the surface. Makes an even smooth application. Just make sure to let it fully dry lol I got my finger prints all over mine lol I’ll take a photo later after I adjust my spacers to a smaller set.
  7. Sep 16, 2024 at 1:17 PM
    sspen003
    sspen003 New Member
    Big thanks to everyone in this thread for inspiring me to tackle my skid plate issue! After installing an Eibach suspension kit that provided about a 2.6-inch lift in the front and 2 inches in the rear, I was advised to add a differential drop kit. However, I ran into a problem — my TRD skid plate no longer fit.
    Taking inspiration from the original poster, I decided to create a proof of concept using PVC spacers of varying lengths for all 6 bolts. After getting the measurements just right, I reached out to a local machine shop to turn the idea into a finished product. It worked out perfectly! The best part is that I can still use the original factory skid bolts, and the mounting brackets align perfectly, making it easy to remove the skid for oil changes.
    tundznoff and Timmy23[OP] like this.
  8. Sep 16, 2024 at 7:33 PM
    tundznoff
    tundznoff New Member
    blk limited tundra
    TRD red axel swap Satin black wrapped fender flares Satin black wrapped bumper insert Icon stage 5 Icon 1.25 rear spring Drkdss panhard bracket Rave trd pro grill & lights 37” K02 17” 0 offset Nomad Sahara
    I want to buy these , take my money please!
  9. Sep 17, 2024 at 12:32 PM
    sspen003
    sspen003 New Member
    I am not a fabricator or reseller; however, I would be happy to help you out so that you can come up with a similar solution.
  10. Oct 17, 2024 at 8:51 AM
    LanceChapin
    LanceChapin New Member
    Lance
    2023 Tundra 1794 Mesquite Hybrid
    T
    SSPEN003 I would like this kit as well. I have the TRD 3" lift kit on mine.
  11. Nov 3, 2024 at 4:27 PM
    Eznk1
    Eznk1 New Member
    Tony
    2024 Tundra
    How do you like the Eibach kit?
  12. Mar 17, 2025 at 8:56 AM
    2024 Tundra TRD OR
    2024 Tundra TRD OR New Member
    Adonis
    2024 Red Tundra TRD Off Road
    SSpen003 Can you give the measurements of the bolts used?
  13. Mar 24, 2025 at 8:20 PM
    Sankster
    Sankster Loving life!
    Paul
    Arizona
    2023 Blueprint Tundra Platinum 4x4
    TRD 3' Lift Kit, 34" Nitto Recon Grapplers
    Has anyone found or fabricated a TRD Skid plate drop kit for the TRD 3" lift kit?
  14. Mar 25, 2025 at 6:51 AM
    Reubenski
    Reubenski New Member
    2025 Limited CM, TRD Off-road package, 3" lift
    If you use the Toyota TRD sway bar with the Toyota 3 " lift the TRD skid plate will fit fine. Toyota doesn't add the TRD sway bar to the vehicles that they install the 3" lift on. Of course.... So they have to use the drop brackets for the factory base sway bar to fit the 3" lift. Those brackets and the height of that sway bar is why the TRD skid plate won't fit. The added benefit of the TRD sway bar is it will allow more clearance for bigger tires. It really does seem like the complete TRD parts do actually work well together, it's more the case that Toyota sells you an incomplete upgrade forcing you to buy more TRD accessories or fabricate skid plate spacers.
  15. Mar 25, 2025 at 7:11 AM
    Sankster
    Paul
    Arizona
    Does the TRD sway bar fit above or below the skid plate? Right now I have the skid plate installed, but the factory sway bar is below it, and I had to bend the skid plate a bit to make that work. And yes, I went up to 275/65/R20s on the original Platinum wheels and they slightly rub the sway bar when I crank it all the way to the left or right. Sounds like the TRD sway bar will fix both problems.
  16. Mar 25, 2025 at 7:15 AM
    Reubenski
    Above. As intended. You should be able to fit 285/65/R20's (34") without any rubbage. After that you need to remove the mudflap, start trimming wheel well liner and think about chopping the cab mount protrusion.
  17. Mar 25, 2025 at 8:18 PM
    Sankster
    Paul
    Arizona
    You wouldn't happen to have the part number, would you? I can't find it with a Google search.
  18. Mar 25, 2025 at 8:46 PM
    Reubenski
    I'm sorry. I don't. I had my dealer install it. I saw the part number floating around here where it this sway bar was discussed so a Google search should illuminate it
  19. Mar 25, 2025 at 8:50 PM
    Reubenski
  20. Apr 13, 2025 at 12:58 PM
    #50
    Spacecowboy863
    Spacecowboy863 New Member
    ooh...i like that too!
  21. Apr 13, 2025 at 1:32 PM
    #51
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    I thought I read in another thread that different sway bar links are also needed?
    TRD Sway Bar
    Bar Sub-Assy, FR Stabilizer
    Part Number: 48804-0C020
    1 $268.32
    Link Assy, FR Stabilizer, LH
    Part Number: 48810-0C030
    1 $60.98
    Part Number: 48820-0C030
    1 $60.98
